AP 1562E joins WLC 3504, SSID is broadcasted, assign static IP for the network, but cannot gain access to network
Network that I am trying to access is 199.8.0.0/16 and is on VLAN 1
AP01 joins WLC-1 and begins broadcasting SSID "CISCO2_test". Created a vlan 1 interface:
Interface Name        Port Vlan Id IP Address Type Ap Mgr Guest
management 5 99 10.1.99.2 Static Yes No
redundancy-management 5 99 0.0.0.0 Static No No
redundancy-port - untagged 0.0.0.0 Static No No
plant network vlan 1 1 199.8.210.2 Dynamic No No
service-port N/A N/A 192.168.1.1 Static No No
virtual N/A N/A 1.1.1.1 Static No No
Switch port WLC is connected is trunked. Switch port AP01 is connected to is trunked.
craig.beck
Have you set a native VLAN ID at the switchport where the WLC connects? If not it will be set to use VLAN 1, which will be untagged. The WLC has it tagged so it must match at both ends.
