AP can not Join Primary WLC
Hussein Mahmoud
I have tow 2500 series wireless controller as primary and secondary and  24 APs  AIR-CAP3602E / 5  APs AIR-CAP 1532E.
Previously to the system working normally,
The problem was that only 5 (1532) of the 24 APs (3602) weren't joining the primary WLC; however, when I accessed the secondary, we discovered all the APs.
WLC Primary IP 192.168.100.30
WLC Secondary IP 192.168.100.31
the message displayed when accessing AP 3602 through a console
Press RETURN to get started!
*Mar 1 00:00:12.959: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (11)
*Mar 1 00:00:12.959: %IFMGR-7-NO_IFINDEX_FILE: Unable to open nvram:/ifIndex-table No such file or directory
*Mar 1 00:00:13.415: Registering HW DTLS
APAVC: Initial WLAN Buffers Given to System is 2500
APAVC: Walpack's 18174 Radio Paks 17566
*Mar 1 00:00:15.795: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:19.615: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar 1 00:00:25.943: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4)
*Mar 1 00:00:26.147: Wait until the stile protocol list is initialized.
*Mar 1 00:00:29.159: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar 1 00:00:31.375: Start STILE Activation
*Mar 1 00:00:38.895: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3600 Software (AP3G2-K9W8-M), Version 15.2(4)JB6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 22-Aug-14 11:52 by prod_rel_team
*Mar 1 00:00:38.895: %SNMP-5-COLDSTART: SNMP agent on host CORRIDOR(255) is undergoing a cold start
*Mar 1 00:00:40.171: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up ERROR: Failed to configure ethernet promiscuous mode. Interface Descriptor mismatch
*Mar 1 00:00:54.039: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (2-8)
*Mar 1 00:00:54.039: DPAA Initialization Complete
*Mar 1 00:00:54.039: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar 1 00:00:55.039: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:01:01.435: APAVC: Succeeded to activate all the STILE protocols.
*Mar 1 00:01:01.435: APAVC: Registering with CFT
APAVC: CFT registration of delete callback succeeded
APAVC: Reattaching Original Buffer pool for system use
Pool-ReAtach: paks 18174 radio17566
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Mar 1 00:01:12.407: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar 1 00:01:12.407: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Mar 1 00:01:12.431: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to uplwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:01:12.607: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:01:12.607: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:01:12.619: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 1 00:01:12.619: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar 1 00:01:13.431: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar 1 00:01:13.607: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar 1 00:01:18.523: %CDP_PD-4-POWER_OK: Full power - INJECTOR_CONFIGURED_ON_SOURCE inline power source
*Mar 1 00:01:19.619: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 1 00:01:20.619: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar 1 00:01:20.715: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 1 00:01:21.715: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar 1 00:01:22.603: Logging LWAPP message to 255.255.255.255.
*Mar 1 00:01:41.607: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar 1 00:01:51.607: %CAPWAP-3-ERRORLOG: Selected MWAR 'GAZA-WLC-01'(index 0).
*Mar 1 00:01:51.607: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Sep 4 13:58:07.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.100.30 peer_port: 5246
*Sep 4 13:58:07.407: %CAPWAP-5-DTLSREQSUCC: DTLS connection created successfully peer_ip: 192.168.100.30 peer_port: 5246
*Sep 4 13:58:07.407: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.100.30
*Sep 4 13:58:07.411: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Sep 4 13:58:07.411: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Sep 4 13:58:07.411: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Sep 4 13:58:07.411: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 192.168.100.30
*Sep 4 13:58:12.407: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.100.30
6 Replies 6
is your AP is matching to exact regulatory domain which configured in WLC?
Good luck
KB
Yes, sure matching
Mark Elsen
  - Check logs on the controller  too when the particular AP is trying to join.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I checked and can ping from primary WLC to AP and vice versa also from the SW can ping WLC and AP
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Hussein Mahmoud
thanks all ,
the issue has been solved .
WLC GUI>>Secuirty>>AAA>AP policies>>Add> ? (AP mac addr) and check if it joins.
