AP Join issues for select APs
aeccles
Level 3
Level 3
I have an existing 5508 with about 400 APs that has been in place and working well for many years.  I am in the process of adding a few new APs and I've had a problem with joining some of them.  Out of about 20 APs, about 5 of them have problems joining... either they never join at all, or they take hours to join, but eventually fall off again.
APs are all 3802i (AIR-AP3802I-B-K9)
Controller is a 5508 (8.5.171.5)
Controller was rebooted 3 days ago
I confirmed my certificate is still good until July 13th, but even so I disabled NTP and backdated the controller just to check, and there was no change.
Any help would be desperately appreciated as I've been up against this for a few days now.!  THanks
Here's the output from one them that shows it repeatedly failing to connect, then after a while, being able to connect.  At the time I grabbed these logs, this AP and another were able to join, but the other 3 were still cyclin through the proceess
Username: [*07/06/2023 17:14:01.9628] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: DTLS Setup(3).
[*07/06/2023 17:14:20.0164] dtls_disconnect: ERROR shutting down dtls connection ...
[*07/06/2023 17:14:20.0166]
[*07/06/2023 17:14:20.0166] CAPWAP State: DTLS Teardown
[*07/06/2023 17:14:24.7681] No more AP manager addresses remain..
[*07/06/2023 17:14:24.7681] No valid AP manager found for controller 'WLC-Primary-Unit' (ip: 192.168.2.102)
[*07/06/2023 17:14:24.7682] Failed to join controller WLC-Primary-Unit.
[*07/06/2023 17:14:24.7682] Failed to join controller.
[*07/06/2023 17:14:24.8728] WTP IP address changed from 0.0.0.0 to 192.168.97.126, restart CAPWAP.
[*07/06/2023 17:14:24.8728] Lost connection to the controller, going to restart CAPWAP (reason : WTP IP address changed)...
[*07/06/2023 17:14:24.8729] Restarting CAPWAP State Machine.
[*07/06/2023 17:14:24.9771] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: DTLS Teardown(4).
[*07/06/2023 17:14:24.9780]
[*07/06/2023 17:14:24.9780] CAPWAP State: DTLS Teardown
[*07/06/2023 17:14:29.8146]
[*07/06/2023 17:14:29.8146] CAPWAP State: Discovery
[*07/06/2023 17:14:29.8153] Got WLC address 192.168.2.102 from DHCP.
[*07/06/2023 17:14:29.8153] IP DNS query for CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:14:29.8172] DNS resolved CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:14:29.8172] DNS discover IP addr: 192.168.2.102
[*07/06/2023 17:14:29.8188] Discovery Request sent to 192.168.2.102, discovery type DHCP(2)
[*07/06/2023 17:14:29.8206] Discovery Request sent to 192.168.2.102, discovery type DNS(3)
[*07/06/2023 17:14:29.8232] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/06/2023 17:14:39.4214]
[*07/06/2023 17:14:39.4214] CAPWAP State: Discovery
[*07/06/2023 17:14:39.4221] Got WLC address 192.168.2.102 from DHCP.
[*07/06/2023 17:14:39.4221] IP DNS query for CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:14:54.4367] DNS resolved CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:14:54.4368] DNS discover IP addr: 192.168.2.102
[*07/06/2023 17:14:54.4410] Discovery Request sent to 192.168.2.102, discovery type DHCP(2)
[*07/06/2023 17:14:54.4420] Discovery Request sent to 192.168.2.102, discovery type DNS(3)
[*07/06/2023 17:14:54.4431] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/06/2023 17:14:54.4432] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*07/06/2023 17:15:04.1291]
[*07/06/2023 17:15:04.1291] CAPWAP State: Discovery
[*07/06/2023 17:15:04.1298] Got WLC address 192.168.2.102 from DHCP.
[*07/06/2023 17:15:04.1298] IP DNS query for CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:15:19.1419] DNS resolved CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:15:19.1419] DNS discover IP addr: 192.168.2.102
[*07/06/2023 17:15:19.1443] Discovery Request sent to 192.168.2.102, discovery type DHCP(2)
[*07/06/2023 17:15:19.1454] Discovery Request sent to 192.168.2.102, discovery type DNS(3)
[*07/06/2023 17:15:19.1464] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/06/2023 17:15:28.8364]
[*07/06/2023 17:15:28.8364] CAPWAP State: Discovery
[*07/06/2023 17:15:28.8371] Got WLC address 192.168.2.102 from DHCP.
[*07/06/2023 17:15:28.8371] IP DNS query for CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:15:28.8388] DNS resolved CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:15:28.8388] DNS discover IP addr: 192.168.2.102
[*07/06/2023 17:15:28.8434] Discovery Request sent to 192.168.2.102, discovery type DHCP(2)
[*07/06/2023 17:15:28.8449] Discovery Request sent to 192.168.2.102, discovery type DNS(3)
[*07/06/2023 17:15:28.8470] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/06/2023 17:15:28.8474] Dropping dtls packet since session is not established. Peer 192.168.2.102-5246, Local 192.168.97.126-5272, conn (nil)
[*07/06/2023 17:15:28.8475] Discovery Response from 192.168.2.102
[*07/06/2023 17:15:28.8548] Discovery Response from 192.168.2.102
[*07/06/2023 17:15:33.7857] Dropping dtls packet since session is not established. Peer 192.168.2.102-5246, Local 192.168.97.126-5272, conn (nil)
[*07/06/2023 17:15:39.0000]
[*07/06/2023 17:15:39.0000] CAPWAP State: DTLS Setup
[*07/06/2023 17:15:44.0764] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: DTLS Setup(3).
[*07/06/2023 17:16:36.0162] dtls_disconnect: ERROR shutting down dtls connection ...
[*07/06/2023 17:16:36.0164]
[*07/06/2023 17:16:36.0164] CAPWAP State: DTLS Teardown
[*07/06/2023 17:16:40.7680] No more AP manager addresses remain..
[*07/06/2023 17:16:40.7680] No valid AP manager found for controller 'WLC-Primary-Unit' (ip: 192.168.2.102)
[*07/06/2023 17:16:40.7681] Failed to join controller WLC-Primary-Unit.
[*07/06/2023 17:16:40.7681] Failed to join controller.
[*07/06/2023 17:16:40.9776]
[*07/06/2023 17:16:40.9776] CAPWAP State: Discovery
[*07/06/2023 17:16:40.9811] Got WLC address 192.168.2.102 from DHCP.
[*07/06/2023 17:16:40.9812] IP DNS query for CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:16:55.9961] DNS resolved CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:16:55.9961] DNS discover IP addr: 192.168.2.102
[*07/06/2023 17:16:55.9974] Discovery Request sent to 192.168.2.102, discovery type DHCP(2)
[*07/06/2023 17:16:55.9985] Discovery Request sent to 192.168.2.102, discovery type DNS(3)
[*07/06/2023 17:16:56.0008] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/06/2023 17:16:56.0009] Discovery Response from 192.168.2.102
[*07/06/2023 17:16:56.0083] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*07/06/2023 17:17:05.4543] Dropping dtls packet since session is not established. Peer 192.168.2.102-5246, Local 192.168.97.126-5272, conn (nil)
[*07/06/2023 17:16:55.0000]
[*07/06/2023 17:16:55.0000] CAPWAP State: DTLS Setup
[*07/06/2023 17:17:26.5354] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: DTLS Setup(3).
[*07/06/2023 17:17:52.0169] dtls_disconnect: ERROR shutting down dtls connection ...
[*07/06/2023 17:17:52.0170]
[*07/06/2023 17:17:52.0171] CAPWAP State: DTLS Teardown
[*07/06/2023 17:17:56.7686] No more AP manager addresses remain..
[*07/06/2023 17:17:56.7686] No valid AP manager found for controller 'WLC-Primary-Unit' (ip: 192.168.2.102)
[*07/06/2023 17:17:56.7686] Failed to join controller WLC-Primary-Unit.
[*07/06/2023 17:17:56.7687] Failed to join controller.
[*07/06/2023 17:17:56.9782]
[*07/06/2023 17:17:56.9782] CAPWAP State: Discovery
[*07/06/2023 17:17:56.9788] Got WLC address 192.168.2.102 from DHCP.
[*07/06/2023 17:17:56.9788] IP DNS query for CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:18:01.9816] DNS resolved CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:18:01.9816] DNS discover IP addr: 192.168.2.102
[*07/06/2023 17:18:01.9829] Discovery Request sent to 192.168.2.102, discovery type DNS(3)
[*07/06/2023 17:18:01.9851] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/06/2023 17:18:11.5072] WTP IP address changed from 0.0.0.0 to 192.168.97.126, restart CAPWAP.
[*07/06/2023 17:18:11.5072] Lost connection to the controller, going to restart CAPWAP (reason : WTP IP address changed)...
