AP 185X and 9115 Firmware update
Ashok09
My Wi-Fi Network setup is mixed APs model. when we are trying to update the Firmware through EWC - HTTP method is not possible because the non homogenous  model.
Suppose i try to update the firmware via TFTP. the updated image is running in the backup Image.
Did anyone having this similar issues ?
9115 AP
cisco C9115AXE-D ARMv8 Processor rev 0 (v8l) with 1971676/1162088K bytes of memory.
Processor board ID FJC2742170A
AP Running Image : 17.3.5.43
Primary Boot Image : 17.3.5.43
Backup Boot Image : 17.9.4.27
1852 AP
cisco AIR-AP1852I-D-K9 ARMv7 Processor rev 0 (v7l) with 996240/592620K bytes of memory.
Processor board ID KWC262305YH
marce1000
 - The question is a bit confusing ; if you refer to client AP upgrade(s) connected to EWC check :
             https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/16-12/config-guide/ewc_cg_16_12/image_download.html
                          If not , please elaborate ,
 M.
marce1000
 M.
@marce1000
Thank you very much for your support and link
I have updated through web / GUI -> tftp method. But some of the AP's not able to update so used cli and then activated.
archive download-sw /no-reload tftp://192.168.XXX.XXX/C9800-AP-universalk9.17.09.04/ap3g3
Rich R
How did you do the upgrade?
As soon as you change the EWC version the subordinate APs will be triggered to download and switch to the new version.
