AP not joining WLC...
ljustl
Hello all,
Working on wireless, CAPWAP is initiated, however AP cannot be joined or discovered by WLC..
using 3700 AP and 2504 WLC
Show run and outputs are attached. (for core, access sw, WLC and AP)
CAPWAP State: Join
Finding DTLS connection to delete for AP (192:1xx:xxx:xx/xxxxx)
Disconnecting DTLS Capwap-Ctrl session 0x17aa3ba8 for AP (192:1xx:xxx:xx/xxxxx)
CAPWAP State: Dtls tear down  acDtlsPlumbControlPlaneKeys: lrad:192.1xx.xxx.xx(xxxxx) mwar:192.1xx.xxx.x(xxxx)
DTLS keys for Control Plane deleted successfully for AP 192.xxx.xxx.xx
DTLS connection closed event receivedserver (192.xxx.xxx.x/xxxx) client (192.1xx.xxx.x/xxxxx)
Entry exists for AP (192.1xx.xxx.xx/xxxxx) apModel: AIR-AP3702I-UXK9  apType = 41 apModel: AIR-AP3702I-UXK9
I need help!!!!
43 Replies 43
what will be the problem of AP keep rebooting?
Not sure until someone can console into the AP.
I tried factory reset, (pressing button while i'm connecting)
set the times correctly.. i don't know where else to start..
Can you console into the AP and leave the console session alone?
We want to see what triggers the AP to reload/reboot independently.
that error messages are above.
thats the only messages i saw so far. same thing over and over and over
as you see, AP gets the time wrong and gets to fix later to current it does its own stuff and keep rebooting...
I need to see the lines in the console terminal.  I can't help troubleshoot if I don't see them.
do you need to see certain command from AP's CLI?
i've attached error messages..
I can see the AP boot up, get an IP address, joined the controller, receive the IOS file from the controller and reboot.
From the look of things, I don't see any problem.
Are you seeing the AP downloading the IOS and reboot over and over again?
- Yes..
- Yes..
Reboot your controller.
I will reboot and let you know!
Well... i did reboot my controller and i was able to console in and login to the AP
HOWEVER.... AP is keep rebooting itself. I confirmed that AP is joined in controller as well, but it keep rebooting automatically. Refer below...
User Access Verification
Username:
Username: Cisco
Password:
AP0042.688d.aed4>
AP0042.688d.aed4>
AP0042.688d.aed4>
AP0042.688d.aed4>en
Password:
% Access denied
AP0042.688d.aed4>
AP0042.688d.aed4>
AP0042.688d.aed4>
AP0042.688d.aed4>en
Password:
AP0042.688d.aed4#
AP0042.688d.aed4#
AP0042.688d.aed4#
AP0042.688d.aed4#
AP0042.688d.aed4#
AP0042.688d.aed4#
*Jul 18 00:57:30.335: %CLEANAIR-6-STATE: Slot 0 enabled
*Jul 18 00:57:32.119: %CLEANAIR-6-STATE: Slot 1 enabled
AP0042.688d.aed4#
AP0042.688d.aed4#
AP0042.688d.aed4#
AP0042.688d.aed4#
AP0042.688d.aed4#
AP0042.688d.aed4#
*Jul 18 00:57:39.499: %CDP_PD-4-POWER_OK: 15.4 W power - NEGOTIATED inline power source
IOS Bootloader - Starting system.
flash is writable
Tide XL MB - 40MB of flash
Xmodem file system is available.
flash is writable
flashfs[0]: 68 files, 9 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 20914176
flashfs[0]: Bytes available: 20244480
flashfs[0]: flashfs fsck took 10 seconds.
Base Ethernet MAC address: 00:42:68:8d:ae:d4
Ethernet speed is 100 Mb - FULL Duplex
Loading "flash:/ap3g2-k9w8-mx.153-3.JA10/ap3g2-k9w8-mx.153-3.JA10"...#########################
File "flash:/ap3g2-k9w8-mx.153-3.JA10/ap3g2-k9w8-mx.153-3.JA10" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Montserrat Board
40MB format
flashfs[0]: flashfs fsck took 11 seconds.
flashfs[1]: 0 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 12257280
flashfs[1]: Bytes used: 1024
flashfs[1]: Bytes available: 12256256
flashfs[1]: flashfs fsck took 0 seconds.
Boot CMD: 'boot flash:/ap3g2-k9w8-mx.153-3.JA10/ap3g2-k9w8-xx.153-3.JA10;flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx'
Loading "flash:/ap3g2-k9w8-mx.153-3.JA10/ap3g2-k9w8-xx.153-3.JA10"...###############################################
File "flash:/ap3g2-k9w8-mx.153-3.JA10/ap3g2-k9w8-xx.153-3.JA10" uncompressed and installed, entry point: 0x1003000
executing...
now i found out why
port is flapping.... IEEE PD on "show power inline" command.....
this was reason why AP were keep rebooting itself.
port is flapping
If the port was flapping then the AP wouldn't be downloading the IOS over and over again.
But let's move forward, is the switch connected to the AP a Cisco switch?  If it is, can you tell me the model and IOS version?
maybe i stated wrong. but it was getting power and suddenly stopped. i found out it IEEE PD.
C3560 Software (C3560-ADVIPSERVICESK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)