[*07/06/2023 17:18:11.5073] Restarting CAPWAP State Machine.
[*07/06/2023 17:18:11.6115] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*07/06/2023 17:18:11.6125]
[*07/06/2023 17:18:11.6125] CAPWAP State: DTLS Teardown
[*07/06/2023 17:18:16.4495]
[*07/06/2023 17:18:16.4495] CAPWAP State: Discovery
[*07/06/2023 17:18:16.4501] Got WLC address 192.168.2.102 from DHCP.
[*07/06/2023 17:18:16.4501] IP DNS query for CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:18:16.4519] DNS resolved CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:18:16.4519] DNS discover IP addr: 192.168.2.102
[*07/06/2023 17:18:16.4536] Discovery Request sent to 192.168.2.102, discovery type DHCP(2)
[*07/06/2023 17:18:16.4551] Discovery Request sent to 192.168.2.102, discovery type DNS(3)
[*07/06/2023 17:18:16.4596] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/06/2023 17:18:16.4597] Discovery Response from 192.168.2.102
[*07/06/2023 17:18:16.4673] Discovery Response from 192.168.2.102
[*07/06/2023 17:18:20.0442] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*07/06/2023 17:18:36.0000]
[*07/06/2023 17:18:36.0000] CAPWAP State: DTLS Setup
[*07/06/2023 17:19:18.4637] Invalid event 2 & state 3 combination.
[*07/06/2023 17:19:18.4638] CAPWAP SM handler: Failed to process message type 2 state 3.
[*07/06/2023 17:19:18.4638] Failed to handle capwap control message from controller - status 1
[*07/06/2023 17:19:18.4638] Failed to process unencrypted capwap packet 0x1555000 from 192.168.2.102
[*07/06/2023 17:19:18.4638] Failed to send message to CAPWAP state machine, msgId 0
[*07/06/2023 17:19:18.4638] Failed to send capwap message 0 to the state machine. Packet already freed.
[*07/06/2023 17:19:18.4638] IPv4 wtpProcessPacketFromSocket returned 1
[*07/06/2023 17:19:21.8069] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: DTLS Setup(3).
[*07/06/2023 17:19:28.0709] Invalid event 2 & state 3 combination.
[*07/06/2023 17:19:28.0710] CAPWAP SM handler: Failed to process message type 2 state 3.
[*07/06/2023 17:19:28.0710] Failed to handle capwap control message from controller - status 1
[*07/06/2023 17:19:28.0710] Failed to process unencrypted capwap packet 0x1567000 from 192.168.2.102
[*07/06/2023 17:19:28.0710] Failed to send message to CAPWAP state machine, msgId 0
[*07/06/2023 17:19:28.0710] Failed to send capwap message 0 to the state machine. Packet already freed.
[*07/06/2023 17:19:28.0710] IPv4 wtpProcessPacketFromSocket returned 1
[*07/06/2023 17:19:33.0164] dtls_disconnect: ERROR shutting down dtls connection ...
[*07/06/2023 17:19:33.0166]
[*07/06/2023 17:19:33.0166] CAPWAP State: DTLS Teardown
[*07/06/2023 17:19:37.7667] Invalid event 2 & state 4 combination.
[*07/06/2023 17:19:37.7668] CAPWAP SM handler: Failed to process message type 2 state 4.
[*07/06/2023 17:19:37.7668] Failed to handle capwap control message from controller - status 1
[*07/06/2023 17:19:37.7668] Failed to process unencrypted capwap packet 0x1567000 from 192.168.2.102
[*07/06/2023 17:19:37.7668] Failed to send message to CAPWAP state machine, msgId 0
[*07/06/2023 17:19:37.7668] Failed to send capwap message 0 to the state machine. Packet already freed.
[*07/06/2023 17:19:37.7668] IPv4 wtpProcessPacketFromSocket returned 1
[*07/06/2023 17:19:37.7681] No more AP manager addresses remain..
[*07/06/2023 17:19:37.7681] No valid AP manager found for controller 'WLC-Primary-Unit' (ip: 192.168.2.102)
[*07/06/2023 17:19:37.7682] Failed to join controller WLC-Primary-Unit.
[*07/06/2023 17:19:37.7682] Failed to join controller.
[*07/06/2023 17:19:37.9777]
[*07/06/2023 17:19:37.9777] CAPWAP State: Discovery
[*07/06/2023 17:19:37.9783] Got WLC address 192.168.2.102 from DHCP.
[*07/06/2023 17:19:37.9784] IP DNS query for CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:19:37.9799] DNS resolved CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:19:37.9799] DNS discover IP addr: 192.168.2.102
[*07/06/2023 17:19:37.9815] Discovery Request sent to 192.168.2.102, discovery type DHCP(2)
[*07/06/2023 17:19:37.9861] Discovery Request sent to 192.168.2.102, discovery type DNS(3)
[*07/06/2023 17:19:37.9883] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/06/2023 17:19:37.9884] Discovery Response from 192.168.2.102
[*07/06/2023 17:19:37.9959] Discovery Response from 192.168.2.102
[*07/06/2023 17:19:47.0000]
[*07/06/2023 17:19:47.0000] CAPWAP State: DTLS Setup
[*07/06/2023 17:19:47.0017] Invalid event 2 & state 3 combination.
[*07/06/2023 17:19:47.0017] CAPWAP SM handler: Failed to process message type 2 state 3.
[*07/06/2023 17:19:47.0017] Failed to handle capwap control message from controller - status 1
[*07/06/2023 17:19:47.0017] Failed to process unencrypted capwap packet 0x1555000 from 192.168.2.102
[*07/06/2023 17:19:47.0018] Failed to send message to CAPWAP state machine, msgId 0
[*07/06/2023 17:19:47.0018] Failed to send capwap message 0 to the state machine. Packet already freed.
[*07/06/2023 17:19:47.0018] IPv4 wtpProcessPacketFromSocket returned 1
[*07/06/2023 17:19:56.6885] Invalid event 2 & state 3 combination.
[*07/06/2023 17:19:56.6885] CAPWAP SM handler: Failed to process message type 2 state 3.
[*07/06/2023 17:19:56.6885] Failed to handle capwap control message from controller - status 1
[*07/06/2023 17:19:56.6885] Failed to process unencrypted capwap packet 0x1557000 from 192.168.2.102
[*07/06/2023 17:19:56.6886] Failed to send message to CAPWAP state machine, msgId 0
[*07/06/2023 17:19:56.6886] Failed to send capwap message 0 to the state machine. Packet already freed.
[*07/06/2023 17:19:56.6886] IPv4 wtpProcessPacketFromSocket returned 1
[*07/06/2023 17:20:16.3789]
[*07/06/2023 17:20:16.3789] CAPWAP State: Join
[*07/06/2023 17:20:16.3814] Sending Join request to 192.168.2.102 through port 5272
[*07/06/2023 17:20:16.3860] Join Response from 192.168.2.102
[*07/06/2023 17:20:16.4655] HW CAPWAP tunnel is ADDED
[*07/06/2023 17:20:16.4802]
[*07/06/2023 17:20:16.4802] CAPWAP State: Image Data
[*07/06/2023 17:20:16.5176] do PRECHECK, part1 is active part
[*07/06/2023 17:20:16.6765] Image Data Request sent to 192.168.2.102
[*07/06/2023 17:20:16.7913] .Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Image Data(10).
[*07/06/2023 17:20:16.9790] ..........................
[*07/06/2023 17:20:27.6422] ..................................................
[*07/06/2023 17:20:42.8624] ..................................................
[*07/06/2023 17:20:58.1599] ..........................
[*07/06/2023 17:21:02.8152] Successfully downloaded image.
[*07/06/2023 17:21:02.8520] do PREDOWNLOAD, part1 is active part
[*07/06/2023 17:21:07.3337] Image signing verify success.
[*07/06/2023 17:21:08.8389] upgrade.sh: part to upgrade is part2
[*07/06/2023 17:21:09.4230] upgrade.sh: Writing image to disk...
[*07/06/2023 17:21:17.5339] sh: 0: unknown operand
[*07/06/2023 17:21:17.6324] upgrade.sh: AP backup version: 8.5.171.5
[*07/06/2023 17:21:17.6893] do ACTIVATE, part1 is active part
[*07/06/2023 17:21:17.7907] upgrade.sh: activate part2, set BOOT to part2
[*07/06/2023 17:21:18.7726] upgrade.sh: AP primary version: 8.5.171.5
[*07/06/2023 17:21:18.7741] upgrade.sh: AP backup version: 8.2.20.16
[*07/06/2023 17:21:21.7796] AP Rebooting: Reset Reason - Image Upgrade
Writing reload timestamp (Thu Jul 6 17:21:21 UTC 2023) to disk
[*07/06/2023 17:21:22.8294] umount: can't umount /storage: Device or resource busy
failed to unmount /storage; waiting 1s and trying again.
