We can set 2.4GHz backhaul on a mesh, and it will work, but if a MAP reboots it wont reconnect.
Only way we have found to reconnect the MAP is to switch back to 5GHz backhaul.Then, after the AP reconnects, we can switch back to 2.4GHz .
It's like the MAP is loosing the configuration information about the backhaul.
Anyone have any ideas? We are running 8.2.100.0 on our WLC.
Phil
