AP WAS NOT JOINING TO WLC
raghu0001
1832i-D-K9 AP not joining to WLC 2504
Getting AP CLI errors as below
 [*02/03/2021 15:13:25.6645] CAPWAP State: Discovery
[*02/03/2021 15:13:25.6645] Discovery Request sent to 192.168.0.73, discovery type STATIC_CONFIG(1)
[*02/03/2021 15:13:25.6645] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*02/03/2021 15:13:25.6645] Discovery Response from 192.168.0.73
[*02/03/2021 15:13:25.6645] Discovery response from MWAR ''running version 0.0.0.0 is rejected.
[*02/03/2021 15:13:25.6645] Failed to decode discovery response(status = 4).
[*02/03/2021 15:13:25.6645] CAPWAP SM handler: Failed to process message type 2 state 2.
[*02/03/2021 15:13:25.6645] Failed to handle capwap control message from controller - status 4
[*02/03/2021 15:13:25.6645] Failed to process unencrypted capwap packet 0x25be000 from 192.168.0.73
[*02/03/2021 15:13:25.6645] Failed to send message to CAPWAP state machine, msgId 0
[*02/03/2021 15:13:25.6645] Failed to send capwap message 0 to the state machine. Packet already freed.
[*02/03/2021 15:13:25.6645] IPv4 wtpProcessPacketFromSocket returned 4
AP Running Image version  8.5.140.0
WLC  version 8.5.140.0
13 Replies 13
balaji.bandi
is this only AP not joining others working as expected? is this any upgrade or changes?
there is some bug around not sure if this effecting you (worth checking)
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvu20765
BB
Only one AP has not joining to WLC rest of all joined and working fine.
For reference i have attached AP CLI OUTPUT and WLC shw sysinfo and Shw time outputs
Sandeep Choudhary
paste the output of these commands from WLC:
show sysinfo
show time
Dont forget to rate helpful posts
For reference i have attached AP CLI OUTPUT and WLC commands outputs
joyaljp
Did you check this AP model supported by the software which is running on your controller?
Could you share show sysinfo output from controller CLI
Yes, the model AIR-AP-1832i was supported to WLC software 8.5.140.0
This one AP was not joining rest of all joined and working fine
WLC and AP outputs as attached below
Can you check the reason for the join failure in the WLC. Monitor>Ap statistics> AP join. You will see the reason for the AP join rejection.
Are all your other AP's also configured on the same 192.168.12.0/24 subnet? The error says this subnet is not known by the WLC. If your using some other subnets to manage your AP's then try configuring the AP switch port with the correct VLAN.
it's not /24
it is /20 subnet
and the switch port is in same subnet
all other ap's are in same subnet and same VLAN and connected to wlc and working fine
@raghu0001 wrote:
it's not /24
it is /20 subnet
Erase the config of the AP and see if makes any difference.
capwap ap erase all
Try the following.
1. @Leo Laohoo  Rest the ap via cli.
2.Hard reset the AP.
3. Try loading another firmware into the AP and then repet the join process.
Leo Laohoo
ip 192.168.12.119, netmask 255.255.240.0, gw 192.168.0.1, bcast 192.168.15.255
Wow!  For 75 APs, that is one HUGE subnet!