The system is going down NOW!17:21:23.8328]
[*07/06/2023 17:21:23.8335] 2023-07-06 17:21:23 TAMS terminating due to signal 15 (Terminated)
[*07/06/2023 17:21:23.8336] 2023-07-06 17:21:23 select errno=4 - Interrupted system call
Sent SIGTERM to all processes
Sent SIGKILL to all processes
Requesting system reboot45]
[07/06/2023 17:21:25.8400] reboot: Restarting system
BootROM - 1.78
Booting from SPI flash, Secure mode
BootROM: RSA Public key verification PASSED
BootROM: CSK block signature verification PASSED
BootROM: Boot header signature verification PASSED
BootROM: Box ID verification PASSED
BootROM: JTAG is disabled
General initialization - Version: 1.0.0
Detected Device ID 6920
Master bootloder version 1.34
High speed PHY - Version: 2.0
BoardId = 0x20board SerDes lanes topology details:
| Lane # | Speed| Type |
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
:** Link is Gen1, check the EP capability
PCIe, Idx 1: Link upgraded to Gen2 based on client cpabilities
PCIe, Idx 2: Link upgraded to Gen2 based on client cpabilities
High speed PHY - Ended Successfully
DDR4 Training Sequence - Ver TIP-0.23.(Sublib 0.8)0
DDR4 Training Sequence - Switching XBAR Window to FastPath Window
DDR4 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
BootROM: Boot image signature verification PASSED
____ _
/ ___|(_) ___ ___ ___
| | | |/ __| / __|/ _ \
| |___ | |\__ \| (__| (_) |
\____||_||___/ \___|\___/
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
** LOADER **
U-Boot 2013.01-gacaad15 (Aug 18 2019 - 20:12:19) SDK version: 2015_T2.0p10
Board: Barbados-3K
SoC: MV88F6920 Rev A1
running 2 CPUs
CPU: ARM Cortex A9 MPCore (Rev 1) LE
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DDR4 32 Bit Width,FastPath Memory Access, DLB Enabled, ECC Disabled
DRAM: 1 GiB
RST I2C0
NAND: 256 MiB
SF: Detected N25Q32A with page size 64 KiB, total 4 MiB
PCI-e 1 (IF 0 - bus 0) Root Complex Interface, Detected Link X1, GEN 2.0
PCI-e 2 (IF 1 - bus 1) Root Complex Interface, Detected Link X1, GEN 2.0
Map: Code: 0x3fed9000:0x3ffadc40
BSS: 0x3ffef704
Stack: 0x3f9c8f20
Heap: 0x3f9c9000:0x3fed9000
U-Boot Environment: 0x00100000:0x00110000 (SPI)
Board configuration:
| port | Interface | PHY address |
| egiga1 | SGMII | 0x01 |
| egiga2 | SGMII | In-Band |
Net: , egiga1, egiga2 [PRIME]
Hit ESC key to stop autoboot: 0
Creating 1 MTD partitions on "nand0":
0x000000200000-0x000010000000 : "mtd=2"
UBI: attaching mtd1 to ubi0
UBIFS: mounted UBI device 0, volume 1, name "part2"
Loading file 'part2/part.bin' to addr 0x02000000 with size 39798909 (0x025f487d)...
Done
Checking image signing.
Image signing verification success, continue to run...
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Barbados Firmware Image
Created: 2021-05-26 19:02:27 UTC
Image Type: ARM Linux Multi-File Image (uncompressed)
Data Size: 39797901 Bytes = 38 MiB
Load Address: 00008000
Entry Point: 00008000
Contents:
Image 0: 3976224 Bytes = 3.8 MiB
Image 1: 35805895 Bytes = 34.1 MiB
Image 2: 15765 Bytes = 15.4 KiB
Verifying Checksum ... OK
## Loading init Ramdisk from multi component Legacy Image at 02000000 ...
## Flattened Device Tree from multi component Image at 02000000
Booting using the fdt at 0x045f0738
Loading Multi-File Image ... OK
OK
reserving fdt memory region: addr=0 size=4000
Loading Device Tree to 01ff9000, end 01fffd94 ... OK
Starting Device Tree update ('fdt_skip_update' = no)
Limit DDR size at 3GB due to power of 2 requirement of Address decoding
Updating device tree successful
Starting kernel ...
[01/01/1970 00:00:00.0000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
[01/01/1970 00:00:00.0000] Memory: 993404K/1048576K available (5392K kernel code, 395K rwdata, 2392K rodata, 347K init, 465K bss, 55172K reserved)
[01/01/1970 00:00:00.1200] CPU1: Booted secondary processor
[01/01/1970 00:00:09.0100] buginf tty flushing thread started, ttyport=be89d800
[01/01/1970 00:00:09.1000] m25p80 spi1.0: found n25q032a, expected n25q032
[*12/24/2032 04:24:22.5007] buginf() enabled.
[*12/24/2032 04:24:22.5093] Made it into bootsh: May 26 2021 18:56:59
[*12/24/2032 04:24:22.5095] bootsh build T-ece610f6acfc7ef813c7f599cb474308b5a5c85d-gece610f6-aut
[*12/24/2032 04:24:22.5095] bootsh mini ramfs booted
[*12/24/2032 04:24:29.7296] 241735 blocks
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
init started: BusyBox v1.23.2 (2021-05-26 18:37:54 GMT)
Dec 24 04:24:33 FIPS[1264]: *** shell: FIPS Mode = disabled ***
User Access Verification
Username: [*12/24/2032 04:24:35.8376]
[*12/24/2032 04:24:35.8376] Authenticating ACT2 ID:AP3800
[*12/24/2032 04:24:35.8376] Authenticating SN:FOC21190NS2
[*12/24/2032 04:24:35.8380]
[*12/24/2032 04:24:35.8381] (ACT2Boot) Hardware is Cisco (c) authentic 🙂
[*12/24/2032 04:24:35.8411] Seeding /dev/urandom from ACT2
[*12/24/2032 04:24:37.4550] Reading ACT2 SUDI certificates
[*05/18/2017 23:59:59.0066] Last reload time: Jul 6 17:21:21 2023
[*07/06/2023 17:21:21.0001] Setting system time Thu Jul 6 17:21:21 UTC 2023
[*07/06/2023 17:21:21.1145] Loading kernel crypto modules
[*07/06/2023 17:21:21.2374] GCM-128 POST passed
[*07/06/2023 17:21:21.2374] GCM-256 POST passed
[*07/06/2023 17:21:21.2660] Identified Ethernet mGig PHY: aq
[*07/06/2023 17:21:38.9402] Active version: 8.5.171.5
[*07/06/2023 17:21:38.9414] Backup version: 8.2.20.16
[*07/06/2023 17:[07/06/2023 17:21:39.1000] PCI: enabling device 0000:00:02.0 (0140 -> 0143)
21:39.0983] devi[07/06/2023 17:21:39.1900] PCI: enabling device 0000:02:00.0 (0140 -> 0142)
ce wired0 entered promiscuous mode
[*07/06/2023 17:21:40.5427] 0;0;0;0;0;0;0;0;0;0;0;0;0;0;0;
[*07/06/2023 17:21:44.1771] Firmware download complete
[*07/06/2023 17:21:44.3771] FIPS enc aes-ccmp Verified
[*07/06/2023 17:21:44.3772] FIPS dec aes-ccmp Verified
[*07/06/2023 17:21:44.3773] FIPS enc aes-ccmp-25[07/06/2023 17:21:44.5200] PCI: enabling device 0000:00:03.0 (0140 -> 0143)
6 Verified
[*07[07/06/2023 17:21:44.6100] PCI: enabling device 0000:03:00.0 (0140 -> 0142)
/06/2023 17:21:44.3774] FIPS dec aes-ccmp-256 Verified
[*07/06/2023 17:21:44.3775] FIPS enc aes-gcmp Verified
[*07/06/2023 17:21:44.3776] FIPS dec aes-gcmp Verified
[*07/06/2023 17:21:44.3777] FIPS enc aes-gcmp-256 Verified
[*07/06/2023 17:21:44.3778] FIPS dec aes-gcmp-256 Verified
[*07/06/2023 17:21:45.9710] 0;0;0;0;0;0;0;0;0;0;0;0;0;
[*07/06/2023 17:21:49.0520] Firmware download complete
[*07/06/2023 17:21:49.2470] FIPS enc aes-ccmp Verified
[*07/06/2023 17:21:49.2471] FIPS dec aes-ccmp Verified
[*07/06/2023 17:21:49.2472] FIPS enc aes-ccmp-256 Verified
[*07/06/2023 17:21:49.2474] FIPS dec aes-ccmp-256 Verified
[*07/06/2023 17:21:49.2475] FIPS enc aes-gcmp Verified
[*07/06/2023 17:21:49.2476] FIPS dec aes-gcmp Verified
[*07/06/2023 17:21:49.2477] FIPS enc aes-gcmp-256 Verified
[*07/06/2023 17:21:49.2478] FIPS dec aes-gcmp-256 Verified
[*07/06/2023 17:21:49.7199] ifconfig: SIOCGIFFLAGS: No such device
[*07/06/2023 17:21:49.8437] Initializing NSS Firmware
[07/06/2023 17:21:52.9800] Disabling lock debugging due to kernel taint
[*07/06/2023 17:21:53.0853] stile module dp init successfully
[*07/06/2023 17:21:53.0853] NBAR Label:BLD_V155_3_S_XE316_THROTTLE_LATEST_20180404_162221 NBAR VERSION:module build date: May 26 2021 at 18:54:14
[*07/06/2023 17:21:54.6049] Loading nf_conntrack...
