Antenna orientation for AP1252
SJessulat_2
i browsed through nearly every antenna installation guide on cisco.com, but i still have one question:
what is the recommended orientation for antennas like the AIR-ANT2422DW-R on a AP1252. Should they be aligned parallel to each other or pointing into different directions? If so, in what direction?
Any best practices or even documents according to this?
Thanks in advance,
Sebastian
wynneit
The dipole antennas should all point in the same direction. with all 6 antennas installed it will look like a hedgehog
