Bookmark
Subscribe
505
Please, Help me with Ethertype Filters
mike_zag
Hello!
My task is very simple.
I want Birdge 350 Series to forward ONLY IP protocol. And drop others.
I follow the Ethertype Filters link, then define new FILTER
with Default Disposition set to block.
Then I add a new Specisal Case with IP protocol (0x0800) with desposition set to forward.
So I think that is all. And then I apply the filter to Interfaces.
And it DOES NOT WORKS. IP protocol is blocked.
Now I have to define filter with Default Disposition set to forward and define all
protocols I don't wanna see with desposition set to block.
I think that it's not correct solution .
So Please show me my mistake!
Thank you!
gverr
Mike,
To get an IP connection (layer 3 of OSI model) you need to have a link at layer 2 and 1 of the OSI model, that is MAC and physical. As such, your mobile unit need to know the MAC address of your target node or the the MAc of the EXIT door of your segment to the target IP address on another segment, that is your router.
To get the MAC address of a node while having its IP address, there is a protocol, ARP (Address Resolution Protocol), which is a subset of IP. You need to set up ARP protocol as well in your Special Cases (Protocol ID 0x0806). So, to get IP only crossing an AP, block all traffic and forward IP and ARP only.
Cordially,
Guy
gverr
Mike,
Cordially,
Guy