[*07/06/2023 17:21:54.6230] Loading nf_conntrack_ftp...
[*07/06/2023 17:21:54.6342] Loading nf_defrag_ipv4...
[*07/06/2023 17:21:54.6452] Loading nf_defrag_ipv6...
[*07/06/2023 17:21:54.6566] Loading nf_conntrack_ipv4...
[*07/06/2023 17:21:54.6680] Loading nf_conntrack_ipv6...
[*07/06/2023 17:21:54.6793] Loading nf_conntrack_irc...
[*07/06/2023 17:21:54.6908] Loading nfnetlink...
[*07/06/2023 17:21:54.7021] Loading nf_conntrack_netlink...
[*07/06/2023 17:21:54.7138] Loading nf_conntrack_sip...
[*07/06/2023 17:21:54.7252] Loading nf_nat...
[*07/06/2023 17:21:54.7370] Loading nf_nat_ftp...
[*07/06/2023 17:21:54.7482] Loading nf_nat_ipv4...
[*07/06/2023 17:21:54.7595] Loading nf_nat_irc...
[*07/06/2023 17:21:54.7707] Loading nf_nat_sip...
[*07/06/2023 17:21:54.7822] Loading x_tables...
[*07/06/2023 17:21:54.7938] Loading xt_conntrack...
[*07/06/2023 17:21:54.8050] Loading xt_state...
[*07/06/2023 17:21:54.8164] Loading xt_nat...
[*07/06/2023 17:21:54.8276] Loading xt_tcpudp...
[*07/06/2023 17:21:54.8390] Loading ip_tables...
[*07/06/2023 17:21:54.8505] Loading iptable_filter...
[*07/06/2023 17:21:54.8664] Loading iptable_mangle...
[*07/06/2023 17:21:54.8776] Loading iptable_nat...
[*07/06/2023 17:21:54.8889] Loading ip6_tables...
[*07/06/2023 17:21:54.9005] Loading ip6t_REJECT...
[*07/06/2023 17:21:54.9120] Loading ip6t_ipv6header...
[*07/06/2023 17:21:54.9232] Loading ip6table_filter...
[*07/06/2023 17:21:54.9345] Loading ip6table_mangle...
[*07/06/2023 17:21:54.9458] Loading ipt_MASQUERADE...
[*07/06/2023 17:21:54.9575] Loading ipt_REJECT...
[*07/06/2023 17:21:54.9688] Loading iptable_raw...
[*07/06/2023 17:21:54.9803] Loading ip6table_raw...
[*07/06/2023 17:21:54.9917] Loading bridge...
[*07/06/2023 17:21:55.0068] Loading nfnetlink_log...
[*07/06/2023 17:21:55.0183] Loading xt_mark...
[*07/06/2023 17:21:55.0298] Loading xt_policy...
[*07/06/2023 17:21:55.0412] xt_tcpudp is already loaded
[*07/06/2023 17:21:55.0412] Loading ebtables...
[*07/06/2023 17:21:55.0531] Loading ebt_ip...
[*07/06/2023 17:21:55.0645] Loading ebt_ip6...
[*07/06/2023 17:21:55[07/06/2023 17:21:56.8800] wired0 emac 0: link up
.0760] Loading i[07/06/2023 17:21:56.9500] wired0: link up
pt_ULOG...
[*07/06/2023 17:21:55.2242]
[*07/06/2023 17:21:55.2281] boot 2 build T-ece610f6acfc7ef813c7f599cb474308b5a5c85d-gece610f6-aut board barbados mac 00:27:E3:89:56:BA
[*07/06/2023 17:21:55.2311] Module: act2_driver .text=0x7f000000 data=0x7f000770 bss=0x7f000a04
[*07/06/2023 17:21:55.2312] Module: aes_generic .text=0x7f004000 data=0x7f00a460 bss=
[*07/06/2023 17:21:55.2312] Module: sha256_generic .text=0x7f00e000 data=0x7f00fbdc bss=
[*07/06/2023 17:21:55.2312] Module: sha512_generic .text=0x7f014000 data=0x7f0158c8 bss=
[*07/06/2023 17:21:55.2312] Module: hmac .text=0x7f019000 data=0x7f0195e8 bss=
[*07/06/2023 17:21:55.2312] Module: sha1_generic .text=0x7f01d000 data=0x7f01d2cc bss=
[*07/06/2023 17:21:55.2312] Module: sha1_arm .text=0x7f021000 data=0x7f021850 bss=
[*07/06/2023 17:21:55.2312] Module: gf128mul .text=0x7f025000 data= bss=
[*07/06/2023 17:21:55.2312] Module: cbc .text=0x7f02a000 data=0x7f02a4f4 bss=
[*07/06/2023 17:21:55.2312] Module: ctr .text=0x7f02e000 data=0x7f02e7c8 bss=
[*07/06/2023 17:21:55.2312] Module: ghash_generic .text=0x7f032000 data=0x7f032268 bss=
[*07/06/2023 17:21:55.2312] Module: seqiv .text=0x7f036000 data=0x7f036654 bss=
[*07/06/2023 17:21:55.2312] Module: mbedtls .text=0x7f03a000 data=0x7f0415e0 bss=0x7f041850
[*07/06/2023 17:21:55.2312] Module: a390_mii_xsmi .text=0x7f046000 data=0x7f046b8c bss=0x7f046d50
[*07/06/2023 17:21:55.2312] Module: a390_port_switch .text=0x7f04b000 data=0x7f0ae0d0 bss=0x7f0b18f0
[*07/06/2023 17:21:55.2312] Module: aptrace .text=0x7f0c9000 data=0x7f0d4f84 bss=0x7f0d5470
[*07/06/2023 17:21:55.2312] Module: ap8x .text=0x7f0dd000 data=0x7f194150 bss=0x7f19bba8
[*07/06/2023 17:21:55.2312] Module: mv_nss_api .text=0x7f38c000 data=0x7f3de66c bss=0x7f3dfaf4
[*07/06/2023 17:21:55.2312] Module: proclikefs .text=0x7f3f1000 data= bss=0x7f3f1b80
[*07/06/2023 17:21:55.2312] Module: stile_lm_ft .text= data= bss=
[*07/06/2023 17:21:55.2312] Module: stile_lm_dp .text= data= bss=
[*07/06/2023 17:21:55.2313] Module: mtdoops .text=0x7ff09000 data=0x7ff09e34 bss=0x7ff09fa8
[*07/06/2023 17:21:55.2313] Module: ipv6 .text=0x7ff0e000 data=0x7ff43980 bss=0x7ff45540
[*07/06/2023 17:21:55.2313] Module: llc .text=0x7ff6c000 data=0x7ff6c848 bss=0x7ff6c9e4
[*07/06/2023 17:21:55.2313] Module: stp .text=0x7ff71000 data=0x7ff71280 bss=0x7ff7143c
[*07/06/2023 17:21:55.2313] Module: nf_conntrack .text=0x7ff75000 data=0x7ff7eb34 bss=0x7ff7f840
[*07/06/2023 17:21:55.2313] Module: nf_conntrack_ftp .text=0x7ff8f000 data= bss=0x7ff90380
[*07/06/2023 17:21:55.2313] Module: nf_defrag_ipv4 .text=0x7ff94000 data=0x7ff94188 bss=
[*07/06/2023 17:21:55.2313] Module: nf_defrag_ipv6 .text=0x7ff98000 data=0x7ff99050 bss=0x7ff992c0
[*07/06/2023 17:21:55.2313] Module: nf_conntrack_ipv4 .text=0x7ff9f000 data=0x7ffa0d88 bss=0x7ffa1218
[*07/06/2023 17:21:55.2313] Module: nf_conntrack_ipv6 .text=0x7ffa7000 data=0x7ffa81bc bss=
[*07/06/2023 17:21:55.2313] Module: nf_conntrack_irc .text=0x7ffad000 data=0x7ffad57c bss=0x7ffada24
[*07/06/2023 17:21:55.2313] Module: nfnetlink .text=0x7ffb1000 data=0x7ffb1a34 bss=0x7ffb1bac
[*07/06/2023 17:21:55.2313] Module: nf_conntrack_netlink .text=0x7ffb6000 data=0x7ffb9a5c bss=
[*07/06/2023 17:21:55.2313] Module: nf_conntrack_sip .text=0x7ffbf000 data= bss=0x7ffc2f44
