AP 2702 dropping clients!
Moudar
I am receiving many complains about Teams and Skype being bad under video meetings, that the picture and voice freezes many times. When i check the logs of the AP that the client was connected to i see so many logs as:
#Dropping the auth req recvd in disabled BSSID.... with many MAC addresses which belong to different clients
Another log that comes often is:
%WIDS-6-SIG_ALARM_OFF: Attack is cleared on Sig:Standard Id:9 Channel:52
this logs comes with different channels and syslog numbers.
My envorniment is consist of many 2702 and 2802 AP which are at the same area. I dont know if this is the problem. But it is only some of my 2702 APs that have these logs not the 2802s!
My workround was to reboot the APs, some of them came back with the same logs after being rebooted and some not, still talking about 2702 APs.
Any thoughts about this?!
19 Replies 19
 It seems to me that you may have some neighbor with wIPS enabled.  I had this problem more then once. Usually people who buy Meraki and dont know how to use it, let wIPS enable and they start to drop everything around.
  I had to help somenone configure their Meraki once so that I could have my network stable again.
 It is only my network that runs the building and no other network are available!!
Georg Pauwen
I wonder if these log messages are related to your problem at all. The WIDS messages could just be related to APs being discovered.
Do you have QoS enabled on the AP 2702 (which automatically enables WMM (Wi-Fi Multimedia) ?
QoS is not enabled.
What about the first log: Dropping the auth req recvd in disabled BSSID  ?
I have checked CSCve54287 which says that a reboot will fix the problem. Some APs seem to be OK after the reboot but other not!
Leo Laohoo
  1. What, EXACTLY, is the problem?
  2. Is this happening to one person('s device) or a lot of users?
  3. What firmware is the controller running on?
  4. Isolate and identify what wireless clients are affected (based on OS or SSID or location).
  5. What, EXACTLY, is the error message being displayed?
  6. What radio are the issue(s) more prominent?
  7. Have you VERIFIED and replicated the issue?
Clients are complaining  that camera under Teams and Skype video meetings freeze
is this happening to one person('s device) or a lot of users?
Happens to many users with Windows PC and Ipad
8.3.133, complains are comming only from one building not all my clients
try to understand what logs mean, will change the AP to different model and check if it will come with same logs
both 2,4 and 5
isolate and identify what wireless clients are affected (based on OS or SSID or location).
Windows 10 machines and Ipads. Windows and Ipad are connecting to two different SSIDs
logs from the AP:
BSSID 84b8.0230.e4fd is disabled in rcvd auth req!
*Feb 15 11:38:13.351: Dropping the auth req recvd in disabled BSSID 84b8.0230.e4fd from the client  algorithm 0 on Dot11Radio0
*Feb 15 11:38:13.663: BSSID 84b8.0230.e4fd is disabled in rcvd auth req!
*Feb 15 11:38:13.663: Dropping the auth req recvd in disabled BSSID 84b8.0230.e4fd from the client  algorithm 0 on Dot11Radio0
*Feb 15 11:38:13.971: BSSID 84b8.0230.e4fd is disabled in rcvd auth req!
*Feb 15 11:38:13.971: Dropping the auth req recvd in disabled BSSID 84b8.0230.e4fd from the client  algorithm 0 on Dot11Radio0
*Feb 15 11:38:14.283: BSSID 84b8.0230.e4fd is disabled in rcvd auth req!
*Feb 15 11:38:14.283: Dropping the auth req recvd in disabled BSSID 84b8.0230.e4fd from the client  algorithm 0 on Dot11Radio0
*Feb 15 11:38:14.595: BSSID 84b8.0230.e4fd is disabled in rcvd auth req!
*Feb 15 11:38:14.595: Dropping the auth req recvd in disabled BSSID 84b8.0230.e4fd from the client  algorithm 0 on Dot11Radio0
*Feb 15 11:39:25.127: BSSID 84b8.0230.e4fd is disabled in rcvd auth req!
       - FYIhttps://bst.cloudapps.cisco.com/bugsearch/bug/CSCve54287?rfs=iqvred
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Workround according to the webpage is to reboot the AP, which is not giving the desired result. I still getting Dropping logs!!
       - Then you need to engage with Cisco TAC (mention the bug report too)
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Rich R
  • What firmware is the controller running on?
    8.3.133
Right that is your first problem - you're running on obsolete code.  No point contacting TAC they'll just tell you to upgrade to supported code so that should be your starting point.  You don't mention what model of WLC you're using so that affects what version of code you can upgrade to but you should probably be running 8.10.162.0 or 8.5.182.0/8.5.171.0
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
Then if you still see the same problems then run client debugs on one of the clients experiencing problems and feed that into https://cway.cisco.com/wireless-debug-analyzer/
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
we are using 5520 WLC
Have many 2600 AP model so we cant move to 8.10.162.0 just yet but we are planing to move to 8.5.182.0 soon.
Why is this happening only to 2700 model?
will run the analyzer and get back with result
Are they using MS Teams version 1.5.00.2164?
It is version 1.4.00.35564
Rich R
Sometimes a bug can affect a specific model or models of AP.
2600 is 11n, 2700 is 11ac wave 1, so you'd expect them to be running different code (although they are both running Cisco IOS).  2802 is 11ac wave 2 running AP-COS so another completely different set of code.
