AP issue
frederick.mercado
Hello we have a local 9120axi AP with a 9800LC WLC that seems to be losing connection. The AP is in flex connect, all config looks fine:
Advanced
Country Code
US
Multiple Countries
US
Statistics Timer
180
CAPWAP MTU
1485
AP Link Latency
Enabled
AP PMK Propagation Capability
Enabled
TCP Adjust MSS Option
AP TCP MSS Adjust
Enabled
AP TCP MSS Size
1250
AP IPv6 TCP MSS Adjust
Enabled
AP IPv6 TCP MSS Size
1250
AP Retransmit Config Parameters
AP Retransmit Count
8
AP Retransmit Interval
Version
Primary Software Version
17.9.3.50
Predownloaded Status
N/A
Predownloaded Version
N/A
Next Retry Time
N/A
Boot Version
1.1.2.4
IOS Version
17.9.3.50
Mini IOS Version
0.0.0.0
Time Statistics
Up Time
191 days 23 hrs 8 mins 37 secs
Controller Association Latency
25 secs
Is the AP currently connected to controller
JOINED
Time at which the AP joined this controller last time
04/22/2024 11:35:11
Type of error that occurred last
Run
Time at which the last join error occurred
04/22/2024 11:34:21
Last AP Disconnect Details
Reason for last AP connection failure
Max Retransmission to AP
Last Reboot Reason (Reported by AP)
No reboot reason
Control DTLS Statistics
DTLS Session request received
2983
Established DTLS session
2977
Unsuccessful DTLS session
6
Reason for last unsuccessful DTLS session
DTLS Handshake Certificate Authentication Failed
Time at last successful DTLS session
04/22/2024 11:35:07
Time at last unsuccessful DTLS session
03/22/2024 20:11:21
Join phase statistics
Join requests received
2979
Successful join responses sent
2977
Unsuccessful join request processing
Reason for last unsuccessful join attempt
NA
Time at last successful join attempt
04/22/2024 11:35:11
Time at last unsuccessful join attempt
02/29/2024 00:35:29
Configuration phase statistics
Configuration requests received
8931
Successful configuration responses sent
8931
Unsuccessful configuration request processing
Reason for last unsuccessful configuration attempt
NA
Time at last successful configuration attempt
04/22/2024 11:35:12
Time at last unsuccessful configuration attempt
NA
Data DTLS Statistics
DTLS Handshake Success
NA
NA
No ICMP drops from concurrent ping. No other reported issues on the 9300 Switch or other APs. There were some loss of connectivity for users at 0834 hrs and 1051 hrs.
Closest thing I ran into was this error in the radioactive tace: "AP disconnect initiated. Reason: Max Retransmission to AP, Phase: Run"
22 Replies 22
Cosmetic - but looks at NTP...tried reloading AP - will do a full power on/off as you indicated on port now.
Tried clearing the config and reset to factory defaults trough WLC...still get these errors:
Apr 24 16:33:21 ntpd[10853]: kernel reports TIME_ERROR: 0x41: Clock Unsynchronized
Apr 24 16:27:43 capwapd[5995]: failed writing /click/pmk_tracker/add_cache_param_via_tlv len 192 data: "MAC 00:00:00:00:00:00, ACL \"\", CACHE_..."
Apr 24 16:27:43 kernel: [*04/24/2024 12:27:43.5026] In write handler 'add_cache_param_via_tlv' for 'pmk_tracker :: PMKTracker':
Apr 24 16:27:43 kernel: [*04/24/2024 12:27:43.5026] not a valid cache_type in add_cache_param_via_tlv
Apr 24 16:27:43 kernel: [*04/24/2024 12:27:43.5026] !!!!! {/opt/cisco/bin/capwapd} failed writing /click/pmk_tracker/add_cache_param_via_tlv len 192 data: "MAC 00:00:00:00:00:00, ACL \"\", CACHE_..."
Apr 24 16:27:42 kernel: [*04/24/2024 12:27:42.8416] *** Unable to connect to: 127.0.0.1:4040 - [Errno 111] Connection refused
Apr 24 16:27:27 ntp_update: NTP: Wed Apr 24 16:27:27 2024 :Can not create ntp process log file.
Apr 24 16:27:27 ntpd[8355]: ntpd exiting on signal 15 (Terminated)
Apr 24 12:37:44 sshd[15551]: error: Could not get shadow information for admin
Mark Elsen
 - Have a checkup of the 9800LC WLC configuration with the CLI command show tech wireless and feed the output to : Wireless Config Analyzer
                                This is fundamental
   Further look at and or 'execute' : https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/218396-troubleshoot-catalyst-9800-ap-join-or-di.html
  You can also trouble shoot with commands from : https://logadvisor.cisco.com/logadvisor/wireless/9800/9800APJoin
  And use these commands to check if you are making progress : https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/217738-monitor-catalyst-9800-kpis-key-performa.html#anc4
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Checked config - nothing out of the ordinary.
I noticed quite a few bugs in the 17.9.3 version - so we will schedule a upgrade this evening to 9.5.
Leo Laohoo
@frederick.mercado
If the controller is on 17.9.4/17.9.4a or 17.9.5, I would strong recommend downgrading to 17.6.6 or upgrading to 17.12.3.  My reasons can be found HERE.
Console into one of the problematic AP.  Is it complaining about "Max retransmission count exceeded, going back to DISCOVER mode."  If it is, then this is CSCwh61011.
Gaurav  Kansal
Level 5
Level 5
Dear Frederick,
It seems you are hitting a bug CSCwe04602. This bug is reported in your version 17.9.3.50. Please go through this bug and if this relates your issue as it looks like you mentioned in your summary, then please go through with known fixed release mentioned by cisco.
Please vote helpful if you find this working.
Good Luck..
This is not in relation to us. We do not run SDA Fabric. Furthermore, this is just one AP. We have opened a RMA for the AP.
We have same problem with 9130 and error
kernel: [*08/29/2024 18:19:46.9273] !!!!! {/opt/cisco/bin/capwapd} failed writing /click/pmk_tracker/add_cache_param_via_tlv len 192 data
Version 17.9.5.201
