AP 9115 join issue
Claudio Battan
Frequent Visitor
Frequent Visitor
I have a problem with APs in a WiFi system with 9800-CL, version 17.9.4.a.
In a branch, connected with IPSEC VPN, the APs (all C9115AX) are regularly joined to the controller, located in the headquarter.
In recent days, the connection had problems and remained down for several minutes.
The APs, which are configured in FLEX-mode, work fine, but after some time on the controller they appear as non-joined - and this is obvious and normal.
The anomaly is that, even when the line comes back UP, the APs do not return Joined (even after a long time), but I have to restart them.
Anyone have any ideas?
Thank you
Mark Elsen
 - Depending how connection states are preserved or not , the (flapping) IPSEC VPN tunnel(s) may not always provide a clear connectivity path for the AP(s) to the controller ; check the VPN server logs too at the branch and check if you can see connecting attempts for the AP and if they are handled  properly (e.g.)
                   Also look into : https://logadvisor.cisco.com/logadvisor/wireless/9800/9800APJoin
  Appendix : review the 9800-CL configuration with the CLI command show tech wireless and feed the output into :
        Wireless Config Analyzer
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rich R
@Claudio Battan If you remain on 17.9.4a then make sure you have the latest SMUs and APSPs installed.
You could also consider installing recently released 17.9.5 which has some bug fixes for AP disconnections.
However it is suspicious that none of your APs reconnect automatically (if it's one of those bugs then it won't usually affect all of them).  Is there any NAT or firewall between the APs and the WLC?
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
First check the IPSec status when the AP's can not join
MHM
