AP not registering with BASE MAC
FRANK SCHADE
we are running WLC version 5.2.193.0 with 20 APs. But one cannot registering to the controller
debug on the wlc
*Jul 19 14:51:38.866: Failed to process CAPWAP packet from 10.29.32.35:7173
*Jul 19 14:51:41.866: 00:12:01:c5:c0:c4 AP not registering with BASE MAC.
*Jul 19 14:51:41.866: 00:12:01:c5:c0:c4 State machine handler: Failed to process  msg type = 5 state = 8 from 10.29.32.35:7173
logging on AP:
*Jul 19 12:50:39.378: %CAPWAP-3-ERRORLOG: GOING BACK TO DISCOVER MODE
*Jul 19 12:50:39.379: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.29.25.241
*Jul 19 12:50:40.922: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 19 12:50:40.923: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul 19 12:50:40.926: bsnInitRcbSlot: slot 0 has NO radio
*Jul 19 12:50:40.927: bsnInitRcbSlot: slot 1 has NO radio
*Jul 19 12:50:40.943: bsnUnlockDevice: not bring radio up: radio 0 is in admin disable state
*Jul 19 12:50:40.943: bsnUnlockDevice: not bring radio up: radio 1 is in admin disable state
*Jul 19 12:50:50.947: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 19 12:50:51.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.29.25.241 peer_port: 5246
*Jul 19 12:50:52.806: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.29.25.241 peer_port: 5246
*Jul 19 12:50:52.808: %CAPWAP-5-SENDJOIN: sending Join Request to 10.29.25.241
*Jul 19 12:50:52.808: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jul 19 12:50:53.366: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
The AP is also in the authentiction list
(FRWHMAG-AUTO-ACCB1) >show auth-list
Authorize MIC APs against AAA ................... disabled
Authorize LSC APs against Auth-List ............. disabled
Allow APs with MIC - Manufactured Installed C.... enabled
Allow APs with SSC - Self-Signed Certificate..... enabled
Allow APs with LSC - Locally Significant Cert.... disabled
Mac Addr                  Cert Type    Key Hash
00:12:01:c5:c0:c4         SSC          f593d3bf2875508c5e7a2005820b56bc2ef48f50
Unfortunatelly I don't have phyiscal access to this AP, so I can't "reconvert" it. Any other ideas?
thanks
Frank
leejohns
Frank,
Looks like you have a bad AP as it is not detecting any installed radios:
This wil case the AP to not be able to join the WLC.  I would look into getting it replaced.
Lee
5 Replies 5
leejohns
Frank,
Lee
i have converted 1262 N from AP to LWAP mode.it is not joining to the controller.
i am using WISM with version 7.0.220.
please find the below logs from WISM
*spamReceiveTask: Mar 17 14:15:30.800: 70:ca:9b:04:f8:1b AP not registering with BASE MAC.
*spamReceiveTask: Mar 17 14:15:30.800: 70:ca:9b:04:f8:1b State machine handler: Failed to process  msg type = 5 state = 5 from 10.36.10.41:20354
*spamReceiveTask: Mar 17 14:15:30.800: 70:ca:9b:04:f8:1b Failed to parse CAPWAP packet from 10.36.10.41:20354
*spamReceiveTask: Mar 17 14:15:33.825: 70:ca:9b:04:f8:1b DTLS connection was closed
*spamReceiveTask: Mar 17 14:15:44.291: 70:ca:9b:04:f8:1b AP with same name AP70ca.9b04.f81b exist. Using default name AP70ca.9b04.f81b for this AP.
*spamReceiveTask: Mar 17 14:15:44.423: 70:ca:9b:04:f8:1b AP not registering with BASE MAC.
*spamReceiveTask: Mar 17 14:15:44.423: 70:ca:9b:04:f8:1b State machine handler: Failed to process  msg type = 5 state = 5 from 10.36.10.41:20354
*spamReceiveTask: Mar 17 14:15:44.423: 70:ca:9b:04:f8:1b Failed to parse CAPWAP packet from 10.36.10.41:20354
*spamReceiveTask: Mar 17 14:15:47.403: 70:ca:9b:04:f8:1b AP not registering with BASE MAC.
*spamReceiveTask: Mar 17 14:15:47.403: 70:ca:9b:04:f8:1b State machine handler: Failed to proc
Please find below logs from Access point
*Mar 17 10:28:52.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.23.36.6 peer_port: 5246
*Mar 17 10:28:52.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Mar 17 10:28:52.478: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.23.36.6 peer_port: 5246
*Mar 17 10:28:52.478: %CAPWAP-5-SENDJOIN: sending Join Request to 172.23.36.6
*Mar 17 10:28:52.478: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Mar 17 10:28:52.616: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
logging facility kern
% Invalid input detected at '^' marker.
*Mar 17 10:29:10.663: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.23.36.6:5246
*Mar 17 10:29:10.663: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar 17 10:29:10.713: %CAPWAP-3-ERRORLOG: Dropping dtls packet since session is not established.
*Mar 17 10:29:21.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.23.36.6 peer_port: 5246
*Mar 17 10:29:21.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Mar 17 10:29:21.481: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.23.36.6 peer_port: 5246
*Mar 17 10:29:21.481: %CAPWAP-5-SENDJOIN: sending Join Request to 172.23.36.6
*Mar 17 10:29:21.481: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Mar 17 10:29:21.613: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Mar 17 10:29:39.660: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.23.36.6:5246
*Mar 17 10:29:39.660: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar 17 10:29:39.713: %CAPWAP-3-ERRORLOG: Dropping dtls packet since session is not established.
*Mar 17 10:29:49.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.23.36.6 peer_port: 5246
*Mar 17 10:29:49.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Mar 17 10:29:49.478: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.23.36.6 peer_port: 5246
*Mar 17 10:29:49.478: %CAPWAP-5-SENDJOIN: sending Join Request to 172.23.36.6
*Mar 17 10:29:49.478: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Mar 17 10:29:49.613: %CAPWAP-5-CHANGED: CAPWAP
have you added the mac address of the ap to te ap policies in the wlc?
Can you please post the following output:
1.  WLC:  sh sysinfo
2.  AP:  sh version
3.  AP:  sh inventory
Scott Fella
Might be a bad image on the AP. Place the AP in the same subnet as the WLC management interface. If the AP doesn't join, the upload the lightweight image back into the AP. I'm assuming you have other APs already joined to this WLC? If not, make sure your time is set properly on the WLC also.
-Scott
