i am using 5760 wlc and cisco switch 4948 core switch and 2960 access switch .
on core switch i create two vlans
vlan 10
name mangement
vlan 50
name clent
when i am creating SSID in controller via command line and assigning vlan 50
the following error is showing to me
Controller(config-wlan)#clent vlan 50
% Invalid input detected at '^' marker.
Controller(config-wlan)# no security wpa akm dot1x
Controller(config-wlan)# security wpa akm psk set-key ascii 0 12345678
Controller(config-wlan)# no shutdown
Controller(config-wlan)#client v
Controller(config-wlan)#client vlan 50
% switch-1:wcm:Request failed - WLAN in the enabled state.
Controller#sh wlan summary
Number of WLANs: 1
WLAN Profile Name SSID VLAN Status
1 testing1234 testing1234 1 UP
so i have to upgrade the latest ios of switch 4948 and access switch 2960 also
wlc logs
Controller#
Apr 5 20:58:13.188: *spamApTask0: 1 wcm: %CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: Failed to delete CAPWAP data tunnel with interface id: 0x0 from internal database. Reason: AVL database entry not found [...It occurred 2 times/sec!.]
Controller#
Apr 5 20:58:23.591: *spamApTask0: 1 wcm: %CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: Failed to delete CAPWAP data tunnel with interface id: 0x0 from internal database. Reason: AVL database entry not found [...It occurred 2 times/sec!.]
Controller#
Apr 5 20:58:33.998: *spamApTask0: 1 wcm: %CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: Failed to delete CAPWAP data tunnel with interface id: 0x0 from internal database. Reason: AVL database entry not found [...It occurred 2 times/sec!.]
Controller#
Apr 5 20:58:44.402: *spamApTask0: 1 wcm: %CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: Failed to delete CAPWAP data tunnel with interface id: 0x0 from internal database. Reason: AVL database entry not found [...It occurred 2 times/sec!.]
Controller#
Apr 5 20:58:54.805: *spamApTask0: 1 wcm: %CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: Failed to delete CAPWAP data tunnel with interface id: 0x0 from internal database. Reason: AVL database entry not found [...It occurred 2 times/sec!.]
Controller#
Apr 5 20:59:05.206: *spamApTask0: 1 wcm: %CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: Failed to delete CAPWAP data tunnel with interface id: 0x0 from internal database. Reason: AVL database entry not found [...It occurred 2 times/sec!.]
Controller#
Apr 5 20:59:15.612: *spamApTask0: 1 wcm: %CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: Failed to delete CAPWAP data tunnel with interface id: 0x0 from internal database. Reason: AVL database entry not found [...It occurred 2 times/sec!.]
Controller#
Apr 5 20:59:26.019: *spamApTask0: 1 wcm: %CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: Failed to delete CAPWAP data tunnel with interface id: 0x0 from internal database. Reason: AVL database entry not found [...It occurred 2 times/sec!.]
Controller#
Apr 5 20:59:36.424: *spamApTask0: 1 wcm: %CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: Failed to delete CAPWAP data tunnel with interface id: 0x0 from internal database. Reason: AVL database entry not found [...It occurred 2 times/sec!.]
Controller#
Apr 5 20:59:46.829: *spamApTask0: 1 wcm: %CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: Failed to delete CAPWAP data tunnel with interface id: 0x0 from internal database. Reason: AVL database entry not found [...It occurred 2 times/sec!.]
Controller#
Apr 5 20:59:57.234: *spamApTask0: 1 wcm: %CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: Failed to delete CAPWAP data tunnel with interface id: 0x0 from internal database. Reason: AVL database entry not found [...It occurred 2 times/sec!.]
Controller#
Apr 5 21:00:07.639: *spamApTask0: 1 wcm: %CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: Failed to delete CAPWAP data tunnel with interface id: 0x0 from internal database. Reason: AVL database entry not found [...It occurred 2 times/sec!.]
Controller#
Apr 5 21:00:18.043: *spamApTask0: 1 wcm: %CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: Failed to delete CAPWAP data tunnel with interface id: 0x0 from internal database. Reason: AVL database entry not found [...It occurred 2 times/sec!.]
Controller#
Apr 5 21:00:28.448: *spamApTask0: 1 wcm: %CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: Failed to delete CAPWAP data tunnel with interface id: 0x0 from internal database. Reason: AVL database entry not found [...It occurred 2 times/sec!.]
Controller#
Apr 5 21:00:38.852: *spamApTask0: 1 wcm: %CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: Failed to delete CAPWAP data tunnel with interface id: 0x0 from internal database. Reason: AVL database entry not found [...It occurred 2 times/sec!.]
