AP using a switches IP address
rgm
I am adding new APs but when they boot up they use the address of one of the Switches making it impossible to SSH into the switch.
Isn't the AP suppose to make sure that the IP address is available?
How can I force the AP to change its IP address without setting it statically?
Can I reserve in the controller a range of IP addresses that the APs cant use?
Scott Fella
I think your dhcp server needs to have reservations. It’s not the AP but your dhcp.
-Scott
 The problem is that your switch is using an IP address that is part of the IP address range provided by DHCP server.
 You can go to whatever is your DHCP server and exclude that IP from pool.
 WLC no necessarily is the DHCP server for APs.
 Make sure you have the correct information of who is who one your network.
