AP issue
frederick.mercado
Hello we have a local 9120axi AP with a 9800LC WLC that seems to be losing connection. The AP is in flex connect, all config looks fine:
Advanced
Country Code
US
Multiple Countries
US
Statistics Timer
180
CAPWAP MTU
1485
AP Link Latency
Enabled
AP PMK Propagation Capability
Enabled
TCP Adjust MSS Option
AP TCP MSS Adjust
Enabled
AP TCP MSS Size
1250
AP IPv6 TCP MSS Adjust
Enabled
AP IPv6 TCP MSS Size
1250
AP Retransmit Config Parameters
AP Retransmit Count
8
AP Retransmit Interval
Version
Primary Software Version
17.9.3.50
Predownloaded Status
N/A
Predownloaded Version
N/A
Next Retry Time
N/A
Boot Version
1.1.2.4
IOS Version
17.9.3.50
Mini IOS Version
0.0.0.0
Time Statistics
Up Time
191 days 23 hrs 8 mins 37 secs
Controller Association Latency
25 secs
Is the AP currently connected to controller
JOINED
Time at which the AP joined this controller last time
04/22/2024 11:35:11
Type of error that occurred last
Run
Time at which the last join error occurred
04/22/2024 11:34:21
Last AP Disconnect Details
Reason for last AP connection failure
Max Retransmission to AP
Last Reboot Reason (Reported by AP)
No reboot reason
Control DTLS Statistics
DTLS Session request received
2983
Established DTLS session
2977
Unsuccessful DTLS session
6
Reason for last unsuccessful DTLS session
DTLS Handshake Certificate Authentication Failed
Time at last successful DTLS session
04/22/2024 11:35:07
Time at last unsuccessful DTLS session
03/22/2024 20:11:21
Join phase statistics
Join requests received
2979
Successful join responses sent
2977
Unsuccessful join request processing
Reason for last unsuccessful join attempt
NA
Time at last successful join attempt
04/22/2024 11:35:11
Time at last unsuccessful join attempt
02/29/2024 00:35:29
Configuration phase statistics
Configuration requests received
8931
Successful configuration responses sent
8931
Unsuccessful configuration request processing
Reason for last unsuccessful configuration attempt
NA
Time at last successful configuration attempt
04/22/2024 11:35:12
Time at last unsuccessful configuration attempt
NA
Data DTLS Statistics
DTLS Handshake Success
NA
NA
No ICMP drops from concurrent ping. No other reported issues on the 9300 Switch or other APs. There were some loss of connectivity for users at 0834 hrs and 1051 hrs.
Closest thing I ran into was this error in the radioactive tace: "AP disconnect initiated. Reason: Max Retransmission to AP, Phase: Run"
22 Replies 22
balaji.bandi
May try upgrading to IOS XE 17.9.4a or 17.9.5
is that MTU show after yoyu changed as suggest bug :
Decrease the MTU between AP and WLC to match same MTU than between WLC and AP
what end devices ? run debug using one client MAC address and post the debug here or use WLC tools
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
BB
I saw this posting - similar....Max retransmissions to AP - Page 2 - Cisco Community
I also noticed that we are operating on the second WLC controller (HA)...did a force back to the main WLC. Will monitor.
I am trying to figure out how to change the MTU....I see we can change the TCP MSS size in the AP join profile, the second question is how do we know the proper number?
First i suggest to upgrade suggest and then let us know still the issue.
BB
I just completed an ISSU to 17.9.5 - the only concern I have is that they seemed to deprecate ip nat inside/outside....this was brought up in a mismatch command alert. We had configured globally, "ip nat log translations syslog" and the interface had "ip nat inside" We had it set to one of our VLANs through a breakout ISP for mobile devices, but unsure if this is a hinderance. I will test this.
Lucky you avoided CSCwh29442 & CSCwh76420.
Indeed - looks on the up - minus the ip nat...
So I upgraded to 17.9.5...again still have this issue with this one AP....users notice packet loss ( ping timeout ) to any host... and I can see the AP in the no joined category if I monitor the WLC page for some time, eventually as shown it rejoins.
show wireless stats ap session termination
Event Previous State Occurance Count
DTLS session closed RUN 3
Message timer expiry RUN 56
show ap crash
File Location: BOOTFLASH
AP Name Crash File Radio Slot 0 Radio Slot 1 Radio Slot 2 Radio Slot 3
show wireless stats ap history | i Disjoined
AP_Main_1  Disjoined 04/24/24 09:30:23 NA Max Retransmission to AP 1
AP_Main_1  Disjoined 04/24/24 09:21:23 NA Max Retransmission to AP 1
AP_Main_1  Disjoined 04/24/24 08:18:19 NA Max Retransmission to AP 1
AP_Main_1  Disjoined 04/24/24 07:33:18 NA Max Retransmission to AP 1
AP_Main_1  Disjoined 04/24/24 07:15:16 NA Max Retransmission to AP 1
AP_Main_1  Disjoined 04/24/24 05:00:11 NA Max Retransmission to AP 1
AP_Main_1  Disjoined 04/24/24 03:48:30 NA DTLS close alert from peer 1
AP_Main_1  Disjoined 04/24/24 02:36:06 NA Max Retransmission to AP 1
AP_Main_1  Disjoined 04/24/24 02:18:03 NA Max Retransmission to AP 1
AP_Main_1  Disjoined 04/24/24 01:33:06 NA Max Retransmission to AP 1
show ap tag summary | i Yes
Time looks fine, county code is US.
48
48
04/24/2024 09:31:10
NA
Switch side looks ok:
sh int gi1/0/24
GigabitEthernet1/0/24 is up, line protocol is up (connected)
Description: AP
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is on, output flow-control is unsupported
Last input 00:00:05, output 00:00:00, output hang never
Input queue: 0/2000/0/1 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 115000 bits/sec, 38 packets/sec
5 minute output rate 887000 bits/sec, 323 packets/sec
161268489 packets input, 70296340553 bytes, 0 no buffer
Received 1899844 broadcasts (1896985 multicasts)
0 watchdog, 1896985 multicast, 0 pause input
5395151790 packets output, 1170461780862 bytes, 0 underruns
Output 683989294 broadcasts (3606762524 multicasts)
0 output errors, 0 collisions, 2 interface resets
558403 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Cable test is fine:
Interface Speed Local pair Pair length Remote pair Pair status
Gi1/0/24
1000M
Pair A 33 +/- 10 meters Pair A Normal
Pair B 33 +/- 10 meters Pair B Normal
Pair C 33 +/- 10 meters Pair C Normal
Pair D 33 +/- 10 meters Pair D Normal
 - Check switch connection for the involved AP , look at port counters , watch for anomalies , look at interface status : make sure there is a normal full duplex connection established with 1G speed,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Already posted above -
Description: AP
Last input 00:00:24, output 00:00:00, output hang never
5 minute input rate 94000 bits/sec, 25 packets/sec
5 minute output rate 762000 bits/sec, 298 packets/sec
161401072 packets input, 70347020394 bytes, 0 no buffer
Received 1900859 broadcasts (1897672 multicasts)
0 watchdog, 1897672 multicast, 0 pause input
5396602165 packets output, 1170890894458 bytes, 0 underruns
Output 684118328 broadcasts (3607782196 multicasts)
558561 unknown protocol drops
Maybe bad AP?
