AP 1522 on pole
s.henrot
Hi All,
I will installed two APs 1522 for mesh network on poles, is it necessary to buy the hand strap tool AIR-BAND-INST-TL and how many ? In the doc, there's a ref too for a Band Hand tool AIR-BAND-IT-TOOL, what's the difference ?
Thks for your response.
Rob Huffman
Hi Stephane,
This is the same tool indicated by the two part#'s. Not sure why the difference but it is the same part. This tool is required for tightening the Metal Bands. You should order at least one kit.
Tighten the metal bands using the band strap tool (Cisco AIR-BAND-IT-TOOL=), following the operating instructions in the box with the tool. Ensure the metal bands are as tight as possible.
http://www.cisco.com/en/US/docs/wireless/access_point/1520/installation/guide/1520_ch2.html#wp1041452
Hope this helps!
Rob
