AP 1250 dont connect ethernet!!
joao
i have a problem wich my ap 1250. I did the basic config by CLI but when i plug it on the switch, the switch port change to up but 5 seconds after the port change to down. In the midle of the switch and the AP i use the AIR-PWRINJ4.
I only config the int bvi 1 ip, and set the default gateway.
I dont know why the ap dont connect the ethernet!
Sorry for my bad english
Thanks!
bbxie
Level 3
Level 3
Typically what you met is related to power configurations on AP and switch, follow this doc to do the troubleshooting:
http://www.cisco.com/en/US/docs/wireless/access_point/1250/installation/guide/125h_c3.html#wp1077905
OK,
but how i configure?
I made a test configuring wich that command
"power inline negotiation injector H.H.H" and don't work!
without more information, it is difficult to say what's wrong, that's why I suggest you to do the troubleshooting according to the TS Guide step by step.
Basicly the TS could be summarized as following steps:
1. Check your cable connection:
*ethernet cable is connected to AP's ethernet port not console port
*AP is connected to Power Injector's AP port, Switch is connected to Power Injector's switch port.
2. Check AP's LED and Power Injector's LED(table 3-1 and 3-2 of the TS guide show the different result)
3. Check switch's port configuration(CDP, duplex, etc)
4. Check power configuration(refer to table 3-3~6, figure 3-3)
5. Check error logs( connect to AP's console port to see if there's any error/warning mesg)
when the AP IOS boot i receive this message "CDP_PD-4-POWER_OK: Full power - INJECTOR_DETECTED inline power source" the bv1 interface change to up and than change to down.
AP led status is green and the others are off.
The CDP protocol is enable.
I think the problem is betwen the power injector and the switch C2960G.
Any idea??
thanks