                  >...Maybe bad AP?
  - Always a possibility , especially if there are no problems with the rest of them , you may try reboot with power cycle; now for POE connected APs that is easy to accomplish , with shut , and followed by no-shutdown of the connected port ,
 M.
Here is the log from AP. Immediately I noticed the time jumps back from 1100hrs to 1500hrs back and forth?!
AP_Main_1#show ntp
Stratum Version Last Received Delay Offset Jitter NTP server
5 4 11sec ago 0.248ms -0.124ms 1.906ms 10.74.31.200
It seems to be reaching WLC for NTP - again no issues from other APs....
System logging :
Apr 24 15:28:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] chpasswd: password for user changed
Apr 24 11:28:17 chpasswd: password for user changed
Apr 24 15:28:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] systemd[1]: Starting Cisco syslogd watcher...
Apr 24 15:28:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] Same LSC mode, no action needed
Apr 24 15:28:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] CLSM[00:00:00:00:00:00]: U3 Client RSSI Stats feature is deprecated; can no longer be enabled
Apr 24 15:28:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] systemd[1]: Starting ntp file watcher...
Apr 24 11:28:17 ntp_update: NTP: Wed Apr 24 11:28:17 2024 :Can not create ntp process log file.
Apr 24 11:28:17 syslogd exiting
Apr 24 11:28:17 syslogd started: BusyBox v1.32.1
Apr 24 15:28:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] systemd[1]: Started Cisco syslog service.
Apr 24 15:28:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] systemd[1]: Started Cisco syslogd watcher.
Apr 24 15:28:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] hostapd:radius_extended_config: radius_aaa_msg_timeout(0) radius_aaa_msg_max_retransmit(0)
Apr 24 15:28:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] Got WSA Server config TLVs
Apr 24 15:28:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] hostapd:radius_extended_config: radius_aaa_msg_timeout(5) radius_aaa_msg_max_retransmit(3)
Apr 24 15:28:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] systemd[1]: Starting Dcdsd Watcher...
Apr 24 15:28:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] systemd[1]: Stopping Dcdsd server...
Apr 24 11:28:18 dcdsd: DIGEST-MD5 common mech free
Apr 24 15:28:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] Memcached status changed from 255 to 1. Notify VRRP
Apr 24 15:28:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] Closing sockets, exiting DCDSd process
Apr 24 15:28:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] systemd[1]: Starting Dcdsd server...
Apr 24 15:28:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] systemd[1]: Started Dcdsd server.
Apr 24 15:28:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] systemd[1]: Started Dcdsd Watcher.
Apr 24 15:28:20 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1]
Apr 24 15:28:20 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] *** Unable to connect to: 127.0.0.1:4040 - [Errno 111] Connection refused
Apr 24 15:28:22 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1]
Apr 24 15:28:22 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] *** Unable to connect to: XXX.XXX.XXX.XXX:4040 - [Errno 111] Connection refused
Apr 24 15:28:24 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1]
Apr 24 15:28:24 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] *** Unable to connect to: XXX.XXX.XXX.XXX:4040 - [Errno 111] Connection refused
Apr 24 15:28:26 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1]
Apr 24 15:28:26 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] *** Unable to connect to: XXX.XXX.XXX.XXX:4040 - [Errno 111] Connection refused
Apr 24 15:28:28 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1]
Apr 24 15:28:28 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] *** Unable to connect to: XXX.XXX.XXX.XXX:4040 - [Errno 111] Connection refused
Apr 24 15:28:30 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1]
Apr 24 15:28:30 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] *** Unable to connect to: XXX.XXX.XXX.XXX:4040 - [Errno 111] Connection refused
Apr 24 15:28:32 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1]
Apr 24 15:28:32 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] *** Unable to connect to: XXX.XXX.XXX.XXX:4040 - [Errno 111] Connection refused
Apr 24 15:28:32 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] In write handler 'add_cache_param_via_tlv' for 'pmk_tracker :: PMKTracker':
Apr 24 15:28:32 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] not a valid cache_type in add_cache_param_via_tlv
Apr 24 15:28:44 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] set cleanair [slot0][band0] enabled
Apr 24 15:28:44 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] set cleanair [slot0][band1] enabled
Apr 24 15:28:44 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] set cleanair [slot1][band1] enabled
Apr 24 15:28:44 NCI: I0: openSensor(slot=0)
Apr 24 11:28:44 eeprom_api[5130]: cfg loopback only mode 0
Apr 24 15:28:45 NCI: I0: SensorApp=5325626c
Apr 24 15:28:45 NCI: I0: SensorHdw=1.5.3
Apr 24 15:28:45 NCI: I0: Hardware Radio Band = [4890, 5935] MHz, BW=75313, band=1
Apr 24 15:28:45 NCI: I0: Hardware Radio Band = [2400, 2500] MHz, BW=75313, band=0
Apr 24 15:28:45 NCI: slot=0 mode=1 chanCnt=36 cw=255
Apr 24 15:28:45 NCI: Squashed Channel List:
Apr 24 15:28:45 NCI: chans: 1 2 3 4 5 6 7 8 9 10 11
Apr 24 15:28:45 NCI: 36 40 44 48 52 56 60 64 100 104 108
Apr 24 15:28:45 NCI: 112 116 120 124 128 132 136 140 144 149 153
Apr 24 15:28:45 NCI: 157 161 165
Apr 24 15:28:45 NCI: cf(MHz): 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462
Apr 24 15:28:45 NCI: 5180 5200 5220 5240 5260 5280 5300 5320 5500 5520 5540
Apr 24 15:28:45 NCI: 5560 5580 5600 5620 5640 5660 5680 5700 5720 5745 5765
Apr 24 15:28:45 NCI: 5785 5805 5825
Apr 24 15:28:45 NCI: I0: channel map channels: in=36 cloned=36
Apr 24 15:28:45 NCI: I0: Requesting MonBand [2400, 2482] bw=0MHz/0 ant=0xbc
Apr 24 15:28:45 NCI: I0: Monitoring (cf=2441, span=82), RadioUsage=5%
Apr 24 15:28:45 NCI: I0: dwell=25000us, update=3000ms, resBW=156251
Apr 24 15:28:45 NCI: I0: Requesting MonBand [5160, 5340] bw=0MHz/0 ant=0xbc
Apr 24 15:28:45 NCI: I0: Monitoring (cf=5250, span=180), RadioUsage=6%
Apr 24 15:28:45 NCI: I0: dwell=20000us, update=3000ms, resBW=156250
Apr 24 15:28:45 NCI: I0: Requesting MonBand [5480, 5845] bw=0MHz/0 ant=0xbc
Apr 24 15:28:45 NCI: I0: Monitoring (cf=5662, span=365), RadioUsage=12%
Apr 24 15:28:45 NCI: CLEANAIR: Slot 0 enabled
Apr 24 15:28:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:28:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:28:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:28:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] chatter: [RX]KEEPALIVE: Count 4984
Apr 24 15:28:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] Sending KEEPALIVE to WTP SM
Apr 24 15:28:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] Capwap data keep-alive Msg.
