ap:
miradooRAND
Community Member
I am a new comer about wireless.I have a problem concerning configuring the ap(1200 series).I have upgraded the ios to a new version and I needed to delete the earlier version to that.After, I have reloaded the device and this prompt is appeared "ap:" so I would like to take out this problem.
Thanks for your assistance.
regards
miradoo
jcornford
Level 3
Level 3
What version are you going too, and from? The prompt if it's "AP>" might mean you've lost the running config.
c1200-k9w7-mx.123-4.JA is the earlier version and the last is c1200-k9w7-tar.123-8.JA.tar that i have done.
The prompt appeared is "ap:"(after reloading), is it rommon mode? I don' t know how to go out of the problem.
I don' t know the commands and the process to do.
So thanks for your assistance.
regards
miradoo
Thanks a lot for your assistance. I found the solution in the link that you
have given.(reloading the AP by using the mode button has resolved the prompt "ap:" problem).
regards.
miradoo
