AP Join Error "Timed out while waiting for ECHO repsonse from the AP" Ver 7.4.100
Freemen
I got number of AP showing the error message of " Timed out while waiting for ECHO repsonse from the AP" from WLC version 7.4.100,
I checked the POE switch is no power flappiing, checked the connectivity between AP and WLC seam ok...
My issue is client randomly cannot get DHCP on a WPA2 SSID, what we do is remove the AP and join back.
Please advice any tShoot Step I can perform?
(Cisco Controller) >show ap join stats detailed 7c:ad:74:50:3c:c9
Sync phase statistics
- Time at sync request received............................ Not applicable
- Time at sync completed................................... Not applicable
Discovery phase statistics
- Discovery requests received.............................. 20
- Successful discovery responses sent...................... 20
- Unsuccessful discovery request processing................ 0
- Reason for last unsuccessful discovery attempt........... Not applicable
- Time at last successful discovery attempt................ Apr 13 12:32:48.347
- Time at last unsuccessful discovery attempt.............. Not applicable
Join phase statistics
- Join requests received................................... 9
- Successful join responses sent........................... 9
- Unsuccessful join request processing..................... 0
- Reason for last unsuccessful join attempt................ Not applicable
- Time at last successful join attempt..................... Apr 13 12:32:59.088
- Time at last unsuccessful join attempt................... Not applicable
Configuration phase statistics
--More or (q)uit current module or <ctrl-z> to abort
- Configuration requests received.......................... 27
- Successful configuration responses sent.................. 9
- Unsuccessful configuration request processing............ 0
- Reason for last unsuccessful configuration attempt....... Not applicable
- Time at last successful configuration attempt............ Apr 13 12:32:59.343
- Time at last unsuccessful configuration attempt.......... Not applicable
Last AP message decryption failure details
- Reason for last message decryption failure............... Not applicable
Last AP disconnect details
- Reason for last AP connection failure.................... Timed out while waiting for ECHO repsonse from the AP
- Last AP disconnect reason................................ Unknown failure reason
Last join error summary
- Type of error that occurred last......................... AP got or has been disconnected
- Reason for error that occurred last...................... Timed out while waiting for ECHO repsonse from the AP
- Time at which the last join error occurred............... Mar 22 18:20:21.369
Ethernet Mac : 7c:ad:74:50:3c:c9  Ip Address : 10.0.10.110
10 Replies 10
George Stefanick
I see your capture there.. I have to wonder is all your clients having this issue at the same time ?
Have you tried a client debug on a client having issues ?
HI George,
When the client connected to SSID, cannot get DHCP.
is the "Timed out while waiting for ECHO repsonse from the AP" Normal?
as for the debug client, still waiting for issue reoccur
so this doesn't happen all the time just randomly meaning your client issue ?
is randomly, but notice when the issue happen, AP is still associated to Controller.
Hi ,
Any luck? i also have same issue. From few days, we affected with this problem. WLC 2504 and different kinds of APs.
always one AP disassociate with WLC. worked well before. and no licensing issues.
Disconnecting reason is : Max re transmission reached for AP
connection failure : timed out while waiting for echo response from the ap
any help?
thanks
Good luck
KB
Scott Fella
Check for a duplicate IP address.
-Scott
-Scott
HI Scott, Do you suspect AP IP address duplicated?
Anything is possible. I just want to rule this out.
-Scott
-Scott
FYI no duplicated IP address for AP segment. any info, or debug can help me isolate the issue?
Did you ever found the issue?