Apr 24 15:28:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:28:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [RX]KEEPALIVE: RoundTripTime=0.001 sec
Apr 24 15:28:49 NCI: CLEANAIR: Slot 1 channel change chk
Apr 24 15:29:02 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:29:11 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:29:14 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:29:14 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:29:14 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:29:14 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] chatter: [RX]KEEPALIVE: Count 4985
Apr 24 15:29:14 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Sending KEEPALIVE to WTP SM
Apr 24 15:29:14 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Capwap data keep-alive Msg.
Apr 24 15:29:14 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:29:14 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [RX]KEEPALIVE: RoundTripTime=0.002 sec
Apr 24 15:29:25 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] CAC_EXPIRY_EVT: CAC finished on DFS channel 64u
Apr 24 15:29:29 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:29:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] CAC_EXPIRY_EVT: CAC finished on DFS channel 124l
Apr 24 15:29:33 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:29:43 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:29:43 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:29:43 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:29:43 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] chatter: [RX]KEEPALIVE: Count 4986
Apr 24 15:29:43 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] Sending KEEPALIVE to WTP SM
Apr 24 15:29:43 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] Capwap data keep-alive Msg.
Apr 24 15:29:43 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:29:43 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] [RX]KEEPALIVE: RoundTripTime=0.003 sec
Apr 24 15:29:49 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:29:54 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:30:09 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:30:11 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:30:11 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:30:11 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:30:11 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] chatter: [RX]KEEPALIVE: Count 4987
Apr 24 15:30:11 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] Sending KEEPALIVE to WTP SM
Apr 24 15:30:11 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] Capwap data keep-alive Msg.
Apr 24 15:30:11 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:30:11 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [RX]KEEPALIVE: RoundTripTime=0.002 sec
Apr 24 15:30:39 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:30:40 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:30:40 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:30:40 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:30:40 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] chatter: [RX]KEEPALIVE: Count 4988
Apr 24 15:30:40 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] Sending KEEPALIVE to WTP SM
Apr 24 15:30:40 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] Capwap data keep-alive Msg.
Apr 24 15:30:40 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:30:40 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [RX]KEEPALIVE: RoundTripTime=0.003 sec
Apr 24 15:30:42 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:31:08 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:31:08 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:31:08 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:31:08 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] chatter: [RX]KEEPALIVE: Count 4989
Apr 24 15:31:08 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] Sending KEEPALIVE to WTP SM
Apr 24 15:31:08 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] Capwap data keep-alive Msg.
Apr 24 15:31:08 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:31:08 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [RX]KEEPALIVE: RoundTripTime=0.003 sec
Apr 24 15:31:36 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:31:37 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:31:37 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:31:37 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:31:37 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] chatter: [RX]KEEPALIVE: Count 4990
Apr 24 15:31:37 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Sending KEEPALIVE to WTP SM
Apr 24 15:31:37 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Capwap data keep-alive Msg.
Apr 24 15:31:37 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:31:37 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [RX]KEEPALIVE: RoundTripTime=0.003 sec
Apr 24 15:31:39 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:31:49 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:32:01 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:32:05 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:32:05 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:32:05 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:32:05 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] chatter: [RX]KEEPALIVE: Count 4991
Apr 24 15:32:05 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] Sending KEEPALIVE to WTP SM
Apr 24 15:32:05 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] Capwap data keep-alive Msg.
Apr 24 15:32:05 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:32:05 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [RX]KEEPALIVE: RoundTripTime=0.019 sec
Apr 24 15:32:07 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:32:30 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:32:34 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:32:34 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:32:34 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:32:34 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] chatter: [RX]KEEPALIVE: Count 4992
Apr 24 15:32:34 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] Sending KEEPALIVE to WTP SM
Apr 24 15:32:34 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] Capwap data keep-alive Msg.
Apr 24 15:32:34 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:32:34 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] [RX]KEEPALIVE: RoundTripTime=0.001 sec
Apr 24 15:32:56 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:33:01 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:33:02 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] Echo Request: Send count 0
Apr 24 15:33:02 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] [TX]Echo Request: Sent to XXX.XXX.XXX.XXX
Apr 24 15:33:02 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:33:02 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:33:02 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:33:02 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] chatter: [RX]KEEPALIVE: Count 4993
Apr 24 15:33:02 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] Sending KEEPALIVE to WTP SM
Apr 24 15:33:02 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] Capwap data keep-alive Msg.
Apr 24 15:33:02 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:33:02 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] [RX]KEEPALIVE: RoundTripTime=0.002 sec
Apr 24 15:33:02 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] [RX]Echo Response from XXX.XXX.XXX.XXX
Apr 24 15:33:02 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] [RX]Echo Response from XXX.XXX.XXX.XXX RttCount 1
Apr 24 15:33:08 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:33:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:33:20 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:33:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:33:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:33:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:33:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] chatter: [RX]KEEPALIVE: Count 4994
Apr 24 15:33:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] Sending KEEPALIVE to WTP SM
Apr 24 15:33:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] Capwap data keep-alive Msg.
