We are happy to announce the second refresh of 8.10MR1 Beta Program for PRODUCTION deployments.
8.10.109.48 is the second, qualified Beta Image and is fully BU supported.
After previous 8.10 CCO, this program is focused on hardening the software quality plus bug fixes mentioned in the release notes. The target date to post 8.10MR1 on CCO is in few weeks.
This beta refresh includes several crash fixes and critical bug fixes as mentioned in the below release notes.
Release Notes: https://www.cisco.com/web/software/280926587/149495/Release_Notes_8_10_109_48.pdf
Please fill out the signup form (if not done already) for access to the image, within 24hrs you will be granted access.
Signup form à http://cs.co/810MR1InterimAccess
Please login to software.cisco.com with your CCO ID and use the below links to download the software once access is granted.
AireOS 8.10.109.48 EFT Download links
Cisco Virtual Wireless Controller
Cisco 5520 Wireless Controller
Cisco 3504 Wireless Controller
Cisco 8540 Wireless Controller
eWLC 17.1 EFT Image download links
C9800-CL
Filename: C9800-CL-universalk9.BLD_V171_1_20191212_003336.SSA.bin
Download link: https://software.cisco.com/download/beta/2022578961
C9800-40/80:
Filename: C9800-universalk9_wlc.BLD_V171_1_20191212_003336.SSA.bin
Download link: https://software.cisco.com/download/beta/1838083298
C9800-L
Filename: C9800-L-universalk9_wlc.BLD_V171_1_20191212_003336.SSA.bin
Download link: https://software.cisco.com/download/beta/2047156536
CL OVA
Filename: C9800-CL-universalk9.BLD_V171_1_20191212_003336-vga.ova
Prime Infrastructure with support for Axel – E AP
Detailed installation/upgrade procedure can be found in the release notes for this release.
Please send in your feedback/issues in the below form.
Feedback Form : http://cs.co/810MR1InterimFeedback - We would review the feedback actively and follow up to make sure we address them.
Important Note:
There is a change in download method for Beta image. Unlike the previous beta releases, the images will be posted in software.cisco.com with restricted access. Please fill out the signup form mentioned above to get access to the image.
Resolved Caveats
8.10.109.48
CSCvm92998 | Cisco IOS and IOS XE Software Change of Authorization Denial of Service Vulnerability |
CSCvn00218 | Cisco IOS and IOS XE Software Session Initiation Protocol Denial of Service Vulnerability |
CSCvr50874 | 8.5.144.49 : kernel panic crash on 3800 |
CSCvr57817 | IOS APs are adding C0 to the AID in assoc-resp when configured as flexconnect central assoc. |
CSCvr71272 | WLC 3504 Free Timer Depletion leading to crash - Clients cannot connect |
CSCvr82181 | WLC crashing while accessing GUI > Monitor > Clients page |
CSCvr82520 | Cisco IOS Software Crashes when configuring a long snmp-server community string |
CSCvr86159 | Primary Controller 5520 in 8.9.111.0 rebooted unexpectedly |
CSCvr88965 | AP3800 adding extra padding to EAP-ID-REQ |
CSCvr95403 | Client arp entry remains even if the client is disconnected |
CSCvs14548 | Trustpoint Configuration Fails on Wave 2 APs in WGB |
CSCvs22775 | 8.10.105.0 : Deauth frame not sent by 2800/3800 AP for Contained clients |
CSCvs27550 | Cisco 1815 AP Kernel Panic pointing to Ethernet driver with large size packet traffic |
CSCvs29183 | WLC still shows weak SSH encryption algorithms with encryption high enabled |
CSCvc99155 | Cisco IOS and IOS XE Network Based Application Recognition Denial of Service Vuln |
CSCuw77959 | Cisco IOS and IOS XE Software DHCP Remote Code Execution Vulnerability |
CSCvg54267 | Cisco IOS and IOS XE Software Cisco Discovery Protocol Denial of Service Vulnerability |
CSCvi48253 | Self-signed certificates expire on 00:00 1 Jan 2020 UTC, can't be created after that time |
CSCvf36258 | Cisco IOS and IOS XE Software HTTP Client Information Disclosure Vulnerability |
CSCux66796 | Cisco IOS and IOS XE Software TACACS+ Client Denial of Service Vulnerability |
CSCvg39082 | Cisco IOS and IOS XE Software TCP Denial of Service Vulnerability |
CSCvh58917 | Cisco WLC MAC authentication web redirected URL is broken |
Hi rrudling,
We plan to upload 810MR1 on CCO on or before 1st week of Feb 2020. This will include the fix for CSCvs39989.
