AP1100_not broadcasting
mhasabal
Hello everyone
i need your help figuring out why i am not able to see the SSID please.
version 12.3
no service pad
service password-encryption
hostname AP1100
no logging console
ip subnet-zero
ip domain name cisco.com
ip name-server 10.10.10.254
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 ssid DRose1
   authentication open
   authentication key-management wpa
   infrastructure-ssid
   mobility network-id 1
   wpa-psk ascii 7 xxxxxxxxxxxxxxxx
   admit-traffic
username Cisco password 7 1531021F0725
username 90840da50ee6 password 7 065F5F79181E0D185047170E5A
username 90840da50ee6 autocommand exit
username 90840da896e5 password 7 065F5F79181E0D185D4E440E59
username 90840da896e5 autocommand exit
username 904ce542851c password 7 09151E5D1A0042465954517B28
username 904ce542851c autocommand exit
username 0019d22f08a0 password 7 091C1E58400145400D5C5C2B7B
username 0019d22f08a0 autocommand exit
username 0026b6324815 password 7 1249554544095A57787F7C7966
username 0026b6324815 autocommand exit
username mhasabal password 7 00291C2B050B5E545D7115
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid DRose1
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
packet retries 128
station-role root
antenna gain 0
world-mode dot11d country US both
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.10.10.253 255.255.255.0
no ip route-cache
ip default-gateway 10.10.10.254
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
access-list 111 permit tcp any any neq telnet
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
bridge 1 route ip
line con 0
access-class 111 in
logging synchronous
line vty 0 4
access-class 111 in
AP1100#sh ver
Cisco IOS Software, C1100 Software (C1100-K9W7-M), Version 12.3(8)JEB1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 20-Jul-07 20:43 by dchih
ROM: Bootstrap program is C1100 boot loader
BOOTLDR: C1100 Boot Loader (C1100-BOOT-M) Version 12.3(2)JA4, RELEASE SOFTWARE (fc1)
AP1100 uptime is 6 days, 18 hours, 25 minutes
System returned to ROM by reload
System image file is "flash:/c1100-k9w7-mx.123-8.JEB1/c1100-k9w7-mx.123-8.JEB1"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1121G-A-K9     (PowerPCElvis) processor (revision A0) with 15138K/1236K bytes of memory.
Processor board ID FOC09324U5R
PowerPCElvis CPU at 197Mhz, revision number 0x0950
Last reset from reload
1 FastEthernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:15:2B:91:3F:0C
Part Number                          : 73-7886-09
PCA Assembly Number                  : 800-21481-09
PCA Revision Number                  : A0
PCB Serial Number                    : FOC09324U5R
Top Assembly Part Number             : 800-22053-07
Top Assembly Serial Number           : FTX0938V03K
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1121G-A-K9
Configuration register is 0xF
Rob Huffman
Hi Mohammed,
The command that controls the "Broadcast" of the SSID is "guest mode". Have a look;
guest-mode (SSID configuration mode)
Use the guest-mode SSID configuration mode command to configure the radio interface (for the specified SSID) to support guest mode. Use the no form of the command to disable the guest mode.
[no] guest-mode
The access point can have one guest-mode SSID or none at all. The guest-mode SSID is used in beacon frames and response frames to probe requests that specify the empty or wildcard SSID. If no guest-mode SSID exists, the beacon contains no SSID and probe requests with the wildcard SSID are ignored. Disabling the guest mode makes the networks slightly more secure. Enabling the guest mode helps clients that passively scan (do not transmit) associate with the access point. It also allows clients configured without a SSID to associate.
Examples
This example shows how to set the wireless LAN for the specified SSID into guest mode:
(config-if-ssid)# guest-mode
This example shows how to reset the guest-mode parameter to default values (no broadcast SSID):
(config-if-ssid)# no guest-mode
Hope this helps!
Rob
Rob Huffman
Hi Mohammed,
[no] guest-mode
Examples
Hope this helps!
Rob
thanks Rob. it's working now