Apr 24 15:33:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:33:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] [RX]KEEPALIVE: RoundTripTime=0.020 sec
Apr 24 15:33:40 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:33:40 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:33:59 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:33:59 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:33:59 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:33:59 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] chatter: [RX]KEEPALIVE: Count 4995
Apr 24 15:33:59 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] Sending KEEPALIVE to WTP SM
Apr 24 15:33:59 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] Capwap data keep-alive Msg.
Apr 24 15:33:59 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:33:59 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [RX]KEEPALIVE: RoundTripTime=0.003 sec
Apr 24 15:34:22 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:34:28 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:34:28 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:34:28 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:34:28 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] chatter: [RX]KEEPALIVE: Count 4996
Apr 24 15:34:28 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] Sending KEEPALIVE to WTP SM
Apr 24 15:34:28 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] Capwap data keep-alive Msg.
Apr 24 15:34:28 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:34:28 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [RX]KEEPALIVE: RoundTripTime=0.002 sec
Apr 24 11:34:33 sshd[8571]: error: Could not get shadow information for admin
Apr 24 11:34:33 sshd[8571]: Accepted password for admin from XXX.XXX.XXX.XXX port 56360 ssh2
Apr 24 15:34:34 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:34:39 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:34:56 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:34:56 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:34:56 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:34:56 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] chatter: [RX]KEEPALIVE: Count 4997
Apr 24 15:34:56 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] Sending KEEPALIVE to WTP SM
Apr 24 15:34:56 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] Capwap data keep-alive Msg.
Apr 24 15:34:56 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:34:56 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] [RX]KEEPALIVE: RoundTripTime=0.002 sec
Apr 24 15:34:57 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:35:25 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:35:25 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:35:25 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:35:25 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] chatter: [RX]KEEPALIVE: Count 4998
Apr 24 15:35:25 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] Sending KEEPALIVE to WTP SM
Apr 24 15:35:25 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] Capwap data keep-alive Msg.
Apr 24 15:35:25 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:35:25 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [RX]KEEPALIVE: RoundTripTime=0.003 sec
Apr 24 15:35:44 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:35:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:35:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:35:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:35:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] chatter: [RX]KEEPALIVE: Count 4999
Apr 24 15:35:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] Sending KEEPALIVE to WTP SM
Apr 24 15:35:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] Capwap data keep-alive Msg.
Apr 24 15:35:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:35:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [RX]KEEPALIVE: RoundTripTime=0.002 sec
Apr 24 15:35:54 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:35:58 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:36:00 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:36:09 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 11:36:18 sshd[9330]: error: Could not get shadow information for admin
Apr 24 11:36:18 sshd[9330]: Accepted password for admin from XXX.XXX.XXX.XXX port 56432 ssh2
Apr 24 15:36:22 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:36:22 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:36:22 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] Re-Tx Count=1, Max Re-Tx Value=8, SendSeqNum=123, NumofPendingMsgs=3
Apr 24 15:36:22 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:36:23 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:36:25 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:36:25 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [TX]KEEPALIVE: Schedule for Retransmit in 6 sec sec_drop_count=0
Apr 24 15:36:25 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:36:26 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] Echo Request: Send count 1
Apr 24 15:36:26 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [TX]Echo Request: Sent 2 Lost 42
Apr 24 15:36:30 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:36:30 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [TX]KEEPALIVE: Schedule for Retransmit in 12 sec sec_drop_count=0
Apr 24 15:36:30 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:36:30 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] chatter: [RX]KEEPALIVE: Count 5000
Apr 24 15:36:30 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] Sending KEEPALIVE to WTP SM
Apr 24 15:36:30 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] Capwap data keep-alive Msg.
Apr 24 15:36:30 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:36:30 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [RX]KEEPALIVE: RoundTripTime=0.001 sec
Apr 24 15:36:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] Re-Tx Count=2, Max Re-Tx Value=8, SendSeqNum=128, NumofPendingMsgs=7
Apr 24 15:36:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [RX]Echo Response from XXX.XXX.XXX.XXX
Apr 24 15:36:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [RX]Echo Response from XXX.XXX.XXX.XXX RttCount 1
Apr 24 15:36:32 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:36:55 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:36:59 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:36:59 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:36:59 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:36:59 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] chatter: [RX]KEEPALIVE: Count 5001
Apr 24 15:36:59 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Sending KEEPALIVE to WTP SM
Apr 24 15:36:59 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Capwap data keep-alive Msg.
Apr 24 15:36:59 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:36:59 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [RX]KEEPALIVE: RoundTripTime=0.001 sec
Apr 24 15:37:27 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:37:27 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:37:27 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:37:27 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] chatter: [RX]KEEPALIVE: Count 5002
Apr 24 15:37:27 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] Sending KEEPALIVE to WTP SM
Apr 24 15:37:27 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] Capwap data keep-alive Msg.
Apr 24 15:37:27 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:37:27 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] [RX]KEEPALIVE: RoundTripTime=0.001 sec
Apr 24 15:37:39 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:37:40 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:37:43 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:37:56 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:37:56 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:37:56 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:37:56 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] chatter: [RX]KEEPALIVE: Count 5003
Apr 24 15:37:56 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] Sending KEEPALIVE to WTP SM
Apr 24 15:37:56 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] Capwap data keep-alive Msg.
Apr 24 15:37:56 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:37:56 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [RX]KEEPALIVE: RoundTripTime=0.002 sec
Apr 24 15:38:24 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:38:24 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:38:24 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:38:24 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] chatter: [RX]KEEPALIVE: Count 5004
Apr 24 15:38:24 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] Sending KEEPALIVE to WTP SM
Apr 24 15:38:24 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] Capwap data keep-alive Msg.
Apr 24 15:38:24 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:38:24 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [RX]KEEPALIVE: RoundTripTime=0.001 sec
Apr 24 15:38:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:38:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:38:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:38:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] chatter: [RX]KEEPALIVE: Count 5005
Apr 24 15:38:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] Sending KEEPALIVE to WTP SM
Apr 24 15:38:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] Capwap data keep-alive Msg.
Apr 24 15:38:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:38:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [RX]KEEPALIVE: RoundTripTime=0.002 sec
Apr 24 15:39:08 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:39:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:39:21 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:39:21 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:39:21 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:39:21 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] chatter: [RX]KEEPALIVE: Count 5006
Apr 24 15:39:21 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] Sending KEEPALIVE to WTP SM
Apr 24 15:39:21 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] Capwap data keep-alive Msg.
