1200 AP missing radio interface
zahid77
hi i have a 1200 ap and its radio interface is missing. i mean i am uanble to see its radio interface
I really need this urgently.Anybody can help me
josephbruce
Community Member
First verify that the radio module is physically installed in the AP.
Second, what IOS are you running? Or is it VXworks?
thanks for ur reply plz find the enclosed show commands output and tell me the solution
cisco AIR-AP1231G-A-K9 (PowerPC405GP) processor (revision A0) with 14838K/1536K bytes of memory.
Processor board ID FOC09501XL4
PowerPC405GP CPU at 196Mhz, revision number 0x0145
Last reset from power-on
1 FastEthernet interface
1 802.11 Radio(s)
That was from an AP with the radio installed.
Your config
cisco AIR-AP1230B-E-K9 (PowerPC405GP) processor (revision A0) with 14326K/2048K bytes of memory.
Processor board ID FOC07410KFY
PowerPC405GP CPU at 196Mhz, revision number 0x00C4
Bridging software.
1 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Yours doesn't show a radio module installed,
You need a radio module
