AP Power Level
janvelgado_16
Frequent Visitor
Frequent Visitor
Hi guys,
Given: 5520 WLC, high density access points, concrete walls. 1832 APs.
TPC Version Coverage Optimal Mode (TPCv1)
Power Level  Assignment Mode Automatic
Maximum Power Level Assignment (-10 to 30 dBm) 30
Minimum Power Level Assignment (-10 to 30 dBm) -10
Power Threshold (-80 to -50dBm) -70
Is it okay to statically configured the power level of the APs to custom level 1 instead of using RRM (which normally gives 7* or 8*)?
Or should i adjust the configuration of minimum and maximum power level?
Does hysteresis also needs to be changed?
JE
Rasika Nayanajith
No.
It is not recommended to increase AP power level to 1 at any circumstances. This will lead your client see very good signal strength, but they can't communicate back to AP as client devices cannot match AP power level.
Always try to match AP power level to average client power capability if you want to set it manually. Otherwise leave it to RRM to decide.
If you see RRM set 7* or 8* power level, which indicate dense AP deployment where  there are many APs on same operating channel.
Yes, this is a good idea. For example, in my network I have set 8dBm as min and 17dBm as max value under TPC for 5GHz band.
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
No.
Rasika
