02-06-2013 10:22 AM - edited 07-03-2021 11:29 PM
I have a AP1242AG access point at home with my 3745 router and 2960G switch and I want to be able to use the roku android app
http://sdkdocs.roku.com/display/RokuSDKv48/External+Control+Guide
So as it can't discover it, does anyone know of a setting on the AP that might block broadcast packets or frames?
Solved! Go to Solution.
02-06-2013 10:47 AM
There shouldn't be anything on the AP to "block" this traffic. Since ROKU is using a multicast communication method for your Android App, can you confirm you are either
A. Android/Remote app is on Wireless connection on the "same VLAN" as your Roku?
or
B. You have PEM routing configured/enabled to properly route this traffic between subnets
It doesn't appear to be a "link-local" multicast range, but you will need to enable PEM routing if going between VLANs.
Also, do you know if you have IGMP snooping enabled/disabled at your Switch?
02-06-2013 10:47 AM
or
02-06-2013 10:54 AM
They're both connected to the same ssid (same vlan)
I can ping the roku from the android (Nexus 7)
I do not think I have ICMP snooping enabled, I can post a sanitized copy of the AP's config.
and I will get the switch's config tonight.
The intervlan routing is handeled by a NME-16ES-1G-p that is linked to the 2960G via 1x gig, the AP is plugged directly into the etherswitch so it can be powered via POE.
if it'll help I can post the etherswitch's and the switch's config tonight.
02-06-2013 10:56 AM
Current configuration : 6050 bytes
! No configuration change since last restart
version 12.4
no service pad
service password-encryption
hostname RLH_AP
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
clock timezone Central -6
clock summer-time -0500 recurring
ip domain name Mydomain.net
ip name-server 10.0.2.5
dot11 ssid Entertainment
vlan 3
authentication open
authentication key-management wpa version 2
wpa-psk ascii 7 061E4B6676140F333F2E02290D583C6D06706A6375
information-element ssidl
dot11 ssid Secure
vlan 4
authentication open
wpa-psk ascii 7 00205D163E63303D40620C6328494B0F2A3E3255671D1D2C071D7B1B29373F285C715B06113D0C010C565F4569004B7057161523544C4E24154559574038260D
dot11 network-map
dot11 arp-cache
dot11 adjacent-ap age-timeout 2
power inline negotiation injector 0021.d786.b497
username root privilege 15 password 7 ####
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 4 mode ciphers aes-ccm
encryption vlan 3 mode ciphers aes-ccm
broadcast-key vlan 4 change 10
broadcast-key vlan 3 change 10
ssid Entertainment
ssid Secure
no preamble-short
channel 2412
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface Dot11Radio0.4
encapsulation dot1Q 4
no ip route-cache
bridge-group 4
bridge-group 4 subscriber-loop-control
bridge-group 4 block-unknown-source
no bridge-group 4 source-learning
no bridge-group 4 unicast-flooding
bridge-group 4 spanning-disabled
interface Dot11Radio0.5
encapsulation dot1Q 5
no ip route-cache
bridge-group 5
bridge-group 5 subscriber-loop-control
bridge-group 5 block-unknown-source
no bridge-group 5 source-learning
no bridge-group 5 unicast-flooding
bridge-group 5 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid Entertainment
ssid Secure
dfs band 3 block
channel 5180
station-role root
bridge-group 1
interface Dot11Radio1.2
no ip route-cache
bridge-group 2
interface Dot11Radio1.3
no ip route-cache
bridge-group 3
interface Dot11Radio1.4
no ip route-cache
bridge-group 4
interface Dot11Radio1.5
no ip route-cache
bridge-group 5
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
interface FastEthernet0.2
no ip route-cache
bridge-group 2
interface FastEthernet0.3
no ip route-cache
bridge-group 3
interface FastEthernet0.4
no ip route-cache
bridge-group 4
interface FastEthernet0.5
no ip route-cache
bridge-group 5
interface BVI1
ip address 10.0.0.4 255.255.255.0
no ip route-cache
ip default-gateway 10.0.0.1
ip http server
ip http port 1025
ip http authentication local
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
access-list 50 permit 10.0.1.11
access-list 50 permit 10.0.0.0 0.0.0.255
access-list 50 deny any
snmp-server community ##### RW
radius-server local
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
transport input ssh
line vty 5 15
transport input ssh
sntp server 10.254.254.1
end
02-10-2013 02:47 PM
I had thought I didn't have IGMP snooping on because it wasn't listed in the running config, but on research I found that its on by default.
From some more research the 1242AG doesn't let multicast cross from wireless to wired with IGMP on.
and did a wireshark capture with a monitor session of the ap to ethswitch port.
the capture didn't show any traffic from the roku or the nexus 7
so from the capture and some multicast research I found the olution to be to do "no IP IGMP snooping" on the ap.
