Anchor Controller Redundancy- Primary and secondary configuration
raymond wang
Can I configure the WLC 5508 in 2 locations as primary and secondary anchor for other wlc? I want the wlc to use one anchor as primary for the traffic. The traffic will go to secondary anchor if the primary fail.
I checked 7.4 code and can not find the way to configure it..
thanks
Ray
7 Replies 7
raymond wang
this is what I got from 7.3 document which frustrated me. I am planning to deploy 2 anchor in 2 data center. I was wondering if 7.4 supports the primary/secondary deployment..
A given foreign controller load balances wireless client connections across the list of anchor controllers configured for the guest WLAN. There is currently no method to designate one anchor as primary with one or more secondary anchors.
http://www.cisco.com/en/US/customer/docs/solutions/Enterprise/Mobility/emob73dg/ch10GuAc.html#wp999714
I've been asking for this feature for a long time now .. Still not supported
thanks to reply me. I think the only solution for me is to create the mobility group first and do the failover manually if one anchor fail.
Exactly .. I have one customer who has the second controllers interface shut ..
Has anyone heard an update on the feature request for prioritization of Anchor WLC's?
I would need to check the features in 8.0, but I think its still unchanged .. Anyone else want to comment ?
I think it is unchanged. If it is, recent WLC 8.0 Delta Webinars should highlighted it.
Rasika