[*07/06/2023 17:21:55.2313] Module: nf_nat .text=0x7ffc8000 data=0x7ffc9f54 bss=0x7ffca174
[*07/06/2023 17:21:55.2313] Module: nf_nat_ftp .text=0x7ffd0000 data=0x7ffd0320 bss=
[*07/06/2023 17:21:55.2313] Module: nf_nat_ipv4 .text=0x7ffd4000 data= bss=0x7ffd491c
[*07/06/2023 17:21:55.2313] Module: nf_nat_irc .text=0x7ffd8000 data=0x7ffd8254 bss=
[*07/06/2023 17:21:55.2314] Module: nf_nat_sip .text=0x7ffdc000 data=0x7ffdd7d8 bss=
[*07/06/2023 17:21:55.2314] Module: x_tables .text=0x7ffe1000 data=0x7ffe3184 bss=0x7ffe32fc
[*07/06/2023 17:21:55.2314] Module: xt_conntrack .text=0x7ffea000 data= bss=
[*07/06/2023 17:21:55.2314] Module: xt_state .text=0x7ffee000 data= bss=
[*07/06/2023 17:21:55.2314] Module: xt_nat .text=0x7fff2000 data= bss=
[*07/06/2023 17:21:55.2314] Module: xt_tcpudp .text=0x7fff6000 data= bss=
[*07/06/2023 17:21:55.2314] Module: ip_tables .text=0x7fffa000 data=0x7fffbeb4 bss=0x7fffc12c
[*07/06/2023 17:21:55.2314] Module: iptable_filter .text=0x7f002000 data=0x7f0021b0 bss=
[*07/06/2023 17:21:55.2314] Module: iptable_mangle .text=0x7f012000 data=0x7f012210 bss=
[*07/06/2023 17:21:55.2314] Module: iptable_nat .text=0x7f01b000 data=0x7f01b5bc bss=
[*07/06/2023 17:21:55.2314] Module: ip6_tables .text=0x7f0bd000 data=0x7f0bef50 bss=0x7f0bf1c8
[*07/06/2023 17:21:55.2314] Module: ip6t_REJECT .text=0x7f023000 data= bss=
[*07/06/2023 17:21:55.2314] Module: ip6t_ipv6header .text=0x7f02c000 data= bss=
[*07/06/2023 17:21:55.2314] Module: ip6table_filter .text=0x7f034000 data=0x7f034174 bss=
[*07/06/2023 17:21:55.2314] Module: ip6table_mangle .text=0x7f044000 data=0x7f044284 bss=
[*07/06/2023 17:21:55.2314] Module: ipt_MASQUERADE .text=0x7f0c3000 data=0x7f0c32a8 bss=
[*07/06/2023 17:21:55.2314] Module: ipt_REJECT .text=0x7f0c7000 data= bss=
[*07/06/2023 17:21:55.2315] Module: iptable_raw .text=0x7f0db000 data=0x7f0db17c bss=
[*07/06/2023 17:21:55.2315] Module: ip6table_raw .text=0x7f370000 data=0x7f370140 bss=
[*07/06/2023 17:21:55.2315] Module: bridge .text=0x7f374000 data=0x7f381028 bss=0x7f38157c
[*07/06/2023 17:21:55.2315] Module: nfnetlink_log .text=0x7f388000 data=0x7f3895e0 bss=0x7f3897ec
[*07/06/2023 17:21:55.2316] Module: xt_mark .text=0x7f3f4000 data= bss=
[*07/06/2023 17:21:55.2316] Module: xt_policy .text=0x7f5cf000 data= bss=
[*07/06/2023 17:21:55.2316] Module: ebtables .text=0x7f5d3000 data=0x7f5d65ec bss=
[*07/06/2023 17:21:55.2316] Module: ebt_ip .text=0x7f5da000 data= bss=
[*07/06/2023 17:21:55.2316] Module: ebt_ip6 .text=0x7f5de000 data= bss=
[*07/06/2023 17:21:55.2316] Module: ipt_ULOG .text=0x7f5e2000 data=0x7f5e28a0 bss=
[*07/06/2023 17:21:55.2316] Module: crc_itu_t .text=0x7f5e6000 data= bss=
[*07/06/2023 17:21:55.2316] Module: lowmemorykiller .text=0x7f5ea000 data=0x7f5ea2f4 bss=0x7f5ea4a0
[*07/06/2023 17:21:55.2316] Module: p8022 .text=0x7f5ee000 data= bss=
[*07/06/2023 17:21:55.2316] Module: psnap .text=0x7f5f2000 data=0x7f5f2344 bss=0x7f5f24c4
[*07/06/2023 17:21:55.2316] Module: rng_core .text=0x7f5f6000 data=0x7f5f6818 bss=0x7f5f69d8
[*07/06/2023 17:21:55.2316] Module: udf .text=0x7f5fa000 data=0x7f60a004 bss=0x7f60a180
[*07/06/2023 17:21:55.2514] barbados /tmp/SC4_1dbm.txt
[*07/06/2023 17:21:55.3788] Last reload reason : 2: Image Upgrade
[*07/06/2023 17:22:02.9862]
[*07/06/2023 17:22:02.9862] Click sched monitor: schedulers = 1
[*07/06/2023 17:22:06.2601] click-config/io-real.click:131: While configuring 'todev_wired0 :: ToDevice':
[*07/06/2023 17:22:06.2601] warning: device 'wired0' is down
[*07/06/2023 17:22:06.2798] click-config/io-real.click:131: While configuring 'fromdev_wired0 :: FromDevice':
[*07/06/2023 17:22:06.2798] warning: device 'wired0' is down
[*07/06/2023 17:22:06.7425] click-config/io-real[07/06/2023 17:22:06.7700] wired0 emac 0: link up
.click:131: Whil[07/06/2023 17:22:06.8400] wired0: link up
e initializing 'tohost_wired0 :: ToHost':
[*07/06/2023 17:22:06.7425] warning: device 'wired0' is down
[*07/06/2023 17:22:06.9109] aptrace_register_sysproc_fn: duplicate registeration for 'wired'
[*07/06/2023 17:22:07.7380] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down
[*07/06/2023 17:22:07.7469] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up
[*07/06/2023 17:22:07.7474] ip6_port srcr6, ip6local fe80::227:e3ff:fe89:56ba, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 3(slaac)
[*07/06/2023 17:22:16.9019] Create symlink /dev/mic_cert result 0
[*07/06/2023 17:22:16.9019] Loading certificates from storage...
[*07/06/2023 17:22:16.9158] SKU to radio FW
[*07/06/2023 17:22:17.2140] Generating key, this may take a while...
[*07/06/2023 17:22:18.1501] Public key portion is:
[*07/06/2023 17:22:18.1501] ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCHM5+0qTfERXayqhfk0gu2TL/t5dMHUGAfqnbDuWHP3yzs5GYWVbNKMN+BT0A39mAlJW0ZIw+EbTD9Yy+bQhjgSc6SxBCt/XRQco4R2mZwqpZjJrnOvu/ko419rfPH1Q8FGLPlkWqbW1VUz+hwRXuOlzfWBEBlsj1OMLDy7Ok7zPKsn3Ad9Ga0h5HoV4V8RG0FqHkRRGeDO90YoKG7F80s/164hAuqzhHHmz3jDhu8JQnHFiKuZahfUCM/W7tjLFH1OPlvmHOp7oCD0rNJgvKquEaEyR9oDwKYveFDMOlA9BXJQsPidgFj5KJalOqnkWoyaw2rtnH8lHCLDpm6pJBn root@m0027E38956BA
[*07/06/2023 17:22:18.1501] Fingerprint: sha1!! 91:f6:ac:ec:3a:e6:4b:4a:ed:96:90:4c:13:9b:ae:be:07:d4:0c:08
[*07/06/2023 17:22:18.1613] Starting monit
[*07/06/2023 17:22:18.4270] New Monit id: d8a13d705dad4048b5d91d55fa46b58c
[*07/06/2023 17:22:18.4270] Stored in '/var/.monit.id'
[*07/06/2023 17:22:18.4271] Starting Monit 5.18 daemon with http interface at [localhost]:2812
[*07/06/2023 17:22:21.9751] starting tam services using ACT2...
