AP with Clean-air Express and 3650 controller
Topher0027
Is Clean-air express supported on the 3650 wireless controller with 1602e APs? The Clean-air options on the controller are available but do not seem to be active. In the controller gui the Clean-air admin status is disabled and the Clean-air operation status is down. I did confirm the Clean Air option is enabled on the config menu for the b/g/n band. Am I missing something here or are these AP's just not supported? Thanks!
The 1600's and 1700's do it on hardware on the AP. It's not the full CleanAir you get from the higher end access points, but does do limited CleanAir functionality.
-Scott
-Scott
Scott Fella
CleanAir Express is different than CleanAir. Express means that the AP does the function of detection, not the controller.  1600's & 1700's run CleanAir Express and you don't have the 100% functionality of CleanAir with these access points.
-Scott
-Scott
Scott,
if the 1600's are used as lightweight AP's do they essentially lose their ability to use cleanair because the controller has no settings for the express?
-Scott
-Scott
