AP1131-AG CLI & GUI not synching
smith606306
Level 3
Level 3
I have a problem with an AP1131-AG access point.When I update the CLI it does not update on the GUI and vice versa. The access point is connected to a 3560 switch and there is no WLAN controller involved.
Has anyone else come across this problem?
change the privelege and see if that works out!! and lemme know if that resolves the issue..
Please dont forget to rate the usefull posts!!
Surendra
Surendra BG
8 Replies 8
Leo Laohoo
Did you save the config in CLI?
Yes.
How do I tell if its for an autonomous or lightweight version?
The output of the show version command is:
Cisco IOS Software, C1130 Software (C1130-K9W7-M), Version 12.4(21a)JA1, RELEASE
SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 16-Sep-09 18:36 by prod_rel_team
ROM: Bootstrap program is C1130 boot loader
BOOTLDR: C1130 Boot Loader (C1130-BOOT-M) Version 12.3(8)JEA, RELEASE SOFTWARE (
fc2)
APETHOS1131-0301-1 uptime is 5 weeks, 5 days, 23 hours, 22 minutes
System restarted at 09:16:49 BST Fri Jun 3 2011
System image file is "flash:/c1130-k9w7-mx.124-21a.JA1/c1130-k9w7-mx.124-21a.JA1
in the image
W7 == Autonomous
W8 == LWAPP image
Now.. while using CLI, did u save the config?? or whats the access right?? is it READ ONLY or READ/WRITE
Lemme know if this naswered ur question and please dont forget to rate the usefull posts!!
Surendra
Surendra BG
I did the original config in the CLI and saved it but the GUI is showing no config.
I have full read/ write access
Wat about GUI to CLI?
Surendra
Surendra BG
Ah! I only seem to have level 15 read only access to the GUI.
Attached is the config.
Surendra
Surendra BG
i am on privilege level 15 (highest) but it only gives me read only access from the GUI.
Any clues how to change this?
