Autonomous AP for EAP
JPavonM
We've got an ACS 5.1 virtual appliance for device administration  tasks and now we want to authenticate wireless domain users, but only by  it's username/password, without trusting any CA certificates from the  AD (is it required an ACS certificate too?).
Maybe there are some steps I have missed but I cant' locate where is the problem:
This is the configuration of the AP that I have but, is it correct?
aaa group server radius rad_eap
server a.b.c.d auth-port 1812 acct-port 1646
server a.b.c.d auth-port 1645 acct-port 1646
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default group rad_eap local
dot11 vlan-name WPA vlan 199
dot11 ssid LABREDES_CERT
   vlan 199
   authentication open eap eap_methods
   authentication network-eap eap_methods
   guest-mode
   mbssid guest-mode dtim-period 75
interface Dot11Radio0
  encryption vlan 199 mode ciphers tkip
We  have spent some days and nothing seems to work but nothing appears in  the ACS log, there are no messages in the log, and a debug (radius, aaa authentication) in the AP only  shows (AAA/BIND(0000014E): Bind i/f  )
Any help would be appreciated
stefan.angerer
Level 7
Level 7
you need to globally configure your radius servers too!
e.g.: radius-server host a.b.c.d auth 1812 acc 1646 secret
also you need to change your SSID config
    authentication key-management wpa
Regarding the certificate: you can use PEAP with MSCHAPv2, and leave the selfsigned certificate on the ACS (so you simply disable certificate validation on your clients), but I would definitely not recommend this.
hope that helps!
Stefan
