04-12-2011 06:21 AM - edited 07-03-2021 08:04 PM
Please whats is the average/mnaximum distance coverable by Aironet 1300 and 1240AG ???
04-12-2011 06:28 AM
All depends on the antenna that we use!!
Range calculator link
http://www.cisco.com/en/US/products/hw/wireless/ps458/products_tech_note09186a008009459b.shtml
Antenna link
Lemme know if this answered ur question!!
Surendra
04-12-2011 06:53 AM
Thanks for the reply. Honestly I dont know how to do the calsulation, but I have the spec of the antennae for the 1240and 1300. I will appreciate if you ca help calculate or give average figure.
The antennaes are..
1300-
2.4 GHz, 5.2 dBi Mast Mount Omni Ant w/RP-TNC Connector
1240-
2.4 GHz 2.2 dBi Swivel Dipole Antenna Black, RP-TNC
5 GHz 3.5 dBi Swivel Dipole Antenna Black, RP-TNC
Thanks so much.
04-12-2011 12:17 PM
it depends on whether in a building or outside, the signal strengh is set and what Data-Rates you are expecting.
Average distances:
Outside, AIR-ANT4941 (Rubber Duck), 2,4 Ghz, max signal strengh (17dbm): 130 meter
Outside, AIR-ANT5135D-R (Rubber Duck), 5 Ghz, max signal strengh (17dbm): 130 meter
Outside, AIR-ANT1728, 2.4 GHz, 5.2 dBi Mast Mount Omni Ant w/RP-TNC Connector: 160 meter
For inside there is not really an average, as each building is different.
Frederik