[*07/06/2023 17:22:22.4163] Password for user changed
[*07/06/2023 17:22:22.7278] gzip -dc /etc/wcp.usermodule.template.gz | sed -e 's/__TX_POWER_XOR_5G_FILE__/\/radio_fw\/X5.csv/g' -e 's/__EVM_POWER_XOR_5G_FILE__/\/radio_fw\/EVM_X5.csv/g' -e 's/__TX_POWER_2G_FILE__/\/radio_fw\/R2.csv/g' -e 's/__TX_POWER_5G_FILE__/\/radio_fw\/R5.csv/g' -e 's/__EVM_POWER_2G_FILE__/\/radio_fw\/EVM_2.csv/g' -e 's/__EVM_POWER_5G_FILE__/\/radio_fw\/EVM_5.csv/g' -e 's/__DOMAIN_2G__/0/g' -e 's/__DOMAIN_5G__/41/g' -e 's/__PWR_TABLE_49G__/0/g' -e 's/__PRODUCT_ID__/AIR-AP3802I-B-K9/g' -e 's/__AP_TYPE__/52/g' -e 's/__WIRELESS_MAC__/40:CE:24:96:67:C0/g' -e 's/__WIRED_MAC__/00:27:E3:89:56:BA/g' -e 's/__WIRED1_MAC__/00:27:E3:89:56:BA/g' | DMALLOC_OPTIONS=debug=0x400003,inter=1000,log=/tmp/wcp.dmalloc.log,limit=40000000 wcpd &
[*07/06/2023 17:22:24.0757] Stopped Radio 1
[*07/06/2023 17:22:24.0884] DOT11_DRV[1]: set_channel Channel set to 36
[*07/06/2023 17:22:24.6344] Stopped Radio 0
[*07/06/2023 17:22:24.6472] DOT11_DRV[0]: set_channel Channel set to 6
[*07/06/2023 17:22:24.8903] CRIT-MeshControl:
[*07/06/2023 17:22:24.8904] Mesh Control: skipped adding wired1 backhaul
[*07/06/2023 17:22:24.8950] DOT11_CFG[0] Radio Mode is changed from Local to Local
[*07/06/2023 17:22:24.8955] DOT11_CFG[1] Radio Mode is changed from Local to Local
[*07/06/2023 17:22:25.1512] DOT11_DRV[0]: set_channel Channel set to 1
[*07/06/2023 17:22:25.4503] DOT11_DRV[0]: set_channel Channel set to 1
[*07/06/2023 17:22:25.4601] DOT11_DRV[0]: set_channel Channel set to 1
[*07/06/2023 17:22:25.8973] bftype is 6
[*07/06/2023 17:22:25.9102] DOT11_DRV[0]: set_channel Channel set to 1
[*07/06/2023 17:22:26.2506] DOT11_DRV[0]: set_channel Channel set to 1
[*07/06/2023 17:22:26.5517] DOT11_DRV[1]: set_channel Channel set to 36
[*07/06/2023 17:22:26.8606] DOT11_DRV[1]: set_channel Channel set to 36
[*07/06/2023 17:22:27.0458] ethernet_port wired0, ip 192.168.97.126, netmask 255.255.254.0, gw 192.168.96.1, mtu 1500, bcast 192.168.97.255, dns1 192.168.8.22, dns2 192.168.8.23, domain pmant1.localDOT11_DRV[1]: set_channel Channel set to 36
[*07/06/2023 17:22:27.1839] DOT11_DRV[1]: set_channel Channel set to 36
[*07/06/2023 17:22:27.6682] bftype is 6
[*07/06/2023 17:22:27.6812] DOT11_DRV[1]: set_channel Channel set to 36
[*07/06/2023 17:22:28.0828] DOT11_DRV[1]: set_channel Channel set to 36
[*07/06/2023 17:22:28.4738] DOT11_DRV[1]: set_channel Channel set to 36
[*07/06/2023 17:22:32.6089] Waiting for POE negotiation to complete
[*07/06/2023 17:22:37.6095] Waiting for POE negotiation to complete
[*07/06/2023 17:22:41.2376] PoE negotiation complete, starts radio
[*07/06/2023 17:22:41.2448] SYS-COND: AP is in fair condition
[*07/06/2023 17:22:41.3299] Started Radio 0
[*07/06/2023 17:22:41.3339] PoE negotiation complete, starts radio
[*07/06/2023 17:22:41.4302] Started Radio 1
[*07/06/2023 17:22:41.7152] DOT11_CFG[0] Radio Mode is changed from Local to Local
[*07/06/2023 17:22:41.7160] DOT11_CFG[1] Radio Mode is changed from Local to Local
[*07/06/2023 17:22:41.7363] AP IPv4 Address updated from 0.0.0.0 to 192.168.97.126
[*07/06/2023 17:22:42.5190] dtls_init: Use SUDI certificate
[*07/06/2023 17:22:42.5193]
[*07/06/2023 17:22:42.5193] CAPWAP State: Init
[*07/06/2023 17:22:42.5198]
[*07/06/2023 17:22:42.5198] Config not found, PNP is required, Starting PNP
[*07/06/2023 17:22:42.5199]
[*07/06/2023 17:22:48.9077] PNP:Server not reachable, Start CAPWAP Discovery
[*07/06/2023 17:22:48.9079]
[*07/06/2023 17:22:48.9079] CAPWAP State: Discovery
[*07/06/2023 17:22:48.9094] Got WLC address 192.168.2.102 from DHCP.
[*07/06/2023 17:22:48.9094] IP DNS query for CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:22:48.9124] DNS resolved CISCO-CAPWAP-CONTROLLER.pmant1.local
[*07/06/2023 17:22:48.9124] DNS discover IP addr: 192.168.2.102
[*07/06/2023 17:22:48.9140] Discovery Request sent to 192.168.2.102, discovery type DHCP(2)
[*07/06/2023 17:22:48.9152] Discovery Request sent to 192.168.2.102, discovery type DNS(3)
[*07/06/2023 17:22:48.9156] Discovery Response from 192.168.2.102
[*07/06/2023 17:22:48.9177] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*07/06/2023 17:22:48.9178]
[*07/06/2023 17:22:48.9178] CAPWAP State: Discovery
[*07/06/2023 17:22:48.9237] Discovery Response from 192.168.2.102
[*07/06/2023 17:24:06.0000]
[*07/06/2023 17:24:06.0000] CAPWAP State: DTLS Setup
[*07/06/2023 17:24:06.7140]
[*07/06/2023 17:24:06.7140] CAPWAP State: Join
[*07/06/2023 17:24:06.7157] Sending Join request to 192.168.2.102 through port 5248
[*07/06/2023 17:24:06.7201] Join Response from 192.168.2.102
[*07/06/2023 17:24:06.8020] HW CAPWAP tunnel is ADDED
[*07/06/2023 17:24:06.8200]
[*07/06/2023 17:24:06.8200] CAPWAP State: Image Data
[*07/06/2023 17:24:06.8602] do NO_UPGRADE, part2 is active part
[*07/06/2023 17:24:06.8663]
[*07/06/2023 17:24:06.8663] CAPWAP State: Configure
[*07/06/2023 17:24:06.8687] DOT11_CFG[0] Radio Mode is changed from Local to Local
[*07/06/2023 17:24:06.8693] DOT11_CFG[1] Radio Mode is changed from Local to Local
[*07/06/2023 17:24:06.9252] Stopped Radio 0
[*07/06/2023 17:24:06.9352] Stopped Radio 1
[*07/06/2023 17:24:07.5159] Started Radio 0
[*07/06/2023 17:24:07.5314] Stopped Radio 0
[*07/06/2023 17:24:07.5443] DOT11_DRV[0]: set_channel Channel set to 1
[*07/06/2023 17:24:07.6768] Started Radio 0
[*07/06/2023 17:24:08.3035] Stopped Radio 0
[*07/06/2023 17:24:08.3161] DOT11_DRV[0]: set_channel Channel set to 1
[*07/06/2023 17:24:08.4486] Started Radio 0
[*07/06/2023 17:24:09.4210] Started Radio 1
[*07/06/2023 17:24:09.4436] Stopped Radio 1
[*07/06/2023 17:24:09.4567] DOT11_DRV[1]: set_channel Channel set to 36
[*07/06/2023 17:24:09.6560] Started Radio 1
[*07/06/2023 17:24:10.2812] Stopped Radio 1
[*07/06/2023 17:24:10.2934] DOT11_DRV[1]: set_channel Channel set to 36
[*07/06/2023 17:24:10.4837] Started Radio 1
[*07/06/2023 17:24:11.4130] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Configure(8).
[*07/06/2023 17:24:11.4132] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Configure(8).
[*07/06/2023 17:24:11.4133] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Configure(8).
[*07/06/2023 17:24:11.4134] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Configure(8).
[*07/06/2023 17:24:11.4135] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Configure(8).
