AP 2602 - AP cycling through dot11_set_rm_scan and dot11_return_serving_channel
So basically I got complaints regarding bad wireless connectivity and I found an AP not showing any signal in the heatmap.
Looked in on the eventlogs and found:
%EVT-5-NTC_PROC: dot11_set_rm_scan:DFS Disable
Process: Dot11 Offchannel PROCESS
%EVT-5-NTC_PROC: : d0 Channel 6 width 0
%EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 6 for d0
Process: Dot11 driver
%EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 1
%EVT-5-NTC_PROC: dot11_set_rm_scan: d1 Channel 52 width 0
%EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 52 for d1
%EVT-5-NTC_PROC: dot11_return_serving_channel: d1 Channel 48
My first thought was about some sort of Interference causing that cycling and complaints from costumers and the missing signal in the heatmap? How do I find the interferring device(s)?
marce1000
 - Cleanair capable ap's might offer a solution , here is a sample document :
       https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/wireless/controller/7-5/configuration-guide/b_cg75/b_cg75_chapter_010000101.html.xml#:~:text=Choose%20Monitor%20%3E%20Cisco%20CleanAir%20%3E%20802.11,the%20interferen....
 M.
Scott Fella
Swap the ap around with another one that is functioning and see if the problem follows the ap or not. Can help determine if the issue is with the ap or an issue in the area which you would need tools to find the source.
-Scott
what tools would I need?
I also looked into the stats with:
show ap stats 802.11b <broken_ap>
Stats Information
Number of Users................................ 0
TxFragmentCount................................ 10084553
MulticastTxFrameCnt............................ 2160656
FailedCount.................................... 250381
RetryCount..................................... 1054785
MultipleRetryCount............................. 480771
FrameDuplicateCount............................ 0
RtsSuccessCount................................ 1895390
RtsFailureCount................................ 228626
AckFailureCount................................ 2770749
RxIncompleteFragment........................... 0
MulticastRxFrameCnt............................ 0
FcsErrorCount.................................. 92191931
TxFrameCount................................... 10214739
WepUndecryptableCount.......................... 5
TxFramesDropped................................ 21548
this is what I found
