AP1542I-E-K9 and AIR-AP1832I-E-K9C
I just need some confirmation about compatibility between 2 models that support Mobility Express.
Is it possible to manage AP1542I-E-K9 and AIR-AP1832I-E-K9C with Mobility Express on the same network? Is it a problem that I have 2 differents models ?
Thanks for your help
5 Replies 5
Hello patoberli,
On this documents it seem's AP1542I-E-K9 does not support Mobility express, but from the link below  indicate the opposite:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/1540/installation/guide/1540hig/ch1.html
which of this 2 documents is correct (I suppose the second documents because is written 2 months after the first) ?
Could depend on the used software version. My document was for the 8.5 release train.
I think it's a "typo" in my document, as there is no model named AIR-AP1540I-x-K9. I'm 99% sure they mean the AP1542I with that model name.
I think you are right,check the document:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-308874
Finaly ,are you sure that I can mixed AP1542I-E-K9 and AIR-AP1832I-E-K9C on the same network and manage them with mobility express version 8.5 or greater ?
Thanks again
You can only manage Mobility Express compatible access points. The 1540 is supported as long as you have the proper image.
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/87/release_notes/b_ME_RN_87.html
-Scott