[*07/06/2023 17:24:11.4418] Stopped Radio 0
[*07/06/2023 17:24:11.4547] DOT11_DRV[0]: set_channel Channel set to 1
[*07/06/2023 17:24:11.5881] Started Radio 0
[*07/06/2023 17:24:12.3631] Stopped Radio 1
[*07/06/2023 17:24:12.3766] DOT11_DRV[1]: set_channel Channel set to 36
[*07/06/2023 17:24:12.5678] Started Radio 1
[*07/06/2023 17:24:13.1945] Stopped Radio 1
[*07/06/2023 17:24:13.2067] DOT11_DRV[1]: set_channel Channel set to 36
[*07/06/2023 17:24:13.3967] Started Radio 1
[*07/06/2023 17:24:14.2146]
[*07/06/2023 17:24:14.2146] CAPWAP State: Run
[*07/06/2023 17:24:14.2443] CAPWAP HW tunnel params changed, UPDATING the existing
[*07/06/2023 17:24:14.3116] AP has joined controller WLC-Primary-Unit
[*07/06/2023 17:24:15.0299] save_on_failure is set to 1
[*07/06/2023 17:24:15.0302] save_on_failure is set to 1
[*07/06/2023 17:24:18.8621] KEEPALIVE: Session ID mismatch (m-bit not set)!
[*07/06/2023 17:24:30.2655] KEEPALIVE: Session ID mismatch (m-bit not set)!
[*07/06/2023 17:24:39.0713] set cleanair [slot0][band0] enabled
[*07/06/2023 17:24:39.0725] set cleanair [slot0][band1] enabled
[*07/06/2023 17:24:39.0737] set cleanair [slot1][band1] enabled
[*07/06/2023 17:26:46.5181] Re-Tx Count=1, Max Re-Tx Value=8, SendSeqNum=62, NumofPendingMsgs=2
[*07/06/2023 17:27:17.6878] Re-Tx Count=1, Max Re-Tx Value=8, SendSeqNum=70, NumofPendingMsgs=8
[*07/06/2023 17:27:28.7726] Re-Tx Count=1, Max Re-Tx Value=8, SendSeqNum=75, NumofPendingMsgs=2
[*07/06/2023 17:27:28.7727]
[*07/06/2023 17:37:21.6994] Re-Tx Count=1, Max Re-Tx Value=8, SendSeqNum=152, NumofPendingMsgs=1
[*07/06/2023 17:37:29.4918] Re-Tx Count=1, Max Re-Tx Value=8, SendSeqNum=154, NumofPendingMsgs=2
[*07/06/2023 17:37:34.2432] Re-Tx Count=2, Max Re-Tx Value=8, SendSeqNum=154, NumofPendingMsgs=2
[*07/06/2023 17:37:38.9947] Re-Tx Count=3, Max Re-Tx Value=8, SendSeqNum=154, NumofPendingMsgs=2
[*07/06/2023 17:37:43.7534] Re-Tx Count=4, Max Re-Tx Value=8, SendSeqNum=154, NumofPendingMsgs=2
[*07/06/2023 17:37:48.4977] Re-Tx Count=5, Max Re-Tx Value=8, SendSeqNum=154, NumofPendingMsgs=2
[*07/06/2023 17:37:53.2492] Re-Tx Count=6, Max Re-Tx Value=8, SendSeqNum=155, NumofPendingMsgs=3
[*07/06/2023 17:38:23.2096] Re-Tx Count=1, Max Re-Tx Value=8, SendSeqNum=158, NumofPendingMsgs=2
[*07/06/2023 17:38:29.1087] Re-Tx Count=1, Max Re-Tx Value=8, SendSeqNum=160, NumofPendingMsgs=2
[*07/06/2023 17:38:33.8529] Re-Tx Count=2, Max Re-Tx Value=8, SendSeqNum=160, NumofPendingMsgs=2
[*07/06/2023 17:38:38.6051] Re-Tx Count=3, Max Re-Tx Value=8, SendSeqNum=160, NumofPendingMsgs=2
[*07/06/2023 17:38:46.0174] Re-Tx Count=1, Max Re-Tx Value=8, SendSeqNum=166, NumofPendingMsgs=6
[*07/06/2023 17:38:50.7688] Re-Tx Count=2, Max Re-Tx Value=8, SendSeqNum=166, NumofPendingMsgs=6
[*07/06/2023 17:38:57.5464] DOT11_DRV[1]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:38:57.8856] DOT11_DRV[1]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:38:58.2249] DOT11_DRV[1]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:38:58.5642] DOT11_DRV[1]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:38:58.9037] DOT11_DRV[1]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:38:59.2440] DOT11_DRV[1]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:39:00.0167] DOT11_DRV[0]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:39:00.5554] DOT11_DRV[0]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:39:15.3983] KEEPALIVE: Session ID mismatch (m-bit not set)!
[*07/06/2023 17:39:18.2492] KEEPALIVE: Session ID mismatch (m-bit not set)!
[*07/06/2023 17:39:18.6210] DOT11_DRV[0]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:39:23.9510] KEEPALIVE: Session ID mismatch (m-bit not set)!
[*07/06/2023 17:39:25.9754] DOT11_DRV[1]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:39:26.3559] DOT11_DRV[1]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:39:26.7368] DOT11_DRV[1]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:39:31.3705] DOT11_DRV[1]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:39:31.7098] DOT11_DRV[1]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:39:32.0493] DOT11_DRV[1]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:39:32.3888] DOT11_DRV[1]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:39:32.7284] DOT11_DRV[1]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:39:33.0721] DOT11_DRV[0]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:39:33.3946] DOT11_DRV[0]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:39:33.7184] DOT11_DRV[0]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:39:34.0427] DOT11_DRV[0]: vendor_send_mgmt_frame VAP 1 is not up as expected
[*07/06/2023 17:46:29.2920] Re-Tx Count=1, Max Re-Tx Value=8, SendSeqNum=230, NumofPendingMsgs=2
[*07/06/2023 17:47:02.5523] Re-Tx Count=1, Max Re-Tx Value=8, SendSeqNum=231, NumofPendingMsgs=1
[*07/06/2023 17:47:14.9060] Re-Tx Count=1, Max Re-Tx Value=8, SendSeqNum=234, NumofPendingMsgs=1
[*07/06/2023 17:47:29.3505] Re-Tx Count=1, Max Re-Tx Value=8, SendSeqNum=240, NumofPendingMsgs=2
Thanks - this has been solved.  There were some statically assigned APs within the DHCP scope.  For some reason (despite conflict detection being turned on) the MS DHCP server was assigning those addresses.  Once I figured this out and removed those IPs from the scope, the APs all joined without an issue and remained stable.
6 Replies 6
 Long shot here but did you check if the WLC is not running out of licensing?
Leo Laohoo
Post the complete output to the following commands:
sh version
sh capwap client rcb
Rich R
Glad you got it working but you should also be looking to upgrade to the latest recommended code version as per TAC recommended link below to resolve known bugs and security vulnerabilities.  For you that means version 8.5.182.7 which is probably the last version to be released for 5508.  Also check all the field notices linked below.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
abdallahhagag24
Community Member
hello i have issue with my ap air1832i-B-k9  cant join this ap to my exist controller
[*12/18/2024 08:17:04.6898] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*12/18/2024 08:17:04.6898] Discovery Response from 172.16.30.88
[*12/18/2024 08:17:15.0000]
[*12/18/2024 08:17:15.0000] CAPWAP State: DTLS Setup
[*12/18/2024 08:17:15.1099]
[*12/18/2024 08:17:15.1099] CAPWAP State: Join
[*12/18/2024 08:17:15.1199] Sending Join request to 172.16.30.88 through port 5256
[*12/18/2024 08:17:15.1299] Join Response from 172.16.30.88
[*12/18/2024 08:17:15.1299] AC accepted join request with result code: 0
[*12/18/2024 08:17:15.1299] Master-Slave: role 3, master 172.16.30.225, old 0
[*12/18/2024 08:17:15.1299] Master-Slave: Set to Slave, retry 44, set_tftp_server 0, Master AP 172.16.30.225, Join role Slave, tftp_timeoutCnt 3
[*12/18/2024 08:17:15.1299] Image pre-download request for version 8.10.185.0.
[*12/18/2024 08:17:15.1299] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Join(5).
[*12/18/2024 08:17:15.1699] upgrade.sh: Script called with args:[NO_UPGRADE]
[*12/18/2024 08:17:15.2099] do NO_UPGRADE, part2 is active part
[*12/18/2024 08:17:15.2099] Resetting slave AP upgrade mode to local mode
[*12/18/2024 08:17:15.2099] Received wlcType 1, timer 120
[*12/18/2024 08:17:15.2799]
[*12/18/2024 08:17:15.2799] CAPWAP State: Image Data
[*12/18/2024 08:17:15.2799] AP image version 8.10.185.0 backup 8.10.185.0, Controller 8.10.185.0
[*12/18/2024 08:17:15.2799] Version is the same, do not need update.
