AP 1131 AG do not associate to controller 5508 or 4402
I have 10 Access-Point model 1131 AG are new AP.
When I connect the access-Point to the network, the AP associate only one time but i go to wireless for see the AP, i can see downloading of IOS, but the ios is 3.0.59, the ap don not nothing. I can not change any parameters.
Regards.
Scott Fella
There have been many post regarding the 1131 not joining. Can you post more info. What WLC model and what code. Did you convert the AP? Did you have enough room in memory for the code to be downloaded to the AP?
Post your show run-config
Post the output from the AP console from when you boot up the AP.
-Scott
APfc99.47f4.d268#
*Mar  1 00:00:35.472: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.72.22.180, mask 255.255.254.0, hostname APfc99.47f4.d268
*Mar  1 00:00:46.757: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
*Mar  1 00:00:51.757: LWAPP_CLIENT_ERROR_DEBUG: spamHandleJoinTimer: Did not recieve the Join response
*Mar  1 00:00:56.766: LWAPP_CLIENT_ERROR_DEBUG: spamHandleJoinTimer: Did not recieve the Join response
examining image...
Loading file /c1130...
*Mar  1 00:01:01.775: LWAPP_CLIENT_ERROR_DEBUG: spamHandleJoinTimer: Did not recieve the Join response
*Apr 19 13:52:01.156: %LWAPP-5-CHANGED: LWAPP changed state to IMAGE!
extracting info (288 bytes)
Image info:
    Version Suffix: k9w8-.124-23c.JY
    Image Name: c1130-k9w8-mx.124-23c.JY
    Version Directory: c1130-k9w8-mx.124-23c.JY
    Ios Image Size: 4915712
    Total Image Size: 5079552
    Image Feature: WIRELESS LAN|LWAPP
    Image Family: C1130
    Wireless Switch Management Version: 7.1.91.0
Extracting files...
c1130-k9w8-mx.124-23c.JY/ (directory) 0 (bytes)
c1130-k9w8-mx.124-23c.JY/html/ (directory) 0 (bytes)
c1130-k9w8-mx.124-23c.JY/html/level/ (directory) 0 (bytes)
c1130-k9w8-mx.124-23c.JY/html/level/1/ (directory) 0 (bytes)
extracting c1130-k9w8-mx.124-23c.JY/html/level/1/forms.js (17486 bytes)!!
extracting c1130-k9w8-mx.124-23c.JY/html/level/1/sitewide.js (16548 bytes)!
extracting c1130-k9w8-mx.124-23c.JY/html/level/1/officeExtendap.css (41795 bytes)!!!!
extracting c1130-k9w8-mx.124-23c.JY/html/level/1/appsui.js (557 bytes)!
extracting c1130-k9w8-mx.124-23c.JY/html/level/1/config.js (24633 bytes)!!
extracting c1130-k9w8-mx.124-23c.JY/html/level/1/ap_home.shtml.gz (1300 bytes)
extracting c1130-k9w8-mx.124-23c.JY/html/level/1/back.shtml (506 bytes)
c1130-k9w8-mx.124-23c.JY/html/level/1/images/ (directory) 0 (bytes)
extracting c1130-k9w8-mx.124-23c.JY/html/level/1/images/cisco-logo-2007.gif (1648 bytes)!
extracting c1130-k9w8-mx.124-23c.JY/html/level/1/images/background_web41.jpg (732 bytes)
extracting c1130-k9w8-mx.124-23c.JY/html/level/1/images/login_homeap.gif (19671 bytes)!!
extracting c1130-k9w8-mx.124-23c.JY/html/level/1/images/info.gif (399 bytes)
c1130-k9w8-mx.124-23c.JY/html/level/15/ (directory) 0 (bytes)
extracting c1130-k9w8-mx.124-23c.JY/html/level/15/officeExtendapBanner.htm (7108 bytes)!
extracting c1130-k9w8-mx.124-23c.JY/html/level/15/officeExtendapHelp.htm (5007 bytes)
extracting c1130-k9w8-mx.124-23c.JY/html/level/15/officeExtendapEvent.shtml.gz (983 bytes)
extracting c1130-k9w8-mx.124-23c.JY/html/level/15/officeExtendapConfig.shtml.gz (2861 bytes)!
extracting c1130-k9w8-mx.124-23c.JY/html/level/15/officeExtendapMain.shtml.gz (3361 bytes)
extracting c1130-k9w8-mx.124-23c.JY/html/level/15/officeExtendapSummary.htm (712 bytes)
extracting c1130-k9w8-mx.124-23c.JY/c1130-k9w8-mx.124-23c.JY (4648399 bytes)!!!
This occur when I connect Access-Point to the network
Model of Controller 5508 and 4402
Model of AP: 1131 AG
AP are Lightweight (All ap are NEW)
Additional i have more access-point in the wireless network (this is old ).
The 1130's are new?  Did you have them laying around in a box or di you purchase it from a reseller?  The reason I ask, is because these AP's ahve only 16mb of memory and not enough space if there are other files in flash:
Also, what code are you running on the WLC... I see this on your log:
This was an interum release to support the 3500's I believe and you really need to upgrade.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Post the output to the following commands:
1.  WLC:  sh sysinfo;
2.  AP:  sh version;
3.  AP:  sh inventory
