AP1130AG - Unable to see other clients on same AP
William Watts
We have 3 AP1130AG installed on our network with 2 VLANs. The APs are set up with two SSID, one for each VLAN. If two devices are connected to the same SSID on the same AP, they are UNABLE to ping/communicate with each other. If two wireless devices are on the same SSID and different APs, they are able to ping/communicate with each other. When the two devices are connected to the same AP/SSID, I can ping both devices from a server that is wired connected. I need to figure out why I can't ping/communicate between two devices that are connected to the same AP and are on the same SSID/VLAN. Below is the current configuration of the wireless AP.
Building configuration...
Current configuration : 2897 bytes
version 12.3
no service pad
service password-encryption
hostname AP02
enable secret 5 ********
led display alternate
ip subnet-zero
no aaa new-model
dot11 ssid GuestIAP
   vlan 20
   authentication open
   guest-mode
   mbssid guest-mode
dot11 ssid IAP
   vlan 10
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 7 *******
power inline negotiation prestandard source
username ********
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 10 mode ciphers tkip
ssid GuestIAP
ssid IAP
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
channel 2437
station-role root
interface Dot11Radio0.10
encapsulation dot1Q 10 native
no ip route-cache
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.20
encapsulation dot1Q 20
no ip route-cache
bridge-group 20
bridge-group 20 subscriber-loop-control
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
bridge-group 20 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
ssid GuestIAP
ssid IAP
dfs band 3 block
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
channel dfs
station-role root
interface Dot11Radio1.10
no ip route-cache
bridge-group 1
interface Dot11Radio1.20
no ip route-cache
bridge-group 20
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 160 in
interface FastEthernet0.10
no ip route-cache
bridge-group 1
interface FastEthernet0.20
no ip route-cache
bridge-group 20
interface BVI1
ip address 192.168.100.222 255.255.255.0
no ip route-cache
ip default-gateway 192.168.100.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Amjad Abdullah
This usually happends if the port protected was enabled:
(AP-if) bridge-group port-protected
But I can't see this configured.
can you try disable/remove the lines:
no bridge-group 1 source-learning?
bridge-group 1 block-unknown-source?
would that make any difference?
Amjad
Rating useful replies is more useful than saying "Thank you"
Amjad Abdullah
Amjad
Thanks Amjad. I tried to make those changes but it told me I couldn't remove those commands. I then googles the error message I got when I tried to remove the commands. It brought me to another Cisco forum with someone that had the same problem. They corrected the issue by putting in "bridge-group 1 subscriber-loop-control."
I searched the internet for over 2 hours yesterday about this problem and couldn't find anything with the same issue. Here is the link to the forum that helped me resolved the issue.
https://supportforums.cisco.com/thread/2024918
Thanks for helping me get in the right direction.
