AP-1231G boot problem :(
kjedroska
Community Member
I have Cisco AP-1231G.
My problem is that this AP doesnt want boot "automatically". This is console:
Xmodem file system is available.
flashfs[0]: 143 files, 7 directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 4922880
flashfs[0]: Bytes available: 2818560
flashfs[0]: flashfs fsck took 20 seconds.
Reading cookie from flash parameter block...done.
Base ethernet MAC Address: 00:13:7f:7d:34:07
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbs, full-duplex
Ethernet port 0 initialized: link is up
The system is not configured to boot automatically. The
following command will finish loading the operating system
software:
boot
C1200 Boot Loader (C1200-BOOT-M) Version 12.2(8)JA, EARLY DEPLOYMENT RELEASE SOF
TWARE (fc1)
TAC Support: http://www.cisco.com/tac
Compiled Wed 12-Feb-03 15:23 by hqluong
ap:
What I have to do ?
will.shaw
Level 4
Level 4
Check your Conf reg is set to 0xF
I have the same problem with a 1242AG, which is managed by a 4400 controller. It boots fine after I type "boot" into the console. Not sure how to set "Conf reg" to the indicated value, either through the console or the 4400.
What I can't seem to find is the equivalent to what you suggest above, nor a "Config ap boot" type of command. Any help would be greatly appreciated.
