Bookmark
Subscribe
2494
Anchor in 8.5 and Foreign in 8.10
Antonio Macia
Level 3
Level 3
Should I expect any incompatibility issues between these two software versions running at the anchor and foreign controllers? According to other posts in this forum, the anchor and foreign can run different software versions, but is this true when the software differs up to 5 versions?
Thanks.
3 Accepted Solutions
Rasika Nayanajith
Yes, typically Cisco recommend to keep it within 3 version. However, I do not expect anything to break between 8.5.x and 8.10.x anchoring.
Any way those two code versions are long live releases. So I would not see any problem of going with it (unless you can match versions)
Rasika
*** Pls rate all useful responses ***
It’s the firmware version that you need to look at. The model doesn’t matter.
-Scott
Scott Fella
You are just tunneling the traffic, so as long as the wlc compatibly matrix has your firmware listed as compatible, you are fine. That means that it is supported by TAC.
-Scott
6 Replies 6
Rasika Nayanajith
Rasika
Thank you Rasika,
In my case I need to update a pair of WLC 5520 (foreign) to the 8.10 in order to support the new Cat9120 but the anchors are 5508 which support 8.5 as the latest version.
Scott Fella
This matrix will show you what is supported.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-201251
-Scott
Thanks Scott, but I don't see the combination of 5520 (foreign) and 5508 (anchor) at the "Wireless Controller Foreign and Anchor Support" table.
-Scott
Scott Fella
-Scott