[*12/18/2024 08:17:15.3299] upgrade.sh: Script called with args:[NO_UPGRADE]
[*12/18/2024 08:17:15.3599] do NO_UPGRADE, part2 is active part
[*12/18/2024 08:17:15.3599] CAPWAP State: Configure
[*12/18/2024 08:17:15.3599] Telnet is not supported by AP, should not encode this payload
[*12/18/2024 08:17:18.2090] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/18/2024 08:17:21.0681] Re-Tx Count=2, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/18/2024 08:17:23.9172] Re-Tx Count=3, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/18/2024 08:17:26.7663] Re-Tx Count=4, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/18/2024 08:17:29.6154] Re-Tx Count=5, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/18/2024 08:17:32.1446] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Configure(8).
[*12/18/2024 08:17:32.4645] Max retransmission count exceeded, going back to DISCOVER mode.
[*12/18/2024 08:17:32.4645] Dropping msg CAPWAP_CONFIGURATION_STATUS, type = 4, len = 2182, eleLen = 2190, sendSeqNum = 1
[*12/18/2024 08:17:32.4645] GOING BACK TO DISCOVER MODE
[*12/18/2024 08:17:32.5045]
[*12/18/2024 08:17:32.5045] CAPWAP State: DTLS Teardown
[*12/18/2024 08:17:32.6045] upgrade.sh: Script called with args:[ABORT]
[*12/18/2024 08:17:32.6345] do ABORT, part2 is active part
[*12/18/2024 08:17:32.6645] upgrade.sh: Cleanup tmp files ...
[*12/18/2024 08:17:32.6845] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: DTLS Teardown(4).
[*12/18/2024 08:17:47.2499]
[*12/18/2024 08:17:47.2499] CAPWAP State: Discovery
[*12/18/2024 08:17:47.2499] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*12/18/2024 08:17:47.2499] Discovery Response from 172.16.30.88
[*12/18/2024 08:17:55.0000]
[*12/18/2024 08:17:55.0000] CAPWAP State: DTLS Setup
[*12/18/2024 08:17:55.1199]
[*12/18/2024 08:17:55.1199] CAPWAP State: Join
[*12/18/2024 08:17:55.1199] Sending Join request to 172.16.30.88 through port 5256
[*12/18/2024 08:17:55.1299] Join Response from 172.16.30.88
[*12/18/2024 08:17:55.1299] AC accepted join request with result code: 0
[*12/18/2024 08:17:55.1299] Master-Slave: role 3, master 172.16.30.225, old 0
[*12/18/2024 08:17:55.1299] Master-Slave: Set to Slave, retry 44, set_tftp_server 0, Master AP 172.16.30.225, Join role Slave, tftp_timeoutCnt 3
[*12/18/2024 08:17:55.1299] Image pre-download request for version 8.10.185.0.
[*12/18/2024 08:17:55.1299] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Join(5).
[*12/18/2024 08:17:55.1699] upgrade.sh: Script called with args:[NO_UPGRADE]
[*12/18/2024 08:17:55.2099] do NO_UPGRADE, part2 is active part
[*12/18/2024 08:17:55.2099] Resetting slave AP upgrade mode to local mode
[*12/18/2024 08:17:55.2099] Received wlcType 1, timer 120
[*12/18/2024 08:17:55.2799]
[*12/18/2024 08:17:55.2799] CAPWAP State: Image Data
[*12/18/2024 08:17:55.2799] AP image version 8.10.185.0 backup 8.10.185.0, Controller 8.10.185.0
[*12/18/2024 08:17:55.2799] Version is the same, do not need update.
[*12/18/2024 08:17:55.3299] upgrade.sh: Script called with args:[NO_UPGRADE]
[*12/18/2024 08:17:55.3599] do NO_UPGRADE, part2 is active part
[*12/18/2024 08:17:55.3599] CAPWAP State: Configure
[*12/18/2024 08:17:55.3599] Telnet is not supported by AP, should not encode this payload
[*12/18/2024 08:17:58.2190] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/18/2024 08:18:01.0681] Re-Tx Count=2, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/18/2024 08:18:03.9172] Re-Tx Count=3, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/18/2024 08:18:06.7663] Re-Tx Count=4, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/18/2024 08:18:09.6154] Re-Tx Count=5, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/18/2024 08:18:12.4645] Max retransmission count exceeded, going back to DISCOVER mode.
[*12/18/2024 08:18:12.4645] Dropping msg CAPWAP_CONFIGURATION_STATUS, type = 4, len = 2182, eleLen = 2190, sendSeqNum = 1
[*12/18/2024 08:18:12.4645] GOING BACK TO DISCOVER MODE
[*12/18/2024 08:18:12.5045]
[*12/18/2024 08:18:12.5045] CAPWAP State: DTLS Teardown
[*12/18/2024 08:18:12.6045] upgrade.sh: Script called with args:[ABORT]
[*12/18/2024 08:18:12.6345] do ABORT, part2 is active part
[*12/18/2024 08:18:12.6545] upgrade.sh: Cleanup tmp files ...
[*12/18/2024 08:18:12.6845] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: DTLS Teardown(4).
[*12/18/2024 08:18:27.2799]
[*12/18/2024 08:18:27.2799] CAPWAP State: Discovery
[*12/18/2024 08:18:27.2799] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*12/18/2024 08:18:27.2799] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Discovery(2).
[*12/18/2024 08:18:27.2899] Discovery Response from 172.16.30.88
[*12/18/2024 08:18:37.0000]
[*12/18/2024 08:18:37.0000] CAPWAP State: DTLS Setup
[*12/18/2024 08:18:37.1199]
[*12/18/2024 08:18:37.1199] CAPWAP State: Join
[*12/18/2024 08:18:37.1199] Sending Join request to 172.16.30.88 through port 5256
[*12/18/2024 08:18:37.1299] Join Response from 172.16.30.88
[*12/18/2024 08:18:37.1299] AC accepted join request with result code: 0
[*12/18/2024 08:18:37.1299] Master-Slave: role 3, master 172.16.30.225, old 0
[*12/18/2024 08:18:37.1299] Master-Slave: Set to Slave, retry 44, set_tftp_server 0, Master AP 172.16.30.225, Join role Slave, tftp_timeoutCnt 3
[*12/18/2024 08:18:37.1399] Image pre-download request for version 8.10.185.0.
[*12/18/2024 08:18:37.1399] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: Join(5).
[*12/18/2024 08:18:37.1799] upgrade.sh: Script called with args:[NO_UPGRADE]
[*12/18/2024 08:18:37.2099] do NO_UPGRADE, part2 is active part
[*12/18/2024 08:18:37.2099] Resetting slave AP upgrade mode to local mode
[*12/18/2024 08:18:37.2099] Received wlcType 1, timer 120
[*12/18/2024 08:18:37.2899]
[*12/18/2024 08:18:37.2899] CAPWAP State: Image Data
[*12/18/2024 08:18:37.2899] AP image version 8.10.185.0 backup 8.10.185.0, Controller 8.10.185.0
[*12/18/2024 08:18:37.2899] Version is the same, do not need update.
[*12/18/2024 08:18:37.3399] upgrade.sh: Script called with args:[NO_UPGRADE]
[*12/18/2024 08:18:37.3699] do NO_UPGRADE, part2 is active part
[*12/18/2024 08:18:37.3699] CAPWAP State: Configure
[*12/18/2024 08:18:37.3699] Telnet is not supported by AP, should not encode this payload
[*12/18/2024 08:18:40.2190] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/18/2024 08:18:43.0681] Re-Tx Count=2, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/18/2024 08:18:45.9172] Re-Tx Count=3, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/18/2024 08:18:48.7663] Re-Tx Count=4, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/18/2024 08:18:51.6154] Re-Tx Count=5, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/18/2024 08:18:54.4745] Max retransmission count exceeded, going back to DISCOVER mode.
[*12/18/2024 08:18:54.4745] Dropping msg CAPWAP_CONFIGURATION_STATUS, type = 4, len = 2182, eleLen = 2190, sendSeqNum = 1
[*12/18/2024 08:18:54.4745] GOING BACK TO DISCOVER MODE
[*12/18/2024 08:18:54.5045]
[*12/18/2024 08:18:54.5045] CAPWAP State: DTLS Teardown
[*12/18/2024 08:18:54.6045] upgrade.sh: Script called with args:[ABORT]
[*12/18/2024 08:18:54.6345] do ABORT, part2 is active part
[*12/18/2024 08:18:54.6545] upgrade.sh: Cleanup tmp files ...
[*12/18/2024 08:18:54.6845] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: DTLS Teardown(4).
[*12/18/2024 08:19:09.2599]
- @abdallahhagag24 :  - Please start a new thread for your problem,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
