AP1121 and Cisco 7920
rmv72
I've configured AIR-AP1121G-A-K9 and clients already associated adn they works with out problems-
xxx#sh dot11 associations
802.11 Client Stations on Dot11Radio0:
SSID [xxx] :
MAC Address IP address Device Name Parent State
0040.96b1.59a5 10.100.5.39 CB21AG/PI21AG RG07 self Assoc
0040.96b5.167d 10.100.5.47 CB21AG/PI21AG RG11 self Assoc
0040.96b5.16d3 10.100.5.41 CB21AG/PI21AG RG15 self Assoc
I'm trying to connect Cisco 7920 phone to AP but failed.
First question - does AP1121 support Cisco 7920?
jeromehenry_2
Level 3
Level 3
I am not sure that there would be incompatibility in the hardware, but probably in the authentication process... what kind of settings has the SSID you try to connect your phone to?
A few debug might help also. 7920 has specific requirements to associate (IOS version 12.3(8) or later, QOS enabled, etc)...
hth
Jerome
migilles
Yes 7920 is supported on the AP1121G. What authentication are you trying to use?
If using key-management (WPA, WPA-PSK, CCKM), then would want to set the phone to AKM mode. LEAP and EAP-FAST modes can do WEP w/ optional CCKM.
Would suggest to try a ssid w/ open and no encryption first, then can increase authentication & encryption.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7920/5_0/english/administration/guide/4_2.html
Thank's to all. I found my mistake - i configured it remotly via
Cisco 7920 Configuration Utility
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7920/5_0/english/administration/guide/7920cfgu.html
and didn't disconnect USB-connection from Phone to computer.
If USB is active and your WLAN is also using the same network as the USB (192.168.1.0), then this could prevent from receiving an IP address. Will need to disable the USB first or simply power cycle the phone after upload the configuration.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7920/5_0/english/administration/guide/7920cfgu.html#wp1300704
