AP Registration Issue
anthony.dyne
Level 4
Level 4
Hi Experts
Not able to register AP Point < Air-Cap35021-E-K9 > on 4402 WLC running IOS (AIR-WLC4400-K9-7-0-235-0 )
Other AP already registered on the WLC are  AIR-LAP1242AG-E-K9  & AIR-LAP1131AG-E-K9
Any hints to resolve the registration issue
thanks
Anthny
13 Replies 13
Amjad Abdullah
How any APs already registerred on the wlc?
Can you provide console output from the AP.
Rating useful replies is more useful than saying "Thank you"
Hi Amjad
currently 6 AP are registered to WLC, newly purchased AP - Air-Cap35021-E-K9 not getting registered. The Green LED is blinking, I shut/noshut the interface connected to AP but still the same issue. what you mean by console output from the WLC
thanks
Anthony
Sorry i meant console output from AP. i edited the above post.
on the console I dont see anything, do I need to enable some commands to get console output. which debug commands will help to identify the issue
Can you please post the following command outputs:
1.  WLC:  sh sysinfo;
2.  WAP:  sh version; and
3.  WAP:  sh inventory
Console into the WAP and reboot the WAP.  Post the entire bootup process including the attempt to join or look for a valid controller.
Hi leo
are are show commands
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.235.0
RTOS Version..................................... 7.0.235.0
Bootloader Version............................... 4.2.205.0
Emergency Image Version.......................... N/A
Build Type....................................... DATA + WPS
System Name...................................... WLC-HO
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 10
Number of Active Clients......................... 16
Maximum number of APs supported.................. 12
Power Supply 2................................... Present, OK
NAME: "Chassis"    , DESCR: "4400 Series WLAN Controller:12 APs"
PID: AIR-WLC4402-12-K9,  VID: V04,
*Mar  1 00:00:11.642: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:11.654: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3500 Software (AP3G1-RCVK9W8-M), Version 12.4(23c)JA3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 18-Oct-11 15:02 by prod_rel_team
*Mar  1 00:11:34.018: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:11:34.987: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:11:55.941: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C2960S-48LPS-L
*Mar  1 00:12:02.978: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:12:12.978: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:12:22.978: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:12:32.979: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:12:42.979: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
Not in Bound state.
*Mar  1 00:12:52.979: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:12:52.979: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:12:56.326: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C2960S-48LPS-L
*Mar  1 00:13:02.983: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:13:12.983: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar  1 00:13:22.983: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
show cdp neigh from switch
AP2894.0fc1.00f6 Gig 1/0/1         149               T    AIR-CAP35 Gig 0
interface GigabitEthernet1/0/1
description Linked to AP
switchport access vlan 26
switchport mode access
spanning-tree portfast
end
interface GigabitEthernet1/0/49
description Linked to BB
switchport mode trunk
end
show vlan
26   WLC         active    Gi1/0/1, Gi1/0/2, Gi1/0/3
Two problems:
Ap does not have enough power:
And
AP does not have an IP address. Is there a configured dhcp that the ap can reach from it is subnet?
can I enter static ip from AP console
do I need any config for power on the switch, currently i have three POE device on the switch WS-C2960S-48LPS-L
POE1#show power inline
Module   Available     Used     Remaining
          (Watts)     (Watts)    (Watts)
1           370.0       42.6       327.4
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Gi1/0/1   auto   on         15.4    AIR-CAP3502I-E-K9   3     30.0
Gi1/0/2   auto   on         15.0    AIR-LAP1242AG-E-K9  3     30.0
Gi1/0/3   auto   on         12.2    AIR-LAP1131AG-E-K9  3     30.0
Here is how to configure the AP with static IP:
https://supportforums.cisco.com/docs/DOC-18274
Note: if the command with "lwapp" keyword could not be run then try the keyword "capwap" instead in the command.
You need a PoE that is IEEE 802.11af compliant. Check if your switch is compatible with this.
Not able to configure static IP even powering ; only get following msg
1.  WLC:  sh sysinfo;
Hi Anthony,
Your output to the above commands are not complete and not correct.
I need the FIRST TWO pages of the output to the command "sh sysinfo" of the WLC.
I need the output from the WAP the commands "sh version" and "sh inventory".
Don't worry about the power.  It's not a major issue.  We'll deal with the power AFTER the WAP has joined the WLC.
The WAP doesn't have an IP address.
In enable mode, enter the following commands:
AP#capwap ap ip address
AP#capwap ap controller ip address
Marco Gonzalez
Level 5
Level 5
Also make sure that the access point is properly powerd with the proper power supply (AIR-PWR-B), power injector (AIR-PWRINJ4) or via PoE (802.3af compliant port providing at least 15.4 W
chan
Level 2
Level 2
It seems that you need to configure 'Vendor Classes' in your DHCP scope for these new 3502 APs.  What do you have for your DHCP server?  If you have DHCP in your router, you need to configure option 60.