Apr 24 15:39:21 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:39:21 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [RX]KEEPALIVE: RoundTripTime=0.001 sec
Apr 24 15:39:50 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:39:50 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:39:50 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:39:50 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] chatter: [RX]KEEPALIVE: Count 5007
Apr 24 15:39:50 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] Sending KEEPALIVE to WTP SM
Apr 24 15:39:50 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] Capwap data keep-alive Msg.
Apr 24 15:39:50 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:39:50 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [RX]KEEPALIVE: RoundTripTime=0.001 sec
Apr 24 15:40:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:40:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:40:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:40:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] chatter: [RX]KEEPALIVE: Count 5008
Apr 24 15:40:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] Sending KEEPALIVE to WTP SM
Apr 24 15:40:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] Capwap data keep-alive Msg.
Apr 24 15:40:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:40:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] [RX]KEEPALIVE: RoundTripTime=0.001 sec
Apr 24 15:40:39 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:40:47 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:40:47 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:40:47 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:40:47 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] chatter: [RX]KEEPALIVE: Count 5009
Apr 24 15:40:47 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] Sending KEEPALIVE to WTP SM
Apr 24 15:40:47 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] Capwap data keep-alive Msg.
Apr 24 15:40:47 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:40:47 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] [RX]KEEPALIVE: RoundTripTime=0.001 sec
Apr 24 11:41:00 sshd[8571]: syslogin_perform_logout: logout() returned an error
Apr 24 15:41:11 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] Echo Request: Send count 2
Apr 24 15:41:11 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [TX]Echo Request: Sent to XXX.XXX.XXX.XXX
Apr 24 15:41:11 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [RX]Echo Response from XXX.XXX.XXX.XXX
Apr 24 15:41:11 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [RX]Echo Response from XXX.XXX.XXX.XXX RttCount 1
Apr 24 15:41:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:41:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:41:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:41:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] chatter: [RX]KEEPALIVE: Count 5010
Apr 24 15:41:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] Sending KEEPALIVE to WTP SM
Apr 24 15:41:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] Capwap data keep-alive Msg.
Apr 24 15:41:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:41:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] [RX]KEEPALIVE: RoundTripTime=0.001 sec
Apr 24 15:41:28 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:41:44 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:41:44 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:41:44 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:41:44 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] chatter: [RX]KEEPALIVE: Count 5011
Apr 24 15:41:44 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] Sending KEEPALIVE to WTP SM
Apr 24 15:41:44 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] Capwap data keep-alive Msg.
Apr 24 15:41:44 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:41:44 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [RX]KEEPALIVE: RoundTripTime=0.001 sec
Apr 24 15:42:00 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:42:09 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:42:12 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:42:12 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:42:12 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:42:12 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] chatter: [RX]KEEPALIVE: Count 5012
Apr 24 15:42:12 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Sending KEEPALIVE to WTP SM
Apr 24 15:42:12 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Capwap data keep-alive Msg.
Apr 24 15:42:12 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:42:12 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [RX]KEEPALIVE: RoundTripTime=0.002 sec
Apr 24 15:42:26 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:42:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Starting ntp file watcher...
Apr 24 11:42:31 ntp_update: NTP: Wed Apr 24 11:42:31 2024 :Can not create ntp process log file.
Apr 24 15:42:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] Update NTP source to WLC
Apr 24 15:42:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Starting ntp watcher...
Apr 24 15:42:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Started ntp file watcher.
Apr 24 15:42:31 ntpd[9981]: ntpd exiting on signal 15 (Terminated)
Apr 24 15:42:31 ntpd[9981]: XXX.XXX.XXX.XXX local addr XXX.XXX.XXX.XXX -> <null>
Apr 24 15:42:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Stopping NTPD daemon...
Apr 24 15:42:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Stopped NTPD daemon.
Apr 24 15:42:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Started ntp watcher.
Apr 24 15:42:32 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Starting ntp watcher...
Apr 24 15:42:32 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Starting NTPD daemon...
Apr 24 11:42:32 ntpd[12111]: ntpd 4.2.XXX.XXX.XXX.XXX8-o Thu Jan 25 12:14:13 UTC 2024 (1): Starting
Apr 24 11:42:32 ntpd[12111]: Command line: /sbin/ntpd
Apr 24 11:42:32 ntpd[12111]: ----------------------------------------------------
Apr 24 11:42:32 ntpd[12111]: ntp-4 is maintained by Network Time Foundation,
Apr 24 11:42:32 ntpd[12111]: Inc. (NTF), a non-profit 501(c)(3) public-benefit
Apr 24 11:42:32 ntpd[12111]: corporation. Support and training for ntp-4 are
Apr 24 11:42:32 ntpd[12111]: available at https://www.nwtime.org/support
Apr 24 11:42:32 ntpd[12113]: proto: precision = 0.220 usec (-22)
Apr 24 11:42:32 ntpd[12113]: basedate set to 2024-01-13
Apr 24 11:42:32 ntpd[12113]: gps base set to 2024-01-14 (week 2297)
Apr 24 11:42:32 ntpd[12113]: Listen and drop on 0 v6wildcard [::]:123
Apr 24 11:42:32 ntpd[12113]: Listen and drop on 1 v4wildcard XXX.XXX.XXX.XXX:123
Apr 24 11:42:32 ntpd[12113]: Listen normally on 2 lo XXX.XXX.XXX.XXX:123
Apr 24 11:42:32 ntpd[12113]: Listen normally on 3 srcrXXX.XXX.XXX.XXX.1:123
Apr 24 11:42:32 ntpd[12113]: Listen normally on 4 lo [::1]:123
Apr 24 11:42:32 ntpd[12113]: Listen normally on 5 srcr2 [fe80::c86c:1416:9ed2:e75e%61]:123
Apr 24 11:42:32 ntpd[12113]: Listening on routing socket on fd #22 for interface updates
Apr 24 11:42:32 ntpd[12113]: kernel reports TIME_ERROR: 0x2041: Clock Unsynchronized
Apr 24 15:42:32 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Started NTPD daemon.
Apr 24 15:42:32 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Started ntp watcher.
Apr 24 15:42:41 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:42:41 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:42:41 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:42:41 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] chatter: [RX]KEEPALIVE: Count 5013
Apr 24 15:42:41 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] Sending KEEPALIVE to WTP SM
Apr 24 15:42:41 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] Capwap data keep-alive Msg.
