01-15-2007 06:44 AM - edited 07-03-2021 01:28 PM
I can not telnet the AP1242 and I can not use its web GUI. I do not find the commands to enable Telnet and HTTP (such as "config network telnet / webmode" of the WLC2006). Does anybody provide them.
AP1242 releases are:
* Cisco IOS Software, C1240 Software (C1240-K9W8-M), Version 12.3(11)JA1, RELEASE)
* BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.3(7)JA1, RELEASE SOFTWARE )
* LWAPP image version 4.0.206.0
Thanks by advance. Best Regards,
Alain-Claude
01-15-2007 09:48 AM
Hi, i belive there is a mistake, since the LWAPP only should work with a wireless lan controller.
http://www.cisco.com/en/US/products/ps6521/products_data_sheet0900aecd8031c968.html
When the LWAPP turns on it locates the WLC by an arp request, and the controller set's up all the configuration on the AP. You can not configure a LWAPP true TELNET or HTTP.
If you only need an AP you should practice a downgrade on your AP to make it work as an autonomous AP.
Check it Here.......
Hope it helps!!!!
01-16-2007 12:47 AM
Hi Paul,
I understood that the lightweight AP is monitored by a WLC (I use a WLC2006). I am setting up a test-bed and I intended to use telnet and / or http to display traces and check configuration directly from the AP without connection to the console port. I will do it (at least for the configuration) through the WLC.
Thanks for your answer.
Best Regards,
Alain-Claude
