AP- load sharing
janesh_abey
Level 5
Level 5
Hi all,
Is there a way to achieve AP load-sharing when we utilise AP groups?
This will make life easy from both designers and implementers as we will not have to worry about subnet allocation etc.
Thanks in advance.
janesh
Scott Fella
Are you talking about having like different AP Groups per floor? A design like that if you had an implementation that had multiple floors for example?
-Scott
yes i'm talking about having different AP groups per floor and replicating it across multiple floors.
yestersay u mentioned that u got a 802.11ac- would you be able to let me know the exact ordering code pls?