Apr 24 15:42:41 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:42:41 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [RX]KEEPALIVE: RoundTripTime=0.001 sec
Apr 24 15:42:58 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:43:09 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:43:09 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:43:09 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:43:09 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] chatter: [RX]KEEPALIVE: Count 5014
Apr 24 15:43:09 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] Sending KEEPALIVE to WTP SM
Apr 24 15:43:09 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] Capwap data keep-alive Msg.
Apr 24 15:43:09 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:43:09 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] [RX]KEEPALIVE: RoundTripTime=0.002 sec
Apr 24 11:43:11 sshd[9330]: syslogin_perform_logout: logout() returned an error
Apr 24 15:43:23 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:43:37 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:43:38 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:43:38 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:43:38 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:43:38 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] chatter: [RX]KEEPALIVE: Count 5015
Apr 24 15:43:38 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] Sending KEEPALIVE to WTP SM
Apr 24 15:43:38 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] Capwap data keep-alive Msg.
Apr 24 15:43:38 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:43:38 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] [RX]KEEPALIVE: RoundTripTime=0.001 sec
Apr 24 15:43:40 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:43:55 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:44:01 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:44:06 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:44:06 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:44:06 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:44:06 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] chatter: [RX]KEEPALIVE: Count 5016
Apr 24 15:44:06 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] Sending KEEPALIVE to WTP SM
Apr 24 15:44:06 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] Capwap data keep-alive Msg.
Apr 24 15:44:06 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:44:06 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [RX]KEEPALIVE: RoundTripTime=0.001 sec
Apr 24 11:44:17 sshd[12777]: error: Could not get shadow information for admin
Apr 24 11:44:17 sshd[12777]: Accepted password for admin from XXX.XXX.XXX.XXX port 57100 ssh2
Apr 24 15:44:20 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:44:27 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:44:35 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:44:35 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:44:35 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:44:35 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] chatter: [RX]KEEPALIVE: Count 5017
Apr 24 15:44:35 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] Sending KEEPALIVE to WTP SM
Apr 24 15:44:35 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] Capwap data keep-alive Msg.
Apr 24 15:44:35 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:44:35 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] [RX]KEEPALIVE: RoundTripTime=0.001 sec
Apr 24 15:44:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:44:50 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:45:03 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:45:03 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:45:03 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:45:06 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:45:06 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:45:06 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] [TX]KEEPALIVE: Schedule for Retransmit in 6 sec sec_drop_count=0
Apr 24 15:45:10 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:45:12 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:45:12 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] [TX]KEEPALIVE: Schedule for Retransmit in 12 sec sec_drop_count=0
Apr 24 15:45:12 kernel: [*04/24/2024 XXX.XXX.XXX.XXX9] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:45:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX0] Re-Tx Count=1, Max Re-Tx Value=8, SendSeqNum=238, NumofPendingMsgs=5
Apr 24 15:45:23 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] Re-Tx Count=2, Max Re-Tx Value=8, SendSeqNum=238, NumofPendingMsgs=5
Apr 24 15:45:23 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:45:23 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] [TX]KEEPALIVE: Schedule for Retransmit in 12 sec sec_drop_count=0
Apr 24 15:45:23 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:45:28 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] Re-Tx Count=3, Max Re-Tx Value=8, SendSeqNum=242, NumofPendingMsgs=9
Apr 24 15:45:28 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] Echo Request: Send count 3
Apr 24 15:45:28 kernel: [*04/24/2024 XXX.XXX.XXX.XXX1] [TX]Echo Request: Sent 4 Lost 42
Apr 24 15:45:33 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] Re-Tx Count=4, Max Re-Tx Value=8, SendSeqNum=244, NumofPendingMsgs=10
Apr 24 15:45:35 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:45:35 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] [TX]KEEPALIVE: Schedule for Retransmit in 12 sec sec_drop_count=0
Apr 24 15:45:35 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:45:38 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] Re-Tx Count=5, Max Re-Tx Value=8, SendSeqNum=244, NumofPendingMsgs=10
Apr 24 15:45:42 kernel: [*04/24/2024 XXX.XXX.XXX.XXX2] Re-Tx Count=6, Max Re-Tx Value=8, SendSeqNum=244, NumofPendingMsgs=10
Apr 24 15:45:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:45:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [TX]KEEPALIVE: Schedule for Retransmit in 12 sec sec_drop_count=0
Apr 24 15:45:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:45:47 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] Re-Tx Count=7, Max Re-Tx Value=8, SendSeqNum=244, NumofPendingMsgs=10
Apr 24 15:45:52 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] Re-Tx Count=8, Max Re-Tx Value=8, SendSeqNum=245, NumofPendingMsgs=11
Apr 24 15:45:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 11:45:54 sshd[13486]: error: Could not get shadow information for admin
Apr 24 11:45:54 sshd[13486]: Accepted password for admin from XXX.XXX.XXX.XXX port 57450 ssh2
Apr 24 15:45:57 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] Echo Request: Send count 4
Apr 24 15:45:57 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [TX]Echo Request: Sent 5 Lost 43
Apr 24 15:45:58 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:45:58 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] [TX]KEEPALIVE: Schedule for Retransmit in 12 sec sec_drop_count=0
Apr 24 15:45:58 kernel: [*04/24/2024 XXX.XXX.XXX.XXX3] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:46:00 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Warning, unencrypted data keepalive failed
Apr 24 15:46:00 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Going to restart CAPWAP (reason : data keepalive not received)...
Apr 24 15:46:00 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Restarting CAPWAP State Machine.
Apr 24 15:46:00 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] OOBImageDnld: OOBImageDownloadTimer expired for image download..
Apr 24 15:46:00 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] OOBImageDnld: Do common error handler for OOB image download..
Apr 24 15:46:00 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] systemd[1]: Starting dhcpv6 client watcher...
Apr 24 15:46:00 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Flexconnect Switching to Standalone Mode!
Apr 24 15:46:00 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] systemd[1]: Stopping DHCPv6 client...
Apr 24 15:46:00 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] systemd[1]: Starting DHCPv6 client...
Apr 24 15:46:00 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] DOT11_DRV[0]: DFS CAC timer enabled time 60
Apr 24 15:46:01 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] systemd[1]: Started DHCPv6 client.
Apr 24 15:46:01 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] DOT11_DRV[0]: DFS CAC timer enabled time 60
Apr 24 15:46:01 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] systemd[1]: Started dhcpv6 client watcher.
Apr 24 15:46:01 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] DOT11_DRV[1]: DFS CAC timer enabled time 60
Apr 24 15:46:01 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] OOBImageDnld: OOBImageDownloadTimer expired for image download..
