AP keep flapping between the old controller and new controller
raymond wang
Level 3
Level 3
I am migrating the AP from the old controller to new controller. One AP connected to new controller and download the code then rebooted and re-connnected to old controller and download the code. After that it joined the new controller and download the code...It keep doing this.
What is the issue and how to solve it....
2 Accepted Solutions
Scott Fella
Enable Authorize MIC APs against auth-list or AAA on the old WLC and the AP's will not be able to join the old WLC unless of course you have all the mac address in the list.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Hi Raymond,
We also need to figure out why the AP leave the new WLC.
Fixing this IMO will be a permanent solution.
1) Execute "debug capwap errors enable" ,  "debug capwap events enable"  and debug pm pki enable" on the NEW WLC. Get the output at the time the AP goes out of the new WLC.
2)  "show logging" from the AP.
3) And "show ap join stats detailed "  and "show ap config general " from the WLC.
Victor V
*****Help out other by using the rating system and marking answered questions as *****Answered"*****
Regards Victor V *****Help out other by using the rating system and marking answered questions as *****Answered"*****
Scott Fella
Scott
-Scott
Hi Raymond,
Victor V
Thank you for all your reply. I did remove the mac address of AP from the ACL and configure the new controller as the master controller. After that the AP joined the new one..
Zain Khan
Level 4
Level 4
Select your primary controller as a master controller in Controller TAB. Also configure mobility group in both the WLC. your issue will be resolved
Zain Khan
https://www.linkedin.com/in/forzain/
