AP1200 VoIP configuration with two ssids
matthogue
Hello everyone,
I posted this in General Forum first, but i wanted to hit this group as well.
On an AP1200, can you set up two different SSIDs on a radio interface using two different types of encryption, without using vlans?
I am trying to use WEP for the data side(i know, still waiting on the wpa go ahead) and wpa2 on the voice side. The problem comes when I set the ecnryption mode on the radio interface. It only allows for one type, wep or wpa. And the site is so small that they do not want to set up vlans.
Any ideas?
thanks
Matt
smalkeric
Level 6
Level 6
you can assign two VLAN and the n configure two ssis's for each vlan.
I tried it at my 1240 and it is possible to set encryption to Cipher: AES CCMP + TKIP + WEP
Then you must make 2 SSID, one of them will be set to Key Management: Optional, Enable WPA,WPA2
The other one (WEP) you must set to Key Management: None