Apr 24 15:46:01 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] OOBImageDnld: Do common error handler for OOB image download..
Apr 24 15:46:01 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] CAPWAP State: DTLS Teardown
Apr 24 15:46:01 NCI: CLEANAIR: Slot 0 CAPWAP down
Apr 24 15:46:01 NCI: I0: shutdownNci
Apr 24 15:46:01 NCI: CLEANAIR: Slot 1 CAPWAP down
Apr 24 11:46:01 upgrade: Script called with args:[CANCEL]
Apr 24 15:46:01 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] status 'upgrade.sh: Script called with args:[CANCEL]'
Apr 24 15:46:01 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] do CANCEL, part1 is active part
Apr 24 11:46:01 upgrade: Cleanup tmp files ...
Apr 24 15:46:01 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] status 'upgrade.sh: Cleanup tmp files ...'
Apr 24 15:46:06 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] OOBImageDnld: OOBImageDownloadTimer expired for image download..
Apr 24 15:46:06 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] OOBImageDnld: Do common error handler for OOB image download..
Apr 24 15:46:06 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] dtls_queue_first: Nothing to extract!
Apr 24 15:46:07 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] ipv6 gw config loop in Ac discovery
Apr 24 15:46:09 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] ipv6 gw config loop in Ac discovery
Apr 24 15:46:11 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] ipv6 gw config loop in Ac discovery
Apr 24 15:46:13 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] ipv6 gw config loop in Ac discovery
Apr 24 15:46:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] ipv6 gw config loop in Ac discovery
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] systemd[1]: Starting dhcpv6 client watcher...
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] systemd[1]: Stopping DHCPv6 client...
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] systemd[1]: Starting DHCPv6 client...
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Discovery Response from XXX.XXX.XXX.XXX
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Found Configured MWAR 'lslromi-wlc-01' (respIdx 0).
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Started wait dtls timer (60 sec)
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] CAPWAP State: DTLS Setup
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Invalid event 2 & state 3 combination.
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] CAPWAP SM handler: Failed to process message type 2 state 3.
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Failed to handle capwap control message from controller - status 1
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Failed to process unencrypted capwap packet 0x55a8c6b000 from XXX.XXX.XXX.XXX
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Failed to send message to CAPWAP state machine, msgId 0
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Failed to send capwap message 0 to the state machine. Packet already freed.
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] IPv4 wtpProcessPacketFromSocket returned 1
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Failed to process unencrypted capwap packet 0x55a8c77000 from XXX.XXX.XXX.XXX
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Failed to process unencrypted capwap packet 0x55a8f0e000 from XXX.XXX.XXX.XXX
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Failed to process unencrypted capwap packet 0x55a8f4c000 from XXX.XXX.XXX.XXX
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Failed to process unencrypted capwap packet 0x55a8c0c000 from XXX.XXX.XXX.XXX
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] systemd[1]: Started DHCPv6 client.
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] systemd[1]: Started dhcpv6 client watcher.
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] dtls_verify_server_cert: Controller certificate verification successful
Apr 24 15:46:16 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] CAPWAP State: Join
Apr 24 15:46:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] OOBImageDnld: OOB Image Download in ap_cap_bitmask(2)
Apr 24 15:46:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Sending Join request to XXX.XXX.XXX.XXX through port 5262, packet size 1376
Apr 24 15:46:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Join Response from XXX.XXX.XXX.XXX, packet size 1397
Apr 24 15:46:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] AC accepted previous sent request with result code: 0
Apr 24 15:46:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Received wlcType 0, timer 30
Apr 24 15:46:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] CAPWAP State: Image Data
Apr 24 15:46:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] AP image version XXX.XXX.XXX.XXX backup XXX.XXX.XXX.XXX, Controller XXX.XXX.XXX.XXX
Apr 24 15:46:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Version is the same, do not need update.
Apr 24 11:46:17 upgrade: Script called with args:[NO_UPGRADE]
Apr 24 15:46:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] status 'upgrade.sh: Script called with args:[NO_UPGRADE]'
Apr 24 15:46:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] do NO_UPGRADE, part1 is active part
Apr 24 15:46:17 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] CAPWAP State: Configure
Apr 24 11:46:17 capwapd[5967]: Check lagloadbalance setting flex_mode 1 cfg 0 linkstate 0 ap_type 86
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] CAPWAP State: Run
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] chatter: [RX]KEEPALIVE: Count 5018
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] AP has joined controller lslromi-wlc-01
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] wtpHandleImageSwapEwlcmeTimer: time=0
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Flexconnect Switching to Connected Mode!
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Sending KEEPALIVE to WTP SM
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Capwap data keep-alive Msg.
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] [RX]KEEPALIVE: RoundTripTime=0.107 sec
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Previous AP mode is 2, change to 2
Apr 24 11:46:18 capwapd[5967]: Check lagloadbalance setting flex_mode 1 cfg 0 linkstate 0 ap_type 86
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Current session mode: ssh, Configured: Telnet-No, SSH-Yes, Console-Yes
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Current session mode: telnet, Configured: Telnet-No, SSH-Yes, Console-Yes
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] Current session mode: console, Configured: Telnet-No, SSH-Yes, Console-Yes
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX4] chpasswd: password for user changed
Apr 24 11:46:18 chpasswd: password for user changed
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Starting Cisco syslogd watcher...
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] Same LSC mode, no action needed
Apr 24 11:46:18 syslogd exiting
Apr 24 11:46:18 syslogd started: BusyBox v1.32.1
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Started Cisco syslog service.
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Started Cisco syslogd watcher.
Apr 24 15:46:18 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] hostapd:radius_extended_config: radius_aaa_msg_timeout(0) radius_aaa_msg_max_retransmit(0)
Apr 24 15:46:19 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] Got WSA Server config TLVs
Apr 24 15:46:19 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] hostapd:radius_extended_config: radius_aaa_msg_timeout(5) radius_aaa_msg_max_retransmit(3)
Apr 24 15:46:19 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Starting Dcdsd Watcher...
Apr 24 15:46:19 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Stopping Dcdsd server...
Apr 24 11:46:19 dcdsd: DIGEST-MD5 common mech free
Apr 24 15:46:19 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] Memcached status changed from 255 to 1. Notify VRRP
Apr 24 15:46:19 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] Closing sockets, exiting DCDSd process
Apr 24 15:46:19 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Starting Dcdsd server...
