AP 3702E - MIBs for SNR, RSL, SIR
roxanateodosiu
Hello everyone,
I'm currently using a 3702E AP in Autonomous Mode for some performance tests and I would like to monitor the following parameters: SNR, RSL and SIR. However, I was enable to find these parameters among the variables provided by the MIBs installed.
The IOS version is 15.3(3)JBB4.
Could you tell me if it's possible to monitor these parameters and in which MIB could I find them?
Thanks!
Roxana
  On the device itself I believe you will not find too much information. Therefore, you can find some information at:
http://tools.cisco.com/ITDIT/MIBS/servlet/index
Furthermore, to monitor an Standalone Access Point, you should create an SNMP Community on such device and point to your NMS.
