AP1200 5 Ghz Antenna Capabilities
Steve Dussault
Various literature indicates that the 5Ghz Antenna is a 6dbi patch and 2dbi dipole. Can anyone please describe in detail the features / funtions of the antenna. (What physical position does the antenna need to be for what function?)
tepatel
Part number for 802.11a radio including antenna is AIR-RM20A-A-K9.
Here is the link for Channels, Power Levels, and Antenna Gains for 802.11a
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1200/accsspts/ap120scg/bkscgaxa.htm
Some more link in that area
http://www.cisco.com/univercd/cc/td/doc/pcat/airo1200.htm#xtocid6
http://www.cisco.com/warp/public/cc/pd/witc/ao1200ap/prodlit/casap_ds.htm
Thank you for the links. They answer all of my questions but one. What mode is the antenna in when it is extended all the way down? 6dbi or 2dbi? To clarify the unit is wall mounted and the antenna is flipped down so it against the wall. Thank you
