AP 1852 does not join vWLC virtual controllers
Alexandre11
Level 5
Level 5
I installed 2 new virtual controllers vWLC version 8.5.161. and configured the mobility group, activated Ap Fallback among others
etc.
I'm trying to upload an AP model 1852 AIR-AP1852I-Z-K9 that is in version 8.5.131
cisco AIR-AP1852I-Z-K9 ARMv7 Processor rev 0 (v7l) with 997268 / 680032K bytes of memory.
Processor board ID KWC220801RJ
AP Running Image: 8.5.131.0
Primary Boot Image: 8.5.131.0
Backup Boot Image: 0.0.0.0
AP Image type: MOBILITY EXPRESS IMAGE
AP Configuration: NOT MOBILITY EXPRESS CAPABLE
2 Gigabit Ethernet interfaces
2 802.11 Radios
Radio FW version: 5fd9df2ef70d087b014a57c17ecc942b
NSS FW version: wstephen,
I configured DHCP option 43. But I gave the message below:
"config not found, PNP is required, Starting PNP "
 Failed to start timer, Null timer handler
Then we left without option 43 then gave the messages below:
Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Join(5).
[*10/30/2020 20:25:47.4445] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Join(5).
[*10/30/2020 20:25:55.0222]
[*10/30/2020 20:25:55.0222] CAPWAP State: DTLS Teardown
[*10/30/2020 20:25:55.0322] Dropping dtls packet since session is not established. Peer 10.1.104.1-5246, Local 10.1.105.0-5272, conn (nil)
[*10/30/2020 20:25:59.8907]
[*10/30/2020 20:25:59.8907] CAPWAP State: Discovery
[*10/30/2020 20:25:59.8907] Discovery Request sent to 255.255.254.0, discovery type STATIC_CONFIG(1)
[*10/30/2020 20:25:59.8907] IP DNS query for CISCO-CAPWAP-CONTROLLER.xxxxx.com.br
[*10/30/2020 20:25:59.9007] Discovery Request sent to 255.255.254.0, discovery type STATIC_CONFIG(1)
[*10/30/2020 20:25:59.9007] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*10/30/2020 20:25:59.9007] Discovery Response from 10.1.104.1
[*10/30/2020 20:25:59.9206] Discovery Response from 10.1.104.2
[*10/30/2020 20:26:10.0000] can't find the Ip from discoveryRequest array
[*10/30/2020 20:26:10.0000] CAPWAP State: DTLS Setup
[*10/30/2020 20:26:10.0199] First connect to vWLC, accept vWLC by default
[*10/30/2020 20:26:10.0299]
[*10/30/2020 20:26:10.0299] CAPWAP State: Join
[*10/30/2020 20:26:10.0299] Sending Join request to 10.1.104.1 through port 5272
What can this be ?
Can you help me ?
Mark Elsen
 - Check if this thread can help :
                    https://community.cisco.com/t5/other-wireless-mobility-subjects/can-t-join-ap-s-to-mobility-express-controller/td-p/3687114
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
In the acess-point show me this messages bellow:
[*11/03/2020 11:41:30.0122] CAPWAP State: DTLS Teardown
[*11/03/2020 11:41:34.8807]
[*11/03/2020 11:41:34.8807] CAPWAP State: Discovery
[*11/03/2020 11:41:34.8907] Discovery Request sent to 10.1.104.1, discovery type STATIC_CONFIG(1)
[*11/03/2020 11:41:34.8907] Discovery Request sent to 10.1.104.2, discovery type STATIC_CONFIG(1)
[*11/03/2020 11:41:34.8907] IP DNS query for CISCO-CAPWAP-CONTROLLER.xxxx.com.br
[*11/03/2020 11:41:34.9007] Discovery Request sent to 10.1.104.1, discovery type STATIC_CONFIG(1)
[*11/03/2020 11:41:34.9007] Discovery Request sent to 10.1.104.2, discovery type STATIC_CONFIG(1)
[*11/03/2020 11:41:34.9007] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*11/03/2020 11:41:34.9007] Discovery Response from 10.1.104.1
[*11/03/2020 11:41:34.9306] Discovery Response from 10.1.104.2
[*11/03/2020 11:41:34.9506] Discovery Response from 10.1.104.1
[*11/03/2020 11:41:34.9706] Discovery Response from 10.1.104.2
[*11/03/2020 11:41:34.9906] Discovery Response from 10.1.104.2
[*11/03/2020 11:41:35.0006] Discovery Response from 10.1.104.1
[*11/03/2020 11:41:44.0000]
[*11/03/2020 11:41:44.0000] CAPWAP State: DTLS Setup
[*11/03/2020 11:41:44.0099] First connect to vWLC, accept vWLC by default
[*11/03/2020 11:41:44.0299]
[*11/03/2020 11:41:44.0299] CAPWAP State: Join
[*11/03/2020 11:41:44.0299] Sending Join request to 10.1.104.1 through port 5248
[*11/03/2020 11:41:56.0562] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Join(5).
[*11/03/2020 11:41:56.0862] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Join(5).
In the controller show me this messages:
Have you accepted the EULA and enabled the license?
Yes. But the problem was the MIC certificate I enabled the mic certificate and works now.
