AP-1832 join problem to 3504 Wireless controller
Hi. 🙂
I have a new configuration of one AP-1832 that I am trying to join to 3504 Wireless controller but it seems to be failing the CAPWAP join.
The AP is not visable from the controller.
See the output from the AP below.
Any guidance appreciated.
PS. What does "can't find the Ip from discoveryRequest array" mean?
[*12/09/2021 11:43:53.0000] CAPWAP State: DTLS Setup
[*12/09/2021 11:43:53.0299]
[*12/09/2021 11:43:53.0299] CAPWAP State: Join
[*12/09/2021 11:43:53.0299] Sending Join request to 192.168.32.100 through port 5256
[*12/09/2021 11:44:50.0222]
[*12/09/2021 11:44:50.0222] CAPWAP State: DTLS Teardown
[*12/09/2021 11:44:50.0322] Dropping dtls packet since session is not established. Peer 192.168.32.100-5246, Local 192.168.32.13-5256, conn (nil)
[*12/09/2021 11:44:54.8807]
[*12/09/2021 11:44:54.8807] CAPWAP State: Discovery
[*12/09/2021 11:44:54.8907] Discovery Request sent to 192.168.32.99, discovery type STATIC_CONFIG(1)
[*12/09/2021 11:44:54.8907] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*12/09/2021 11:44:54.8907] Discovery Response from 192.168.32.100
[*12/09/2021 11:45:05.0000] can't find the Ip from discoveryRequest array
3 Accepted Solutions
balaji.bandi
check the onboarding process :
https://mrncciew.com/2013/03/17/ap-registration/
- Others to check, what is the version, is the AP matrix supported that version and model
- is the NTP ok ?
- Do you have Licenses installed in WLC.
- Do you have Option 43 to set
Post below output :
WLC
sh sysinfo;
sh time
AP
sh version
BB
Leo Laohoo
Post the complete output to the following commands:
  1. WLC:  sh sysinfo
  2. WLC:  sh time
  3. WLC:  sh license
  4. AP:  sh version
Rich R
https://www.cisco.com/c/en/us/products/collateral/wireless/3504-wireless-controller/datasheet-c78-738484.html#Perpetuallicensing
https://www.cisco.com/c/en/us/support/docs/wireless/3504-wireless-controller/214106-licensing-on-3504-5520-and-8540-wireles.html#anc1
You need RTU license or smart licensing to cover the number of APs connected to the WLC.
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
7 Replies 7
balaji.bandi
- is the NTP ok ?
Post below output :
WLC
sh sysinfo;
sh time
AP
sh version
BB
Thanks for your reply.
The problem was that the license was in the "not-in-use" state after checking it by your recommendation.
License state: Active, Not-In-Use
Afterwards
License state: Active, In-use
Do you guys know what Cisco licenses are needed to operate one 3504 wireless controller and three AP-1832?
Is the license per AP?
Leo Laohoo
  1. WLC:  sh sysinfo
  2. WLC:  sh time
  3. WLC:  sh license
  4. AP:  sh version
yes per AP, you can bulk License.
BB
Rich R
Great information @Rich R!!
Much appreciated.