Apr 24 15:46:19 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Started Dcdsd server.
Apr 24 15:46:19 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] systemd[1]: Started Dcdsd Watcher.
Apr 24 15:46:21 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5]
Apr 24 15:46:21 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] *** Unable to connect to: XXX.XXX.XXX.XXX:4040 - [Errno 111] Connection refused
Apr 24 15:46:23 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5]
Apr 24 15:46:23 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] *** Unable to connect to: XXX.XXX.XXX.XXX:4040 - [Errno 111] Connection refused
Apr 24 15:46:25 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5]
Apr 24 15:46:25 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] *** Unable to connect to: XXX.XXX.XXX.XXX:4040 - [Errno 111] Connection refused
Apr 24 15:46:27 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5]
Apr 24 15:46:27 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] *** Unable to connect to: XXX.XXX.XXX.XXX:4040 - [Errno 111] Connection refused
Apr 24 15:46:29 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5]
Apr 24 15:46:29 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] *** Unable to connect to: XXX.XXX.XXX.XXX:4040 - [Errno 111] Connection refused
Apr 24 15:46:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5]
Apr 24 15:46:31 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] *** Unable to connect to: XXX.XXX.XXX.XXX:4040 - [Errno 111] Connection refused
Apr 24 15:46:33 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5]
Apr 24 15:46:33 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] *** Unable to connect to: XXX.XXX.XXX.XXX:4040 - [Errno 111] Connection refused
Apr 24 15:46:33 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] In write handler 'add_cache_param_via_tlv' for 'pmk_tracker :: PMKTracker':
Apr 24 15:46:33 kernel: [*04/24/2024 XXX.XXX.XXX.XXX5] not a valid cache_type in add_cache_param_via_tlv
Apr 24 15:46:45 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] set cleanair [slot0][band0] enabled
Apr 24 15:46:45 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] set cleanair [slot0][band1] enabled
Apr 24 15:46:45 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] set cleanair [slot1][band1] enabled
Apr 24 15:46:45 NCI: I0: openSensor(slot=0)
Apr 24 11:46:45 eeprom_api[5130]: cfg loopback only mode 0
Apr 24 15:46:46 NCI: I0: SensorApp=5325626c
Apr 24 15:46:46 NCI: I0: SensorHdw=1.5.3
Apr 24 15:46:46 NCI: I0: Hardware Radio Band = [4890, 5935] MHz, BW=75313, band=1
Apr 24 15:46:46 NCI: I0: Hardware Radio Band = [2400, 2500] MHz, BW=75313, band=0
Apr 24 15:46:46 NCI: slot=0 mode=1 chanCnt=36 cw=255
Apr 24 15:46:46 NCI: Squashed Channel List:
Apr 24 15:46:46 NCI: chans: 1 2 3 4 5 6 7 8 9 10 11
Apr 24 15:46:46 NCI: 36 40 44 48 52 56 60 64 100 104 108
Apr 24 15:46:46 NCI: 112 116 120 124 128 132 136 140 144 149 153
Apr 24 15:46:46 NCI: 157 161 165
Apr 24 15:46:46 NCI: cf(MHz): 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462
Apr 24 15:46:46 NCI: 5180 5200 5220 5240 5260 5280 5300 5320 5500 5520 5540
Apr 24 15:46:46 NCI: 5560 5580 5600 5620 5640 5660 5680 5700 5720 5745 5765
Apr 24 15:46:46 NCI: 5785 5805 5825
Apr 24 15:46:46 NCI: I0: channel map channels: in=36 cloned=36
Apr 24 15:46:46 NCI: I0: Requesting MonBand [2400, 2482] bw=0MHz/0 ant=0xbc
Apr 24 15:46:46 NCI: I0: Monitoring (cf=2441, span=82), RadioUsage=5%
Apr 24 15:46:46 NCI: I0: dwell=25000us, update=3000ms, resBW=156251
Apr 24 15:46:46 NCI: I0: Requesting MonBand [5160, 5340] bw=0MHz/0 ant=0xbc
Apr 24 15:46:46 NCI: I0: Monitoring (cf=5250, span=180), RadioUsage=6%
Apr 24 15:46:46 NCI: I0: dwell=20000us, update=3000ms, resBW=156250
Apr 24 15:46:46 NCI: I0: Requesting MonBand [5480, 5845] bw=0MHz/0 ant=0xbc
Apr 24 15:46:46 NCI: I0: Monitoring (cf=5662, span=365), RadioUsage=12%
Apr 24 15:46:46 NCI: CLEANAIR: Slot 0 enabled
Apr 24 15:46:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:46:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:46:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:46:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] chatter: [RX]KEEPALIVE: Count 5019
Apr 24 15:46:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] Sending KEEPALIVE to WTP SM
Apr 24 15:46:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] Capwap data keep-alive Msg.
Apr 24 15:46:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:46:46 kernel: [*04/24/2024 XXX.XXX.XXX.XXX6] [RX]KEEPALIVE: RoundTripTime=0.001 sec
Apr 24 15:46:50 NCI: CLEANAIR: Slot 1 channel change chk
Apr 24 15:46:53 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:47:00 kernel: [*04/24/2024 XXX.XXX.XXX.XXX7] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:47:02 kernel: [04/24/2024 XXX.XXX.XXX.XXX7] audit: audit_lost=264 audit_rate_limit=100 audit_backlog_limit=8192
Apr 24 15:47:02 kernel: [04/24/2024 XXX.XXX.XXX.XXX7] audit: rate limit exceeded
Apr 24 15:47:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [TX]KEEPALIVE: Send to XXX.XXX.XXX.XXX-5247
Apr 24 15:47:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [TX]KEEPALIVE: Schedule for Retransmit in 3 sec sec_drop_count=0
Apr 24 15:47:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] capwap_ap_upstream_send ip: XXX.XXX.XXX.XXX, port: 5262 => ip: XXX.XXX.XXX.XXX, port: 5247
Apr 24 15:47:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] chatter: [RX]KEEPALIVE: Count 5020
Apr 24 15:47:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] Sending KEEPALIVE to WTP SM
Apr 24 15:47:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] Capwap data keep-alive Msg.
Apr 24 15:47:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [RX]KEEPALIVE: Session ID 1623363519, Next scheduled for TX in 30 sec
Apr 24 15:47:15 kernel: [*04/24/2024 XXX.XXX.XXX.XXX8] [RX]KEEPALIVE: RoundTripTime=0.020 sec
         - FYI :  https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwf66673
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
