08-28-2008 11:51 AM - edited 07-03-2021 04:23 PM
I have configured radius setting on the wireless controller. After applying setting I lost the control. I want to break the password. Pl let me know how I cn be able to break pasword of 4400 wireless controller.
Thanks in Antiscipation.
08-28-2008 12:03 PM
08-29-2008 10:57 PM
Thanks for the quick responce. Fortunately I have created a local user priv 15 on wlc. I disconnected WLC from the netwrok. Then I could be able to login through the local user.
I have one question if i dont have fergot the local user id and password, in that case will my configuration will lost during the recovery process?
Thanks for ur help.
08-30-2008 07:35 AM
That link is for a 4400 router. If you clear the config from the boot, then you will loose all your configuration and will have to configure the wlc fro the startup wizard. Here is a Q&A fro the WiSM, which is the same for the 4400's:
How can I reset the WiSM to factory default settings?
A. Complete these steps to reset the WiSM controller to factory defaults:
1.Enter reset system at the WiSM controller CLI.
2.At the prompt that asks whether you need to save changes to the configuration, enter Y or N. The unit reboots.
3.When you are prompted for a username, enter recover-config to restore the factory default configuration. The Cisco WLAN controller reboots and displays this message:
Welcome to the Cisco WLAN Solution Wizard
Configuration Tool4.The WiSM is now reset to factory defaults. Use the configuration wizard to enter new configuration settings.
09-01-2008 08:19 PM
How about just going to WCS and adding a new admin level user and then deleting the old?
