Aironet 2800 duplex mismatch
bvj197222
Our switch, WS-C3750X-24P running 15.0(2)SE4, keeps Reporting Duplex mixmatch With most of Our 2800 AP's;
Mar 14 09:32:18.338: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/14 (not half duplex), with XXX_AP3 GigabitEthernet0 (half duplex).
Mar 14 09:32:21.786: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet2/0/16 (not half duplex), with XXX_AP6 GigabitEthernet0 (half duplex).
The WLC (Cisco 5508, sw 8.3.140.0) reports speed 1000 and Duplex full. The switch also reports a-full and a-1000 on the switchports. I can only assume that this is a bug somewhere..
27 Replies 27
powys
We're getting this on both Catalyst and Small Business switches, the WLC is running 8.3.143.0. Upgrading to 8.5.x would involve a lot of work as we still have older APs which are supported on 8.3.x but not 8.5.x.
This is a known issue with 8.3.143.0. See here for more information:
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html#anc9
It's this bug: https://tools.cisco.com/bugsearch/bug/CSCvi02106
Field notice: https://www.cisco.com/c/en/us/support/docs/field-notices/702/fn70252.html
You can either open a TAC and you get a new 8.3.14x.x image where this is fixed, or wait until the next normal 8.3 release is out.
Please note, it's just a cosmetical issue and the AP/Switch is working correctly.
moved to 8.5.140.0 and all is well
Thank you
Same phenomenon with Aironet 2800 and WLC SW 8.5.160 on Catalyst 2960X
Then it should be a different bug. Please open a new thread and include the error messages you see and also the configuration of the switchport plus software version of the switch.
Ok i will open a new thread
I agree with Patrick.
If the controller is running 8.5MR6 and this message is still appearing, contact Cisco TAC as this could be a new bug.
I am using 8.5.151.0 and having same issue with one 2802 AP.
That is not possible, the problem was temporary and has now gone and is not reproducible, i had running 40 2802I temporary for an event and the issue was only on one port of an 2960X.
The AP´s were deployed to six 2960X but the issue was on only one port of an 2960X although all switchports and all AP´s had the same identical configuration.
Same issue with 8.3.143.0
Any luck with this ?
8.3.143.0 was released on 05 June 2018.
The fix is found in release 8.5.151.0 which was released back in 20 June 2019
Try upgrading the firmware of the controller.
