02-07-2014 01:23 AM - edited 07-05-2021 12:07 AM
Dear all, is the Aironet 1600 compatible with the old power supply of 1231 or 1242 APs?
Solved! Go to Solution.
02-07-2014 01:28 AM
Yes it will work.
1242AP: 12.95W maximum
1600 AP: 12.95 W
But still I recomamnd to use 1600 AP power options:
Reagrds
Dont forget to rate helpful posts
02-07-2014 01:28 AM
Yes it will work.
1600 AP: 12.95 W
Reagrds
02-07-2014 03:00 AM
If your talking about the AC power plug... Yeah it does work. I use then still have a bunch of those to test the newer AP's when there is no PoE switch. I have one old power injector that works also that I haven't thrown away:). Some of my customers still use both in there environment since they would upgrade their AP's but not their switches (no PoE).
