Bookmark
Subscribe
2217
Aironet 1252 doesn't broadcast SSID and VLANs
JOSE CHAUCA
Best regards.
I have an autonomus AP Aironet 1252 (software version: 12.4(18a)JA1)
I configured 3 SSID and VLANs, but the AP doesn't broadcast SSID, the vlans are working fine because I tested configuring manually the hide SSID on laptops.
Also the AP broadcasts the SSID whe only one SSID is configured!!!
How I can do the AP to broadcast all SSIDs?
Thanks in advance.
Surendra BG
Please chec kthe below Video..
https://supportforums.cisco.com/videos/2343
Surendra
Surendra BG
daviwatk
Level 3
Level 3
From the command line of your AP.
Change each SSID as follows.  You want to turn off "guest-mode" and enable "mbssid" at each SSID.  Guest-mode will only broadcast one SSID, you must use mbssid  to allow all SSIDs to broadcast.
#config t
#dot11 ssid
#no guest-mode
#mbssid
Now from each radio
#int d0
#mbssid
#int d1
#mbssid
Surendra BG
Surendra
Surendra BG
Thank you so much.
The wireless LAN is working fine now!
Jose
